I love aerobars
I love aerobars
Postby AndrewBurns » Thu Aug 01, 2013 2:41 pm
I've only ridden the Calga TT twice on a normal road bike with somewhat aero wheels however I've been itching to try out some clip-on aero bars to see how much time I can shave off.
Luckily I was at Steve Hogg getting a slight adjustment to the fit on my bikes the other day and I noticed he had some clip-on bars hanging up so I asked him if he could fit some up for me and he obliged. He set up the bars such that my body position was exactly the same as when I was on the drops except with my arms out forward and tucked in so my frontal area is greatly reduced. This means that I'm already well adapted to the position and I'm not going to have to re-learn anything or injure myself from being too stretched out etc. My drops position is already quite low down so I think my tuck is about as good as I could currently do without improving on my flexibility anyway.
I took them for my first try today, I've read a bit saying that they take some getting used to and are very twitchy so I was a little concerned but as it turns out I found the position really comfortable and stable after about 15 mins. I don't know if this is because the position of the rest of my body is the same as I'm used to in the drops but after some initial zig-zaging I had no problems staying in the tuck even on rough roads and around corners etc.
Suffice it to say I love them and can definitely see improvement, I went out to akuna bay and back along mona vale road which has long relatively flat sections and some rolling hills, above about 35 kph I find I get a lot more stable and on the flat I find it almost easy to just cruise along at ~45 kph. It's a little annoying to move my right hand to shift but over the ride I probably spent about an hour at least down in the tuck and I'd say I'm pretty used to it by now. It was a bit of a clenching experience going down my first decent hill at ~70 in the aero tuck with my hands so far from the brakes but it ended up being a non-event.
So all geared up for Calga this Sunday!
- rpmspinman
Re: I love aerobars
Postby rpmspinman » Thu Aug 01, 2013 5:14 pm
Shav
My Bikes:
2011 Kona Dew Plus (commuter)
2012 Focus Cayo 2.0 (road)
2015 Cervelo S5 VWD
Re: I love aerobars
Postby AndrewBurns » Thu Aug 01, 2013 5:32 pm
- rpmspinman
Re: I love aerobars
Postby rpmspinman » Thu Aug 01, 2013 6:19 pm
Shav
My Bikes:
2015 Cervelo S5 VWD
Re: I love aerobars
Postby AndrewBurns » Thu Aug 01, 2013 6:27 pm
- rpmspinman
Re: I love aerobars
Postby rpmspinman » Fri Aug 02, 2013 11:52 am
sounds perfect. What brand did you buy, and what configuration? I know there are 3 or 4 types of tri bars you can buy with different configurations. Just wondering what is better I guess.AndrewBurns wrote:My bars are already as low as my back and neck can handle (also as far as my frame allows coincidently) but I didn't need to change anything otherwise, just clip the bars on. They're adjusted specifically so that when I transfer from the drops to the aero bars my upper body and torso don't move a mm, I just have my arms tucked in instead of down.
Shav
My Bikes:
2015 Cervelo S5 VWD
Re: I love aerobars
Postby AndrewBurns » Fri Aug 02, 2013 1:18 pm
Steve mentioned that they were the cheapest ones he sells but also the most adjustable which is why he recommended them. Mine are pretty short in my config so he cut the spare off the back (even then my knees hit the arm pads when out of the saddle).
Re: I love aerobars
Postby DoubleSpeeded » Fri Aug 02, 2013 10:20 pm
well TT and Tri bikes have slightly different frames.. so it might differ if its a road bike.AndrewBurns wrote:My bars are already as low as my back and neck can handle (also as far as my frame allows coincidently) but I didn't need to change anything otherwise, just clip the bars on. They're adjusted specifically so that when I transfer from the drops to the aero bars my upper body and torso don't move a mm, I just have my arms tucked in instead of down.
also ive read an article where it was talking about the aero position.
When leaning too low, can most likely benefit aerodynamics but can also reduce your power output.. due to the hip angle etc. And something about how some certain Time Trailists have leaned to the extent where it would be impossible for a regular person to achieve maximum output..
i guess thats why theres places that charge $350 for professional bike fitting.. seems easy but they actually assess your body movements and joint capabilities etc...
i suppose everything has a little science to it.
- ldrcycles
Re: I love aerobars
Postby ldrcycles » Fri Aug 02, 2013 11:06 pm
Re: I love aerobars
Postby AndrewBurns » Sun Aug 04, 2013 11:28 am
Just rode the Calga TT and I'm disappointed to be honest, didn't get a PB even with the new aero bars. Of course it's nothing to do with the bike and more me being off form (recovering from a cold, not riding as much as I should be) and it was pretty windy today which I find makes it harder.
Re: I love aerobars
Postby DoubleSpeeded » Sun Aug 04, 2013 1:06 pm
thats a neat set up.AndrewBurns wrote:Pictures:
alloy?
can the arm rests come together any closer? Apparently your elbows closer can benefit more on the aerodynamic side.
Well thats like me then, i dont spend alot of time in the aero position... i usually train with the Hybrid MTB...
And on the weekend when i take the TT bike out.. the position seem to focus on the hamstrings for me... feeling lotsa build up in the muscles and fatigue.
- toolonglegs
Re: I love aerobars
Postby toolonglegs » Sun Aug 04, 2013 3:28 pm
I found clip ons made a bit of difference but not that bigger difference from riding in the drops. The problem is clip ons sit above your normal bar height, so while they reduce your frontal area a bit, your head still sits up above the shoulders quite a bit.AndrewBurns wrote: Just rode the Calga TT and I'm disappointed to be honest, didn't get a PB even with the new aero bars. Of course it's nothing to do with the bike and more me being off form (recovering from a cold, not riding as much as I should be) and it was pretty windy today which I find makes it harder.
Re: I love aerobars
Postby dalai47 » Sun Aug 04, 2013 11:49 pm
Depends on the individual...DoubleSpeeded wrote:can the arm rests come together any closer? Apparently your elbows closer can benefit more on the aerodynamic side.
Re: I love aerobars
Postby DoubleSpeeded » Tue Aug 06, 2013 4:50 pm
i guess its like aero helmets isnt it?... depending on the weather.dalai47 wrote:Depends on the individual...DoubleSpeeded wrote:can the arm rests come together any closer? Apparently your elbows closer can benefit more on the aerodynamic side.
if the whole path has strong cross winds... it may even render the thing useless.
- rpmspinman
Re: I love aerobars
Postby rpmspinman » Thu Aug 22, 2013 5:49 pm
Shav
My Bikes:
2015 Cervelo S5 VWD
- Xplora
Re: I love aerobars
Postby Xplora » Wed Sep 11, 2013 5:38 pm
Surprised you had the guts to descend at 70 on the bars, I would NEVER do that. Ever. Done quite a bit of road bike TT bars stuff on the commutes etc, you just get more and more used to the position. A lot of the balance issues relate to core stability. You just don't have to extend onto the bars in a normal situation, so you lack a reference point. You'll get there. Regarding hitting the elbow pads, if they are REMOTELY effective, you'll bump them constantly. I actually ended up climbing differently (a lot more weight backward of the BB) to stop hitting them. I doubt its an efficient way of climbing - I wouldn't do bellbird like that LOL
- Duck!
Re: I love aerobars
Postby Duck! » Sat Sep 14, 2013 11:19 am
I'd say it's more to do with the rider's build than weather considerations. A rider with broader shoulders will need the elbows further apart than a narrower-shouldered rider. Pulling the elbows in rotates the shoulders forward as well, which restricts the expansion capability of the ribcage. Restricting the expansion of the ribs reduces aerobic efficiency, because you're not able to take as big breaths. So elbow position is finding the compromise between aerodynamic efficiency, without too badly affecting aerobic efficiency.DoubleSpeeded wrote:i guess its like aero helmets isnt it?... depending on the weather.dalai47 wrote:Depends on the individual...DoubleSpeeded wrote:can the arm rests come together any closer? Apparently your elbows closer can benefit more on the aerodynamic side.
- mikesbytes
Re: I love aerobars
Postby mikesbytes » Mon Sep 16, 2013 11:06 am
Andrew, I've ridden Calga 4 times, twice in 2011 on a road bike with clip-ons and twice in 2013 on a TT bike. The first outing on the TT bike didn't beat my 2011 PB, but I did beat it on the second occasion. I'm guessing that in your case I'd guess it was not enough riding with clipon's and/or different atmospheric conditions. Suspect that next time you go you will break your PB
- Xplora
Re: I love aerobars
Postby Xplora » Mon Sep 16, 2013 11:19 am
- mikesbytes
Re: I love aerobars
Postby mikesbytes » Mon Sep 16, 2013 1:24 pm
I do 70k on blood hill at Calga
- Xplora
- mikesbytes
Re: I love aerobars
Postby mikesbytes » Mon Sep 16, 2013 8:12 pm
Anyway back on topic. Looking at the photo, I'm wondering if Andrew's handlbars are a little too high. I'm trying to image Andrew on them (I've met him). Andrew, perhaps a couple of pics of you on the bike would help us armchair experts
- toolonglegs
Re: I love aerobars
Postby toolonglegs » Mon Sep 16, 2013 8:47 pm
- Xplora
Re: I love aerobars
Postby Xplora » Mon Sep 16, 2013 8:55 pm
- All times are UTC+11:00
