Arbuckle23 wrote:Post up a pick of the 28mm tyres fitted up when you have done that.
Keen to see the clearance.
It'll be a bit difficult to see the clearance if I took a pic, because the guards would interfere with the view. However the fact that I have guards fitted alone would suggest that there is ample clearance there, even taking into account the variation in size of different "28mm" tyres.
Does that mean you can run 32mm, without guards? Possibly.
I've not replaced the front tyre, it has always been a 25mm Schwalbe Dureme. It would be close to fitting a 28mm tyre there with the guard as well, and comfortably so without.
Cameron
