6700 GS max sproket
6700 GS max sproket
Postby warthog1 » Sun Aug 11, 2013 7:55 pm
5700 GS
Model Number RD-5700
Series 105
Cassette Compatibility 10-speed
Maximum Sprocket 28T
Minimum Sprocket 11T
Maximum Front Difference 16T
Total Capacity 39T
This is the same max sprocket listed for the short cage (ultegra is the same), just a slightly bigger total capacity
5700 SS
Series 105
Total Capacity 33T
I was hoping if I wound the b screw out a bit this derailleur would run the 32. Has anyone tried this or is there a MTB derailleur I can use?
- Duck!
Re: 6700 GS max sproket
Postby Duck! » Sun Aug 11, 2013 8:07 pm
However! RD-5701 and RD6700-A have a 32T big sprocket capability, although even with a GS there's not enough wrap to handle a triple with the 32. You can run a SS with 32, but it is a bit sensitive to chainstay length in order to get just the right amount of tension in the small ring/small sprocket combo, and preferably not a compact crank (bigger front difference than a standard).
Side note: in general terms it's not the cage length that determines the max sprocket capability, it's the length of the upper body that does, 'cos that determines the clearance below the cassette. The cage length just wraps the "spare" chain that's required to cover the gear range. Obviously a triple has the increased range between its extremes, so a longer cage is needed to take all the slack.
Postby warthog1 » Sun Aug 11, 2013 8:37 pm
Thanks Duck, I have a 130mm BCD crank with 53/39 and run a 28/11 sram cassette with a 6700 ss derailleur. It shifts well and I can climb everything I have come across with that gearing.Duck! wrote:Your specs there are correct, RD-5700 & 6700 have a max. sprocket of 28T. The longer cage of the GS version gives the greater chain wrap required to run a triple up front.
However I have decided to do the ACE250 and would like a bail out gear in case the legs are failing after high k's. The sram 12/32 looks good;
12-32: 12-13-14-15-17-19-22-25-28-32
Currently the chain is fairly tight on the 53-28 and not far off hitting the cage/upper jockey wheel on the 39-11. I know that cross chaining like that isn't ideal, and almost never run the 39-11 gear. The 53-28 does come in handy to stay in the big ring on some of the rolling hills and the final part of a climb following a false flat that I do regularly .
I cant see myself using the 53-32 but I dont think the short cage looks like it will handle the range.
It seems you are saying that either cage length will handle a 32 tooth rear sprocket? Will a medium cage derailleur handle it better or it matters not?
- Duck!
Postby Duck! » Sun Aug 11, 2013 8:49 pm
Postby warthog1 » Sun Aug 11, 2013 11:38 pm
Postby scirocco » Mon Aug 12, 2013 6:06 pm
If your bike has a short derailleur hanger it may be very hard to avoid the derailleur pulley hitting the 32 tooth cog, even if the chain wrap is okay, even with a medium cage RD. I have one bike where the only solution is a MTB derailleur. Shimano 9-speed MTB derailleurs have the correct ratio to work with 10-speed road shifters. This is kind of the standard method that is used by people who want to run 34 or 36 tooth rear cogs. For a 32 tooth you may get away with the road RD, can't do any harm to try it and see.warthog1 wrote:... or is there a MTB derailleur I can use?
Postby warthog1 » Mon Aug 12, 2013 6:41 pm
Postby warthog1 » Tue Aug 13, 2013 3:52 pm
Can I confirm that a 9sp Deore will work?
It's cheaper anyway.
Postby mitzikatzi » Tue Aug 13, 2013 4:06 pm
I think you can get away with a "medium" cage on a standard road double set up. (52-39 = 13, 32-11=21, 21+13=34, GS is 35) but not a compact.
Postby scirocco » Tue Aug 13, 2013 11:32 pm
Yes, or alternatively c r c also carry the slightly lighter and higher spec Deore XT version, which is the one I have successfully used on a road bike with a 34T rear cog (for climbing stupidly long and steep mountains in Italy). Deore XT
Setup and adjustment was a bit more finicky than with the standard 6700 RD - it was hard to get it shifting sweetly at both ends of the cassette but it got there in the end.
Postby warthog1 » Wed Aug 14, 2013 8:36 am
Postby Arlberg » Wed Aug 14, 2013 9:42 pm
- Duck!
Postby Duck! » Wed Aug 14, 2013 9:46 pm
Postby warthog1 » Tue Aug 20, 2013 7:56 pm
12-13-14-15-17-19-21-24-27-30.
That looks like it will fit the bill nicely. Small steps and a 39-30 will be low enough.
This should almost certainly work with my 6700
SS derailleur if I put a new chain on 1 or 2 links longer at the same time:?:
Here is the derailleur in the 39/28 currently
The b screw had a fair bit to go
- Duck!
Postby Duck! » Tue Aug 20, 2013 8:14 pm
And on that note, it's not possible to lengthen a chain by one (or any odd number) link, because you'll end up with two ends the same and you won't be able to join it, unless that link is a "half-link" (stepped so it's half inner & half outer). You have to add minimum two links, one inner and one outer.
- singlespeedscott
Postby singlespeedscott » Tue Aug 20, 2013 8:23 pm
It might work but make sure you don't try 53x30. Your Derailleur may have issues.warthog1 wrote:I have been thinking further on this and see that shimano do a 30-12 ultegra cassette:
6700 GS max sproket
Postby warthog1 » Tue Aug 20, 2013 8:35 pm
Chain looks pretty tight to me in the 53/28?
Here is another shot that shows also where the b screw is at
Does that look like it will run a 30-12 with a longer chain?
Here it is in the 39/11 which I never use.
Looks like it will run out of range in that gear with a longer chain though? As long as it will run a 39/12 I'll be happy.
I guess a bit of b screw can take up a little slack at a pinch? Not that I have any experience there, just postulating.
- Duck!
Postby Duck! » Tue Aug 20, 2013 9:09 pm
Postby warthog1 » Tue Aug 20, 2013 9:19 pm
No worries, thanks.Duck! wrote:I reckon one pair of links will do the trick. After all, you're only increasing the overall chain wrap by one tooth/link - sure you've got a 2-tooth increase in the big sprocket, but you're getting some of it back by changing from the 11 to a 12 at the other end. Looking at the first pic, you're not going to get the 53/30 gear (which you should avoid anyway) without adding a little bit.
I'm happy with that as a cheap way out.
- biker jk
Postby biker jk » Tue Aug 20, 2013 9:41 pm
- Duck!
Postby Duck! » Tue Aug 20, 2013 9:50 pm
Give it a clean too, will ya!
Postby warthog1 » Wed Aug 21, 2013 11:09 am
.biker jk wrote:A friend of mine fitted an Ultegra 12-30 cassette with no problem clearing the guide pulley. A chain length calculator suggests you may not need extra links (it suggests 54 links should be fine with 40.6cm chain stay length). Your picture of the derailleur cage in 53-28 also suggests you may not need extra links in the chain.
The chain in that pic has a few k km on it. I guess if I start longer with the replacement I can always shorten it if needed.
Postby warthog1 » Wed Aug 21, 2013 11:15 am
I have used one of those chain cleaner goers in the past but it seemed to make the driveline rough and noisy until several lubes later. I reckon it washed all the lube out of the rollers and replaced it with solvent?
Think I used turps. Could have been the wrong stuff.
Postby warthog1 » Mon Nov 25, 2013 6:01 pm
30-12 runs fine, I didn't even need to touch the b screw on the original 6700 short cage derailleur
Postby ball bearing » Mon Dec 02, 2013 8:07 am
- All times are UTC+11:00
