Merida 95 carbon
davetheaviator
Merida 95 carbon
Postby davetheaviator » Mon Oct 02, 2017 2:51 pm
Hi all I'm new here so please be gentle...
I have a Merida 95 carbon with all ultegra except cranks it has FSA 170 cranks I was thinking about upgrading cranks . It is confusing if you are not up with all this and I must confess I'm not. Which ultegra crank should I install please help. I'm 170cm tall with 170 mm cranks at the minute..
Thank you all for your help in advance.
Cheers Dave
eeksll
Re: Merida 95 carbon
Postby eeksll » Mon Oct 02, 2017 9:00 pm
you need to know what sort of bottom bracket you currently have, but probably more important what type of BB your frame will take.
I would expect you would need a different Bottom bracket for the ultegra chainset.
Also why the swap? just to keep everything the same?
Postby Duck! » Mon Oct 02, 2017 11:25 pm
Picking the crank is the easy bit.... Just match the arm length, unless there's a physiological need to change, and pick the chainring combo. The frame will determine which of the multitude of bottom bracket formats or adaptors is required.
Users browsing this forum: CKinnard, vinski
