MTB rims that suit ONLY Presta valves? -
Postby DoubleSpeeded » Sat Aug 10, 2013 11:38 pm
ive just noticed my MTB rim only takes Presta as the schrader is too wide.
i dont think drilling it out a bit wider with a drill bit to suit a schader is a good idea.
now im limited to choices?
Re: MTB rims that suit ONLY Presta valves? -
Postby }SkOrPn--7 » Sat Aug 10, 2013 11:42 pm
Ricky
- ozdavo
Postby ozdavo » Sat Aug 10, 2013 11:44 pm
Unless their carbon, why not?DoubleSpeeded wrote: i dont think drilling it out a bit wider with a drill bit to suit a schader is a good idea.
... and by limited choices, you mean you can't use schrader valves tubes???... But it will be easier to go tubeless
Sent from my iThingy using Tapatalk
- bychosis
Postby bychosis » Sun Aug 11, 2013 8:51 am
Postby DoubleSpeeded » Sun Aug 11, 2013 9:47 am
}SkOrPn--7 wrote:I drill out all my rims to suit schrader no issue just use drills in steps to you get to the hole size you need or buy a step drill for 20 clams.
Ricky
right... yeh it is aluminium with Disc brakes...ozdavo wrote:Unless their carbon, why not?DoubleSpeeded wrote: i dont think drilling it out a bit wider with a drill bit to suit a schader is a good idea.
ill keeo it in mind
however, srilling may impede the resale of the rim right?
why makes you say they are better?bychosis wrote:Just stick with Presta valves, they are better anyway. And if its about using a car compressor for a pump just grab an adaptor and leave it on as a valve cap.
i have gotten used to presta valves by now as it seems that they are getting quite common...
i was just curious as i am out of 29" spare tubes (since i had a flat the other day)
and ive got one lying around in the garage but it had a schrader valve.
- ozdavo
Postby ozdavo » Sun Aug 11, 2013 12:25 pm
Postby DoubleSpeeded » Sun Aug 11, 2013 3:39 pm
yeh?!ozdavo wrote:Just so you know, you can use 26" tubes on a 29er, they easily stretch and I've had no problems in about 12 months of use.
didnt know that one
ill keep it in mind
- Duck!
Postby Duck! » Sun Aug 11, 2013 5:35 pm
Postby DoubleSpeeded » Sun Aug 11, 2013 5:47 pm
trueDuck! wrote:You do need to be super careful to avoid pinching the tube when you fit the tyre though. Having it stretched that tight around the rim makes it a lot more difficult to tuck inside the tyre properly.
but obviously the most sensible thing is to purchase the right tube for the right application
but i guess what he meant was just in worse case scenario and desperately needed something
- Duck!
Postby Duck! » Sun Aug 11, 2013 5:51 pm
- Dragster1
Postby Dragster1 » Sun Aug 11, 2013 5:57 pm
Postby DoubleSpeeded » Sun Aug 11, 2013 6:08 pm
Dragster1 wrote:Too easy you can buy adaptors http://www.ebay.com.au/itm/Allow-Shrade ... 0805439933 I use rubber O-rings over 1000kms no problems. I used a 2.1 x 26 tube on a 26 x 2.35 tyre and it split at the seam about 6 months later.
1000km with no punchture?
your doing well man!
hang on hang on...wont work...
your link contents says "Allow Shrader Rims to Accept Presta Valve Converter Adaptor"
mines actually the other way around....
Presta Rim... fitting a Shcrader valve.... which as mentioned above... will require a bigger hole. which can only be done by drilling.
- Dragster1
Postby Dragster1 » Sun Aug 11, 2013 8:09 pm
Drill them and if you want to go back to presta use the adaptor it allows you full option of shrader or presta tubes. Just take your time drilling, use a new and sharp drill bit or take it to a good LBS. You can buy blank rims and drill them to what ever you want, spoke holes and all. $5 for a Presta tube is much easierDoubleSpeeded wrote:Dragster1 wrote:Too easy you can buy adaptors http://www.ebay.com.au/itm/Allow-Shrade ... 0805439933 I use rubber O-rings over 1000kms no problems. I used a 2.1 x 26 tube on a 26 x 2.35 tyre and it split at the seam about 6 months later.
Postby DoubleSpeeded » Sun Aug 11, 2013 9:44 pm
$5 a 29er tube?Dragster1 wrote:Drill them and if you want to go back to presta use the adaptor it allows you full option of shrader or presta tubes. Just take your time drilling, use a new and sharp drill bit or take it to a good LBS. You can buy blank rims and drill them to what ever you want, spoke holes and all. $5 for a Presta tube is much easierDoubleSpeeded wrote:Dragster1 wrote:Too easy you can buy adaptors http://www.ebay.com.au/itm/Allow-Shrade ... 0805439933 I use rubber O-rings over 1000kms no problems. I used a 2.1 x 26 tube on a 26 x 2.35 tyre and it split at the seam about 6 months later.
wow.. once again your doing well! lol
ive just purchased some online, Continental 29er $10 i think.
(unless you were thinking of 26" tube, which i find them cheaper than 29er)
- Dragster1
Postby Dragster1 » Sun Aug 11, 2013 10:21 pm
Postby DoubleSpeeded » Sun Aug 11, 2013 10:27 pm
Dragster1 wrote:http://www.pushys.com.au/xtech-29-x-2-3 ... -tube.html even Kmart has them cheaper than $10
LOL now, you tell me?!
too late now.
normally i overlook Pushy's as the prices are significantly higher than other stores...on the items I've wanted to purchase in the past.
(hopefully i didnt offend anyone by saying that... )
i guess its the brand name Continental is why its costing almost, double.
ill remember for next time.
- Duck!
Postby Duck! » Sun Aug 11, 2013 10:27 pm
Given that your other bike also uses Presta valves, it makes sense re; pump attachments for both to be the same.
Postby DoubleSpeeded » Sun Aug 11, 2013 11:11 pm
Duck! wrote:Where's the problem? The vast majority of rims are drilled for Presta; it tends to be only the cheaper ones that are drilled for Schraeder valves.
Hi duck
Yeah I kinda noticed that.
Department store bikes generally have Schrader valves on cheap rims.
Yeh both MTB and TT have presta rims
But pumping Schrader valve isn't a problem as I've got a Merida aluminium Floor pump, the pump attachment pumps both types.
I'll stick to presta
- Dragster1
Postby Dragster1 » Sun Aug 11, 2013 11:27 pm
Lol! No offence taken man, I know you can get bum steered on these sites sometimes, only trying to help with what I know. I have Maxxis overdrive tyres with Kevlar belts that work a treat for road riding, Touch wood no flats so far, they are heavy and running tubes dosent help the weight.DoubleSpeeded wrote:Dragster1 wrote:http://www.pushys.com.au/xtech-29-x-2-3 ... -tube.html even Kmart has them cheaper than $10
too late now.
Postby DoubleSpeeded » Mon Aug 12, 2013 8:52 am
Yeh sometimes I wish local stores would be priced better. To support local industry rather than purchasing from foreign UK.Dragster1 wrote: Lol! No offence taken man, I know you can get bum steered on these sites sometimes, only trying to help with what I know. I have Maxxis overdrive tyres with Kevlar belts that work a treat for road riding, Touch wood no flats so far, they are heavy and running tubes dosent help the weight.
The original tyres were 29er Maxxis Cross Mark kevlar off road folding tyres. They were awsome.
But just too knobby for paved surfaces.
Since converting to a wirebead tyre from Kevlar.. I felt the difference. In weight and seemingly .a . less quality feel with wire
- barefoot
Postby barefoot » Mon Aug 12, 2013 10:17 am
Rims have no resale value anyway. They're consumable. You're much more likely to destroy the rim in service than sell it. If I'm buying a second hand wheelset, I'm only interested in whether the rims have buckles or dents or cracks. The size of the hole doesn't enter into it.DoubleSpeeded wrote:however, srilling may impede the resale of the rim right?
I've always preferred Schrader valves. Partly because they're more robust (ripping the valve off a tube happens sometimes wtih Presta... never with Schrader), partly because it gives me the option of using any pump, anywhere. Yes, servo air lines are dodgy, but they do the job. So I've drilled out lots and lots of rims.
Now deeper section rims are becoming standard, some of them are too deep for a Schrader valve to go through. So I've reluctantly switched to a new standard - long-stem Presta for all my 700c wheels, and Schrader for all my 26" wheels (which are all fairly shallow section, so far).
tim
Postby rkelsen » Mon Aug 12, 2013 11:51 am
Presta valves are better at holding pressure, even in lower pressure tyres.DoubleSpeeded wrote:why makes you say they are better?
That only happens if you have the wrong kind of pump. It can't happen with a good quality pump like the Lezyne Floor Drive, due to the design of the chuck.barefoot wrote:(ripping the valve off a tube happens sometimes wtih Presta... never with Schrader)
- bychosis
Postby bychosis » Mon Aug 12, 2013 1:23 pm
I knew there was a real reason Apparently they are also easier to pump up as once the pump pressure is above the tube pressure the valve is open, you don't need to overcome the pressure of the spring valve in the Schrader valve. I also like the locking ring on presta that enables me to push the pump chuck on without having to hold the valve in place by pushing on the tyre.rkelsen wrote:Presta valves are better at holding pressure, even in lower pressure tyres.DoubleSpeeded wrote:why makes you say they are better?
- barefoot
Postby barefoot » Mon Aug 12, 2013 2:26 pm
Better at holding pressure is a new one, and I thought I'd heard most of the myths of why Presta are superior.rkelsen wrote:Presta valves are better at holding pressure, even in lower pressure tyres.DoubleSpeeded wrote:why makes you say they are better?
i have gotten used to presta valves by now as it seems that they are getting quite common...That only happens if you have the wrong kind of pump. It can't happen with a good quality pump like the Lezyne Floor Drive, due to the design of the chuck.barefoot wrote:(ripping the valve off a tube happens sometimes wtih Presta... never with Schrader)
I've never had a problem with Schrader valves failing to hold pressure. Neither have about a billion car drivers. Air gets through the rubber tube faster than it gets through either type of valve.
I know it's possible (and not _all_ that difficult) to not rip Presta valves off, especially with a decent pump. I now use a RoadMorph or my track pump, and haven't ripped one off in years (although I definitely ripped a few off with my venerable Blackburn Mammoth Mtn before it finally died).
My point remains - you have to be a little bit careful with Presta, because it is possible to damage them with rough handling. You can handle Schrader as rough as you like, and I'm yet to find anybody who has managed to rip a valve off the tube.
Postby rkelsen » Mon Aug 12, 2013 3:32 pm
I didn't say that Schraeder valves don't hold pressure... Just that Presta valves are better at it.barefoot wrote:I've never had a problem with Schrader valves failing to hold pressure. Neither have about a billion car drivers.
Car tyres are "super low pressure." You're comparing apples & oranges.
If you don't believe me, why not try an experiment? Inflate one of each and see which deflates the fastest.barefoot wrote:Air gets through the rubber tube faster than it gets through either type of valve.
My own personal experience with both has proven that Presta valves are better at holding air. I'm sure I'm not alone here.
The Lezyne pump I mentioned has a screw-on chuck. With this pump, it is impossible to rip a Presta valve out. I bought it specifically because I was having the same problem as you.barefoot wrote:I know it's possible (and not _all_ that difficult) to not rip Presta valves off, especially with a decent pump.
Users browsing this forum: The Great Boffo
