Help me find the perfect ladies commuter frame
cram
Postby cram » Fri Jul 06, 2018 11:16 am
How hard can it be?
Looking for frame to build a ladies comfort/commuter. What I need in a frame:
- step through
- at least front suspension (and rear if possible),
- internal hub gears (nuvinci 380) without chain tensioner (i.e. sliding/horizontal drop-outs)
- 700c wheel spacing.
- front and rear disc brakes.
Will also become electric with a mid mount kit.
She is currently riding a Reisse and Muller e-bike but it is a large and she could use a small. And she wants to go faster than the Bosch allows (yes I know I can mod the Bosch - may still go down that route)...
Re: Help me find the perfect ladies commuter frame
Postby find_bruce » Fri Jul 06, 2018 11:26 am
Not possible to have both rear suspension & no chain tensioner - no suspension has a perfect arc around the bottom bracket
Velt
Postby Velt » Fri Jul 06, 2018 11:34 am
Why do you want front suspension? She might feel faster on one without
Thoglette
Re: Help me find the perfect ladies e-bike disc & suspension frame
Postby Thoglette » Fri Jul 06, 2018 2:21 pm
cram wrote:- at least front suspension (and rear if possible),
Brooks B67S That's a sprung saddle. And add some fatter tyres.
cram wrote:- 700c wheel spacing.
What exactly do you mean? I'm presuming 700C with 135 rear and 100 front drop out spacing
Why do you need 700C? Especially as you need a small frame (and fat tyres). Mix these with 700C wheels and you end up with a badly compromised geometry.
cram wrote:How hard can it be?
Well, you didn't specify carbon or titanium :D
Seriously, you are asking for a fair bit. Probably the closest I can think of is a Rivendell Clem-L with a new (disc) front fork. (There are adapters to mount discs on the rear of non-disc frames if you must)
Maybe the best move would be to modify an existing e-bike, like the EARTH ui-5 or e-bikes ui-ryder, which tick most of your boxes ???
