First power meter - guidance and feedback please
Alex Simmons/RST
Re: First power meter - guidance and feedback please
Postby Alex Simmons/RST » Sun Apr 01, 2018 9:18 am
Certainly the power meter is an accurate tool for calculating mechanical work done, and via that an estimate of energy metabolised while exercising. You can probably get an estimate within a 10% accuracy range most of the time which is more reliable than other day to day means such as online estimators, heart rate monitors.
As a ROT, energy expended in kcal = 1.05 - 1.15 x mechanical work done in kJ.
IOW if you take the kJ reading from your power meter, add 10% and call that Calories metabolised, you'll most likely be in the right range give or take 5%.
While there are differences, on average, in efficiency between untrained, recreational and trained cyclists, those differences are smaller than the individual variability of efficiency between riders at each level. IOW a recreational rider can still be more efficient than a trained cyclist.
That's because inherit biochemical factors, muscle fibre type mix and the duration and relative workload of effort are more influential on one's individual GME than various and often purported pedalling technique improvements - due to the fact that cycling is a motion performed without many degrees of freedom.
You can be more precise with metabolic energy demand from cycling if:
i. you know your GME via gas exchange analysis performed in a lab, and
ii. your cycling is mostly relatively steady state.
That said it is possible to determine VO2max (and hence GME) with reasonable accuracy using a good power-duration model if you have sufficient quality mean maximal power data across a decent range of duration (e.g. from 5s to 3600s). But this is relatively new and its application requires care in understanding limitations (usually a result of factors influencing the quality of data inputs and a wise choice of model).
CKinnard
Postby CKinnard » Sun Apr 01, 2018 11:57 am
Gas exchange analysis is confounded by diet composition, bodyfat %, fat burning adaptation, and insulin resistance.
Arbuckle23
Postby Arbuckle23 » Sun Apr 01, 2018 12:05 pm
CKinnard wrote:Gas exchange analysis
I have plenty of gas :)
Alex Simmons/RST
Postby Alex Simmons/RST » Sun Apr 01, 2018 12:48 pm
CKinnard wrote:Gas exchange analysis is confounded by diet composition, bodyfat %, fat burning adaptation, and insulin resistance.
So?
CKinnard
Postby CKinnard » Mon Apr 02, 2018 12:26 pm
So?
These are factors that effect GME calculation and result.
Pedaling technique has been too casually dismissed in its influence on GME. i.e the influence of cadence on climbing efficiency.
And more significant inputs to GME are a higher % of total blood flow (cardiac output) to key cycling muscles, and glycogen storage in same.
Experienced riders on average are likely to have an advantage in both.
Alex Simmons/RST
Postby Alex Simmons/RST » Mon Apr 02, 2018 2:50 pm
So?
Again, so what?
In the context of this thread, i.e. guidance on using a power meter, it's hardly pertinent.
Yes, elite riders are, on average, a little bit more efficient than trained, recreational and untrained riders. So what?
The differences in efficiency between such rider levels is not actually all that much (~10% on average), and they pale when compared with the differences in sustainable power output for riders across the capability spectrum (which are of the order of ~300-400%). IOW differences in efficiency only account for a small proportion of the differences in physiological capability. And our ability to positively influence GME is rather limited because it is dominantly an inherited trait.
When testing efficiency there are typically controls wrt the relative intensity one tests at, and what pre-test controls are put in place, such as diet, fatigue, glycogen levels and so on. Yes efficiency varies with cadence and other factors affect it on an acute and chronic basis. Environmental conditions or hydration status for instance. Yawn. Tell us something new or useful in context of this thread.
Cadence is not "technique". It's just a measure of crank rotational velocity.
Indeed cadence is not something we can actually independently control, despite what one might believe.
What we can control is our level of effort (power output) and gear choice. Cadence is then an outcome of those choices and the resistance forces acting against us at the time.
As for technique being lightly dismissed, meh I just refer to the published science which demonstrates changing "technique" from that which develops naturally really doesn't do all that much.
In any case we don't typically pedal at cadences equated with the highest efficiency (we tend to pedal more quickly that that) since maximising efficiency isn't typically the objective of cycling (certainly not in any competitive or performance sense). What does matter (physiologically) is the ability to sustain power output over durations of relevance. Fortunately that's what a power meter tells us, and is what makes it really useful.
In any case, esoteric discussion of GME is not really of much value here.
Information about using the power meter in a productive manner is the topic.
MichaelB
Postby MichaelB » Mon Apr 02, 2018 3:40 pm
I dunno what GME is ?
Anyway, even if I could work it out with a power meter, I wouldn't work it out.
Far beyond what this thread was all about anyway. BoT. :-)
Alex Simmons/RST
Postby Alex Simmons/RST » Tue Apr 03, 2018 7:07 am
MichaelB wrote:I dunno what GME is ?
Gross Mechanical Efficiency.
It's the ratio of mechanical energy applied to the cranks of the bicycle to the total energy metabolised by our body.
Approximately 1/5th of the energy we metabolise ends up reaching the cranks. The vast majority of the balance is given off as waste heat.
MichaelB wrote:Anyway, even if I could work it out with a power meter, I wouldn't work it out.
That was my point. Focus on power as it's the integral of all the underlying processes and factors, and is what matters.
For those interested in using the power meter for keeping an eye on their energy balance (i.e. food calories in, exercise and base metabolism calories out), then just use the simple method I outlined earlier for estimating the energy demand while cycling.
Arbuckle23
Postby Arbuckle23 » Tue May 22, 2018 6:48 pm
At the risk of Alex telling me "I told you so" :) The Powerbeat has been sent back.
Had problems with the first sensor, so Watteam sent me another. It too gave problems.
Getting dropouts all the time, readings all over the place, even on a trainer
Contacted Pushys and returned to them for a full refund.
Big Kudos's to Pushys, no problems in returning when I voiced my dissatisfaction with the product.
But the little taste of power now has me in.
Spent a little :wink: :lol: :oops: more on pedal based Favero Assioma.
Been using for a week with no problems, very happy. Solid as a rock.
Riding with/to power is such an eye opener. A lot more to learn, but will enjoy the learning.
MichaelB
Postby MichaelB » Tue May 22, 2018 9:51 pm
Glad it worked out in the end.
Presume single sided ?
Arbuckle23
Postby Arbuckle23 » Wed May 23, 2018 6:54 am
I decided that I would blow the budget right out of the water and got dual sided :oops: .
All the chat about single sided got to me, upgrading later would cost even more.
The good thing is that the pedals can fit my backup bike now. Different crankset types on each bike.
The interesting thing I have learnt about knowing both sides, is that I consistently seem to be 52/48 L/R. And slightly more again on the left when working harder.
Being right handed and useless with my left hand and foot I would have thought it should have gone the other way?
MichaelB
Postby MichaelB » Wed May 23, 2018 8:37 am
Arbuckle23 wrote:I decided that I would blow the budget right out of the water and got dual sided :oops: .
:lol: :lol: Get War Office approval ?
Arbuckle23
Postby Arbuckle23 » Wed May 23, 2018 9:50 am
MichaelB wrote: :lol: :lol: Get War Office approval ?
Ssh :wink:
Alex Simmons/RST
Postby Alex Simmons/RST » Wed May 23, 2018 11:33 am
Power asymmetry is variable and often unrelated to what is our natural side.
But to put it into context, there were times when I was measured as left side dominant while at an easy endurance power level which considering I'm a left below knee amputee may be a little surprising. As the power level went up, I evened up in my power balance.
One of the things with meters which measure each crank/pedal independently is you now actually have two power meters, each with potential error or bias in their readings. It's also twice as many things to go wrong :)
All good fun.
Alex Simmons/RST
Postby Alex Simmons/RST » Wed May 23, 2018 11:35 am
Arbuckle23 wrote:At the risk of Alex telling me "I told you so" :) The Powerbeat has been sent back.
Bummer. But what matters most is that the after sales support backed you up. That's the bit I worry about with the newer players. Perhaps less so early on but later when the weight of longer term financial viability begins to bite.
MichaelB
Postby MichaelB » Wed Nov 14, 2018 3:38 pm
OK, I've now been using the PM (FSA Powerbox) for almost a year now, and am really happy with it, even though I don't use it as well as I could.
It does however, do what I want it to do, so all is good in the world.
BUT, I've now bought a Gravel bike, and will use that a bit as well. So that I don't miss the data sets that I would get when I use the bike (the hrTSS is typically 25% lower than the TSS recorded for the same route (and times) when using a PM).
The bike is a Cannondale Slate and comes with their Si crankset. BikeBug have a 50% off sale on the Pioneer Cannondale Consumer Supplied Left Crank Power Meter for $399.
I know this isn't as accurate as other PM's etc, but compared to the similar options like Stages and 4iii, is this probably the best deal for this type of PM ?
TIA
MichaelB
Postby MichaelB » Thu Nov 15, 2018 8:22 am
Duly sent off email clarifying the 'how', and got this reply ;
Hi Michael
That is still the case.
Here's a pre install check list that gives the clearances you need:
We generally allow 2 to 3 business days for installation upon receipt of your cranks here:
3/595 Princes Highway
Tempe NSW 2044
AUSTRALIA
After ordering send them in along with a copy of the order and the completed check list.
It is a Pioneer requirement that it is installed and calibrated here.
Now, the colour & highlight of the last sentence is mine. What a CROCK !! And what annoys me even more is that it's not stated anywhere in the ad.
Oh, I can take it off myself, but can't put it on and link it to my computer. How dumb is that. :evil: :evil: :evil:
madmacca
Postby madmacca » Thu Nov 15, 2018 1:53 pm
MichaelB wrote:OK, I've now been using the PM (FSA Powerbox) for almost a year now, and am really happy with it, even though I don't use it as well as I could.
TIA
DCRainmaker's annual power meter guide has just come out at https://www.dcrainmaker.com/2018/11/power-meter-buyers-2018.html if you want to check his view of the market.
MichaelB
Postby MichaelB » Thu Nov 15, 2018 2:23 pm
Cheers for that.
The only key for me is the 50% off at Bike Bug. That's where the Pioneer comes in better, and for the Cannondale arms, Stages are exxy.
Update on the fitment stuff : Seems I can get it 'fitted' at the Adelaide store. Still a bit stoopid, but workable, especially for that price.
macca33
Postby macca33 » Fri Nov 16, 2018 12:58 am
MichaelB wrote:Duly sent off email clarifying the 'how', and got this reply ;
Hi Michael
Tempe NSW 2044
AUSTRALIA
I'm fairly sure that the 'installation' is the physical bonding of the PM sensor to the crankarm and I'm fairly sure that it has to be done to an exacting specification, which is why they need your crank arm sent to them.
CAAD10 Berzerker & Focus Mares CX & Ridley Noah SL
biker jk
Postby biker jk » Fri Nov 16, 2018 7:05 am
Hi Michael
Tempe NSW 2044
AUSTRALIA
Exactly. That's what 4iiii requires as well with their factory install option. You send them your crank.
MichaelB
Postby MichaelB » Fri Nov 16, 2018 7:40 am
Yep. Understood that, but what I misinterpreted was that ‘they’ needed to install the crank back on the bike.
Maybe didn’t have enough coffee yesterday.
Anyway, ordered, measurements taken (it’s a bit close, but should be fine) crank removed and ready to be sent off today.
Interesting that Pioneer also want the pedal centreline length as well.
Anyway, getting posted today :-)
Users browsing this forum: Ivanerrol, lewie15, vinski
