Mavic Ksyrium Allroad Pro Disc wheelset | Thru Axle
DrFragnasty
Postby DrFragnasty » Tue Jun 26, 2018 12:43 am
I bought a 2nd hand in May this year and was led to believe I could convert the hubs from the current 9mm QR to 12mm thru axle by simply buying a 15mm to 12mm adapter and the thru-axles.
But I'm not so sure having pulled the hub apart (photo).
I can't find much in the way of info on this either from Mavic or Youtube or bloke Google.
I have a hunch it's not possible and I'm stuck with QR wheels.
Help.
10speedsemiracer
Re: Mavic Ksyrium Allroad Pro Disc wheelset | Thru Axle
Postby 10speedsemiracer » Tue Jun 26, 2018 2:20 pm
Are they Ksyrium Pro Disc or Allroad Pro Disc wheels. Mavic telling me they're different wheels.
They do carry adapter kits but need to know which wheelset you have. Alternatively you can drop into one of the Mavic dealers and get it sorted there. CycleWorks in Box Hill (Melb) are Mavic dealers and I've dealt with them before and found them really good.
Where are you based?
I have also read that on some of the Ksyrium range, only the front can be converted to TA, if the rear was purchased as a QR so definitely need to know which you have,
Mmm, SunTour
