I HATE BB standards !!! Grrrrrr
MichaelB
Postby MichaelB » Tue Dec 05, 2017 4:05 pm
Some of you will know, that I've been faffing about looking at getting a power meter, and after much teeth gnashing, wailing, moaning and indecision, I finally placed an order for an FSA Powerbox.
Given that my frame is a BB30 (42mm ID and 68mm shell width), and the crank is based around the FSA BB386EVO (46mm ID and 86.5mm shell width), I needed an adaptor.
No probs, as Bike24 (where I got the Powerbox from) had these 'adaptors/spacers' that essentially made up the width difference for bugger all, so I got them as well.
Sweet :D . Sort of. :?
Being a bit of a dork with a penchant for doing things right (in an engineering sense) saw the great opportunity to get a BB adaptor that screws together to try and eliminate one of the crappy things with press in BB's, and that is the dreaded creak. Haven't had too much of an issue, but I have an engineering background and ....
Anyway, lots more googling, and crap isn't there sooooooo many different standards with shell diameters, shell widths, crank diameters (Shimano at 24mm, Campagnolo at 25 & 30, SRAM, Rotor and some others at 30mm, then SRAM again with a 24/22mm hybrid, Easton, Verve U Turn with M30 - AAAARRRRGGGGHHHHHH :roll:
So, with some assistance, here is a list of suppliers that will do adaptors (and some that don't)
Kogel : do a Ceramic version for USD$199 + shipping
C-Bear : do a BB-BB30-386-R (ceramic bearings) for RRP of Euro 129, will sell direct or can get via Bike24
HSC - No options
Praxis Works - No Options
Wheels Mfg - No Options
Tri peak - do a Steel bearing (BB30-386-PKSBTF12) for A$178 delivered & a Ceramic (BB30-386-PKCBTF12) for A$225 delivered via eBay
Wishbone - do a Ceramic (BB30386) for A$178 delivered via eBay
FSA - Spacers for ~ $10 & a press together version
Token - Spacers for ~ $10
F1 Ceramics - No Options
Torq Tite (Enduro Bearings) - Euro250 + tools + shipping from Bike 24
BBInfinite - a press together version that costs USD$205 + shipping
[/sigh] :|
Wonder how long the cheap adaptors will last before I start burrowing down another rabbit hole .....
tcdev
Re: I HATE BB standards !!! Grrrrrr
Postby tcdev » Tue Dec 05, 2017 8:35 pm
You know the great thing about standards, right? That there's so many to choose from! :roll:
2015 Giant XTC Advanced 29er 1, Suunto Ambit2 Black
2011 Schwinn Sporterra Comp
MichaelB
Postby MichaelB » Tue Dec 05, 2017 9:28 pm
But they all think theirs is the right one !!!
The odd bit is that some of them don’t make some offerings despite the difference only being a beating size ?
Postby Duck! » Tue Dec 05, 2017 9:35 pm
The only real difference between BB30 and BB386 cranksets is the spindle length; both use a 30mm diameter spindle, 386 is just longer to suit the 90mm-wide (86mm shell + bearing cup flanges, 2mm each side) vs 68mm (with flush-fit bearings) for BB30. All you really need is an 11mm-wide x 30MM ID spacer on each side.
Propensity for creaking is very much related to the frame manufacturers' attention to tolerances (but press-fit in all its variations can take a long walk off a short pier). If the bike's been fine with the standard BB30 crank in it, it'll in all probability be just as fine with a spaced-out 386 crank in.
MichaelB
Postby MichaelB » Wed Dec 06, 2017 9:18 am
From your experience Duck, what seems to be the standard that is gaining most traction in the road bike scene ?
Postby Duck! » Wed Dec 06, 2017 11:11 am
The main one I see is BB86, which is the type designed around Shimano, SRAM GXP , FSA Mega Exo etc.
CaffeineAU
Postby CaffeineAU » Wed Dec 06, 2017 1:38 pm
Relevant...
Bentnose
Postby Bentnose » Wed Dec 06, 2017 7:37 pm
You've opened up a can of worms. I have a PF30 frame on my MTB and there is a distinct lack of 2x11 30mm cranks if I wanted to use them. I've just gone with a Wheels Manufacturing PF30 to outboard bottom bracket and will use Shimano cranks. I was perfectly happy with the English threaded bottom bracket standard.
No signature
Usernoname
Postby Usernoname » Wed Dec 06, 2017 8:10 pm
Bentnose wrote:You've opened up a can of worms. I have a PF30 frame on my MTB and there is a distinct lack of 2x11 30mm cranks if I wanted to use them. I've just gone with a Wheels Manufacturing PF30 to outboard bottom bracket and will use Shimano cranks. I was perfectly happy with the English threaded bottom bracket standard.
As were we all!
eeksll
Postby eeksll » Wed Dec 06, 2017 9:23 pm
yeah I am confused with all the BB stuff. I know my frame is a BB30, but pretty sure it has a BSA adapter on it. Ill need to double check this over the break to make sure its BSA, then I will know what crank to order if/when i buy one.
Postby Duck! » Wed Dec 06, 2017 11:40 pm
PF30 is just BB30 with the bearings assembled in cups (in the same manner as BB86) rather than direct-fit into the frame. Contrary to what the manufacturers will try to tell you, there's eff-all difference between 9, 10 & 11-sp. cranksets, so they're not particularly fussy about what the rest of the drivetrain is, so basically any BB30 MTB crankset is going to work. That said, BB30 didn't really get the same uptake through the industry for MTB as it did road, so options will be more limited.
As someone who deals with this stuff on a daily basis, I can assure you that English thread is far and away my favourite too!
Postby Duck! » Wed Dec 06, 2017 11:48 pm
eeksll wrote:yeah I am confused with all the BB stuff. I know my frame is a BB30, but pretty sure it has a BSA adapter on it. Ill need to double check this over the break to make sure its BSA, then I will know what crank to order if/when i buy one.
BSA adaptors are somewhat self-defeating..... Pressing in an adaptor to take a screwed-in bottom bracket is not really going to have the full security of a threaded system, because when you go to properly tighten the BB, there's nothing more than a wing & a prayer to stop the adaptor spinning in the frame..... Screw-together adaptors - basically two external-bearing housings with a threaded sleeve joining the two - are the best compromise.
queequeg
Postby queequeg » Thu Dec 07, 2017 12:55 am
Just got my BSA-30 BB today with my delivery. With all these different standards, I had completely missed that you could in fact fit a 30mm crank to a frame that only had a threaded BSA shell.
Saved me having to swap cranks all over the place, so the Rotor 3D+ with p2max spider that came off my Cervelo S5 will now happily go straight onto my Lynskey commuter bike, and I don't need to buy a new crank and power meter. Winning. The BB cups have plenty of clearance around the p2max spider, so I am all set.
Postby Duck! » Thu Dec 07, 2017 1:20 am
Another one of those possibly accidental hybrids, BSA 30 (as the title suggests, a bb30-esque 30mm-diameter spindle through an English [BSA]-threaded frame) is essentially a BB386 crank with a screw-in, external bearing bottom bracket.
MichaelB
Postby MichaelB » Thu Dec 07, 2017 7:45 am
For those that are interested, here is a good summary of the various standards from Paragon Machine works.
Oh, and from Wheels Manufacturing, BB Standards and crankset standards - the latter being very useful, as it gives bearing part numbers and ID/OD for their setup (except Campagnolo for some reason .....)
One that it does miss is the new, yes another one, M30 standard which has a 30mm dive side bearing and 28mm non-drive side one. The Praxis works adaptors work in a 68mm wide frame shell as well as others. Not sure what the spindle length is, but given it can fit in BB92 shell, it must be long.
Gotta laugh, the non-drive side is a proprietary :mrgreen: :roll: bearing
queequeg
Postby queequeg » Thu Dec 07, 2017 3:09 pm
MichaelB wrote:For those that are interested, here is a good summary of the various standards from Paragon Machine works.
You mean it's proprietary like SRAM GXP where the Non-Drive Side is 22mm instead of 24mm?
MichaelB
Postby MichaelB » Thu Dec 07, 2017 3:14 pm
AFAIK, that's still an OTS bearing. Still stoopid though.
MichaelB
Postby MichaelB » Wed Sep 19, 2018 10:54 am
Bit of a thread resurrection here, as it's better than creating a new one.
This article by CyclingTips Matt Wikstrom is probably one of the better summaries and listings, with appropriate graphics and tables on BB's around.
It isn't company specific, is clear, and even mentions the really weird standards.
I like the point that when choosing a bike, the BB and potential crank that you want to use now becomes an issue to investigate BEFORE you buy the bike !!
Some will also notice that I've been hunting to replace the FSA MegaEVO BB on my Kinesis, and gone through the rigmarole again, not so much from the BB side, but the damn tool side. :roll: :|
Postby Duck! » Wed Sep 19, 2018 2:04 pm
"Standard" is a very misused word. Not all BB systems/formats are standard.
Thoglette
Postby Thoglette » Wed Sep 19, 2018 5:28 pm
Usernoname wrote:
Bentnose wrote: I was perfectly happy with the English threaded bottom bracket standard.
As were we all!
As I still am!
Yes, call me a neo-luddite if you like, but I'm happy here under my rock. :D
Nobody
Postby Nobody » Wed Sep 19, 2018 7:19 pm
Thoglette wrote:
As were we all!
As I still am!
Yes. If it ain't broke...
uad782
Postby uad782 » Wed Sep 19, 2018 9:34 pm
I had one of these horrible megaEvo bb’s on my Lynskey. Luckily it uses a 68mm bsa standard. From memory I bought a park tool for about $30 that fit it. I got if from crc. Let me know if you want more details.
The bike now has an ultegra Bb!
MichaelB
Postby MichaelB » Fri Sep 28, 2018 3:28 pm
As a separate side note, there was a recommendation (of course, AFTER I'd ordered my Hope BB) that Hawk racing were quite good too.
Certainly not cheap (but then neither was the Hope), but the interesting thing was the 'independent friction test report' done by Friction Facts. meh.
The good thing to note is that the Hope unit tested well compared to others :lol:
Still, they have lots of options and another useful site.
Postby trailgumby » Sat Sep 29, 2018 8:41 pm
uad782 wrote:I had one of these horrible megaEvo bb’s on my Lynskey. Luckily it uses a 68mm bsa standard. From memory I bought a park tool for about $30 that fit it. I got if from crc. Let me know if you want more details.
FSA bottom brackets were junk 10 years ago when I first encountered them. You would think they'd have learned something over that peiod of time, but apparently not. :?
Paddles
Postby Paddles » Sun Sep 30, 2018 3:05 pm
I've just bought my first new bike in a long time and it has a FSA Gossamer Pro crankset with press fit bottom bracket as standard. It started creaking after only one ride then the creak went away after the next two rides and now it just has an occasional creak. So my question is, when it gets the better of me what are the replacement options if I want one that screws together in the middle and self aligns?
