How far should you be able to turn your front wheel?
Postby Alex Sniga » Mon Jul 21, 2008 9:49 am
I got my new roadie recently, and I noticed that when I turn my front wheel to the right it stops approx at 45 degrees (while I can turn to -90 degrees to the left easily). The reason it stops is because the brake cable is too short and when I turn my wheel, the cable stops it from going further. If I push a little harder the cable activates brakes at the back.
I went back to LBS, they said it's nothing to worry about, as I never gonna be turning my front whell that far while I'm riding, and that it will change once the cable stretches, and they also loosened the brakes at the back. But the thing is that if I'm walking next to my bike I may want to take a sharp turn (i.e. when there is not much space to move), which I do indoors, and that's how I noticed this.
So my question is - is it common to have something like that? As it does not seem to be right. The brake cable shouldn't be whatever stops the front wheel turning left/right (and what's more - pulling on the brakes while you do it). But being myself pretty much a n00b in all this, I didn't feel like arguing in the LBS.
Postby MountGower » Mon Jul 21, 2008 9:57 am
- mikesbytes
Postby mikesbytes » Mon Jul 21, 2008 12:09 pm
- DavidH
Postby DavidH » Mon Jul 21, 2008 12:42 pm
If the bars can only turn 45 degrees I think that this is a definite indicator that the brake cable has been installed too short. And the remedy (new cable) willl require removing the bar tape. This should definitely be done by the LBS IMO.
- jasimon
- RainForeverRain
Postby RainForeverRain » Mon Jul 21, 2008 1:38 pm
Looks like a clear product defect to me.
Postby Alex Sniga » Mon Jul 21, 2008 2:41 pm
During lunchbreak I went to Clarence St to have a look at what the cable looks like on other bikes, and pretty much all of them had a decent curve, which means you can turn the handlebar without stretching the cable. Mine is almost straight line from handlebar to the frame. Also the bar tape looks stretched where the cable coming out from being pulled all the time.
Postby thomas_cho » Mon Jul 21, 2008 2:58 pm
The cable has been cut too short, in the case of an emergency you may need to rotate your wheel more than 45 degrees.
Postby Alex Sniga » Mon Jul 21, 2008 3:13 pm
I guess, the reason they thought it's a good solution is because the way I explained my problem to them. Basically, I said something along (while demonstrating the problem) "do you think this cable is too short? When I turn the wheel the brakes at the back are activated". (arghh, sometimes I really have difficulty making myself clear). I didn't really worry that much about the brakes, just tried to use it as a proof that the cable is too short(as it shouldn't be like that on a properly set up bike).thomas_cho wrote:I am surprised that the bike shop thinks that increasing the pad distance to the rim solves your problem. Do not let them treat you like a noob.
Also the shopassistant probably wasn't very experienced and may be had "she'll be right" attitude.
- Sveky
Postby Sveky » Mon Jul 21, 2008 3:21 pm
The mechanic who set it up is clearly an idiot.
- toolonglegs
Postby toolonglegs » Mon Jul 21, 2008 3:24 pm
But do agree that it probably wont make any difference while riding if it only happens when you tur the bars 45% or more.
- rustguard
- Mulger bill
Postby Mulger bill » Mon Jul 21, 2008 9:13 pm
Shaun
Postby CoffeeNut » Sun Jul 27, 2008 9:44 pm
Postby Alex Sniga » Mon Jul 28, 2008 1:37 pm
The stem was pointing up before, now it's pointing down (or pretty much horizontal). Is there any issue with that, or can they be turned any way?
While riding to work today haven't noticed much difference (except that I haven't tightened it well enough and when I hit a bump the handlebar got pushed closer to the ground, it's sorta rotated with a horribly sounding squeak - I thought I broke a wheel or something at first, the speed was around 50kph too).
- peter
Postby peter » Mon Jul 28, 2008 3:38 pm
No issue at all as long as you feel comfortable. It is actually designed to be able to flip, it gives you 2 riding positions.Alex Sniga wrote:The stem was pointing up before, now it's pointing down (or pretty much horizontal). Is there any issue with that, or can they be turned any way?
Make sure to tighten them, but not over tighten. Some stems have torque rating printed on them (Nm or lbin), best to get a torque wrench. It's important to alternate between the bolts, i.e. take turns to tighten each bolt a little bit at a time.While riding to work today haven't noticed much difference (except that I haven't tightened it well enough and when I hit a bump the handlebar got pushed closer to the ground, it's sorta rotated with a horribly sounding squeak - I thought I broke a wheel or something at first, the speed was around 50kph too).
- Verbs & Nouns
Postby Verbs & Nouns » Wed Jul 30, 2008 5:10 pm
Problem solved.
(Or get a singlespeed with a rear coaster brake).
Ten Grand wrote:Goddamnit baby, this is soul... What's wrong with you?
- m@
Postby m@ » Thu Jul 31, 2008 9:24 am
Is this on the 1.9? If so, I'd be going back to the shop and asking their advice - you've laid down a fair amount of cash so they should be accommodating!theoddbot wrote:If I have my cranks horizontal and turn the front wheel it hits the front of my shoe. It's not really a problem except for starting, but I can't figure out any way to fix it.
Any ideas or should I just ignore it?
Alternatively, I guess you could move your cleats forward on your shoes, or put on a smaller crankset or longer headstem - but any/all of these are likely to adversely affect the fit of your bike...
- jasimon
Postby jasimon » Thu Jul 31, 2008 9:29 am
Some bikes are like that. My CRX2 creates that problem as well. Sheldon Brown doesn't think it's a problem (Look at the entry on Toe Clip Overlap).theoddbot wrote:If I have my cranks horizontal and turn the front wheel it hits the front of my shoe. It's not really a problem except for starting, but I can't figure out any way to fix it.
Postby theoddbot » Thu Jul 31, 2008 10:51 am
No it's a Masi Vincere.m@ wrote: Is this on the 1.9? If so, I'd be going back to the shop and asking their advice - you've laid down a fair amount of cash so they should be accommodating!
The cleats are already in the front holes. A smaller set of cranks would probably do the trick but I'm not too worried.m@ wrote: Alternatively, I guess you could move your cleats forward on your shoes, or put on a smaller crankset or longer headstem - but any/all of these are likely to adversely affect the fit of your bike...
As per the post below, I'm happy enough to ignore it, especially if Sheldon says so
- Verbs & Nouns
Postby Verbs & Nouns » Thu Jul 31, 2008 10:58 am
And I thought this was sarcasm.theoddbot wrote:If I have my cranks horizontal and turn the front wheel it hits the front of my shoe. It's not really a problem except for starting, but I can't figure out any way to fix it.
