If there was ever a need for a "like" button, spurious as they are...HAKS wrote:I'll check on the weekend for you when i do the swap.Xplora wrote:Want to know if the 6800 crank nondriveside is compatible with the 6700... would definitely be the tipping point for a Stages power meter for me...
Ultegra 11spd
- Xplora
Re: Ultegra 11spd
Postby Xplora » Wed Aug 07, 2013 4:52 pm
Re: Ultegra 11spd
Postby jasonc » Wed Aug 07, 2013 5:03 pm
+1Xplora wrote:If there was ever a need for a "like" button, spurious as they are...
the more you write about it, the more I'll read
having to wait til jan for di2 is going to be hard
- Duck!
Re: Ultegra 11spd
Postby Duck! » Wed Aug 07, 2013 7:54 pm
I fitted a 6650 Ultegra Compact to a customer's 9000-specced bike for a trip to France a few weeks ago (due to unavailability of compact rings for the 9000 crank). She brought the bike back in today to have the crank swapped back, and I asked her if the 10-sp crank had any effect with the 11-sp. chain. She said it worked perfectly the entire time.Duck! wrote:They said the same thing ten years ago when 10-speed was The New Thing, and it quickly became apparent that there's more compatibilty than Shimano would like us to believe. Heck, they're even marketing certain stuff as 9/10-sp. compatible. Sure there's some bits that are specific, but cranks tend to not be too fussy.Xplora wrote:Had a look online, Shimano's compatibility chart says 9000 doesn't go with anything else, and saw a few forum comments that said the new teeth might be susceptible to excessive misshifts with the 10 speed chain as it shifts. Then again... if you wanted to get a new crank now and move to 11 speed by Christmas, that might not be a bad idea.
- Xplora
Re: Ultegra 11spd
Postby Xplora » Wed Aug 07, 2013 9:19 pm
Cmon I'm serious, 105 arm is calliiiiiinnnnnnngggggggggggggggggggggggggggg
- Duck!
Re: Ultegra 11spd
Postby Duck! » Wed Aug 07, 2013 11:27 pm
- Xplora
Re: Ultegra 11spd
Postby Xplora » Thu Aug 08, 2013 8:24 am
- HAKS
Re: Ultegra 11spd
Postby HAKS » Sun Aug 11, 2013 4:36 pm
- Xplora
- HAKS
Re: Ultegra 11spd
Postby HAKS » Tue Aug 20, 2013 9:17 pm
Some slightly used 6800 brakes going in the market place
- Xplora
Re: Ultegra 11spd
Postby Xplora » Tue Aug 20, 2013 10:16 pm
- HAKS
Re: Ultegra 11spd
Postby HAKS » Wed Aug 21, 2013 5:01 am
not many shops stocking them yet. Found some at http://www.westbrookcycles.co.uk/" onclick="window.open(this.href);return false; though and they were pretty well priced.Xplora wrote:Didn't realise they had the aero brakes available yet? I'm not unhappy with my Bontrager stock brakes... good on you for getting a real bike
- mikesbytes
Re: Ultegra 11spd
Postby mikesbytes » Wed Aug 21, 2013 10:00 am
http://www.westbrookcycles.co.uk/compon ... ar-p219505
What forks do they fit?
- Xplora
Re: Ultegra 11spd
Postby Xplora » Wed Aug 21, 2013 11:49 am
- HAKS
Re: Ultegra 11spd
Postby HAKS » Wed Aug 21, 2013 12:18 pm
- Duck!
Re: Ultegra 11spd
Postby Duck! » Wed Aug 21, 2013 2:08 pm
- Xplora
Re: Ultegra 11spd
Postby Xplora » Wed Aug 21, 2013 3:34 pm
Cough cough time for cough cough upgrade cough... gee what happened to my lungs??HAKS wrote:They need dual brake post mounts for a start.
Re: Ultegra 11spd
Postby AndyRevill » Thu Aug 22, 2013 2:01 pm
I've tried trawling google but I can't seem to come up with anything so hoping the combined wisdom on here can guide me.
cheers, Andy
Trek Domane 4.5
Re: Ultegra 11spd
Postby jasonc » Thu Aug 22, 2013 2:10 pm
6700 shifters won't work with the 6800 deraillers (well, at least the rear one won't)AndyRevill wrote:So my Domane came with mostly 6700 Ultegra but the cranks are non-series. I'm thinking about upgrading them to Ultegra and it seems logical (to me at least ) that if I do that I may as well go for the latest 6800 variant. I know these are aimed at 11 speed but is there any reason they won't work with 6700 shifters?
you'll also have to check that your wheel hub is capable of holding an 11 speed cassette (they are wider)
re your crank - you'll have to check your bottom bracket/frame are capable of running a 24mm spindle BB that is the correct width for the shimano cranks
- Duck!
Re: Ultegra 11spd
Postby Duck! » Thu Aug 22, 2013 2:17 pm
Did you even read the question?jasonc wrote:6700 shifters won't work with the 6800 deraillers (well, at least the rear one won't)AndyRevill wrote:So my Domane came with mostly 6700 Ultegra but the cranks are non-series. I'm thinking about upgrading them to Ultegra and it seems logical (to me at least ) that if I do that I may as well go for the latest 6800 variant. I know these are aimed at 11 speed but is there any reason they won't work with 6700 shifters?
There is no problem mixing the 6800 crank with a different series of shifters/derailleurs/etc.
Re: Ultegra 11spd
Postby jasonc » Thu Aug 22, 2013 2:27 pm
the upgrading them to me he's going to be upgrading more than 1 componentDuck! wrote:Did you even read the question?jasonc wrote:6700 shifters won't work with the 6800 deraillers (well, at least the rear one won't)AndyRevill wrote:So my Domane came with mostly 6700 Ultegra but the cranks are non-series. I'm thinking about upgrading them to Ultegra and it seems logical (to me at least ) that if I do that I may as well go for the latest 6800 variant. I know these are aimed at 11 speed but is there any reason they won't work with 6700 shifters?
them - Pronoun
Used as the object of a verb or preposition to refer to two or more people or things previously mentioned or easily identified.
Re: Ultegra 11spd
Postby AndyRevill » Thu Aug 22, 2013 2:29 pm
Thanks, I thought that should be the case but nice to have some confirmationDuck! wrote: Did you even read the question?
cheers, Andy
Trek Domane 4.5
Re: Ultegra 11spd
Postby AndyRevill » Thu Aug 22, 2013 2:41 pm
Sorry, my bad. I used cranks as in plural of crank. In my mind a bike has two cranks if the definition of a crank is "an arm attached at right angles to a rotating shaft" there's one on each side. I should more correctly have used crankset, then I could have used "upgrade it". Won't do it again, honest and thanks for trying to help.jasonc wrote:
them - Pronoun
cheers, Andy
Trek Domane 4.5
- Xplora
Re: Ultegra 11spd
Postby Xplora » Thu Aug 22, 2013 8:58 pm
- Duck!
Re: Ultegra 11spd
Postby Duck! » Thu Aug 22, 2013 11:57 pm
- HAKS
Re: Ultegra 11spd
Postby HAKS » Fri Aug 23, 2013 6:51 am
Users browsing this forum: piledhigher2, WyvernRH
