Bang for Buck upgrades - that you've done!
Postby JessicaAlba » Sat Aug 24, 2013 2:14 pm
At $200 for the hubs, plus post, I cannot think of a cheaper way to have ended up with what are essentially a new set of wheels and such a fantastic upgrade to my bike.
And this has got me thinking...what other upgrades have people done to their rides that qualify as true bang for buck? I am not talking trading your $10K Casiti for an $8K Foil Team Issue here, I mean actual bits that you've added to your bike that have instantly paid off in performance, comfort or other real world results.
Get sharin'!
2014 Scott Addict Team Issue/DA9000/Syncros RL1.1/Zipp 404/Gatorskins
- trailgumby
Re: Bang for Buck upgrades - that you've done!
Postby trailgumby » Sat Aug 24, 2013 2:40 pm
Postby gabrielle260 » Sat Aug 24, 2013 2:50 pm
True too!!trailgumby wrote:Losing a couple of Kg from around the middle has been the best performance upgrade I've ever done. Cheap too
But the best upgrade for me is tyres, always. Going to a top quality tyre changes the feel of the ride.
To a lesser extent going from Butyl to Latex tubes improves the ride noticeably too.
Finally - for bigger bucks - upgrading wheels makes a huge difference.
- trailgumby
Postby trailgumby » Sat Aug 24, 2013 3:20 pm
Very true on tyres. Tubes ... I'd prefer to ditch entirely, but that's much more of a challenge with roadie tyres than off-road.gabrielle260 wrote:True too!!trailgumby wrote:Losing a couple of Kg from around the middle has been the best performance upgrade I've ever done. Cheap too
- Rob74
Postby Rob74 » Sat Aug 24, 2013 3:23 pm
1) BBB Bar Tape Synthetic Cork BBHT-05 (don't settle for BBHT-01) + Cinelli AVS Gel Pads I put mine along the top bar around the outside towards the hoods where my hands normally sit.
2) Continental gp4000 700 x 25c reflective with Michelin 700C Presta A1 Ultralite 700X18/23 80g buytl rubber tubes (comfort & safety)
Rob
- Duck!
Postby Duck! » Sat Aug 24, 2013 6:42 pm
- g-boaf
Postby g-boaf » Sat Aug 24, 2013 7:06 pm
How silly! The things are really light. Saved a lot of weight quickly.
Further improvements involve a lot of money or rather a lot of training. I'm already light...
Postby michaelten » Sat Aug 24, 2013 7:16 pm
Postby you cannot be sirrus » Sat Aug 24, 2013 7:17 pm
- trailgumby
Postby trailgumby » Sat Aug 24, 2013 7:40 pm
Hmm. Off-road.Duck! wrote:Picked up a brand new Rockshox Reba fork off another forum that the seller had not read the specs on properly & wound up with the wrong thing, and replaced my old Recon. 400g weight reduction right there, and a better-performing fork to boot. Makes the front end of the bike a stack more playable in rocky stuff, being easier to lift, it tends to float over the lumps rather than ploughing in. $260 well spent. At the same time I did some smaller tweaks - bar, stem, seatpost & pedals, which combined with the fork pulled about 700g out of the bike, but the fork is the one that had the biggest impact on the handling.
Speaking of suspension forks, the upgrade to the 2013 MY damper in the Lefty on my commuter bike, I kept on blowing up the lockout on the DLR hitting potholes with my 700x23c wheelset fitted while the lockout was on.. For $50 more than it was going to cost to fix the lockout, RLC Sport in Brisbane replaced the entire damper with the current model yeaer unit, which has a blowoff valve. No more busted lockouts, and a bit more slow speed damping to boot so its easier to pedal out of the saddle, and the PBR mechanism for the lockout is so much better than the twist lever.
Prior to that, hands down it was going tubeless. Besides the (minor) weight loss - maybe 200g net - the improvement in traction and riding confidence was astounding. Cost me $60 to set up the rims. NOt counting tyres as I'd have replaced them anyway and I initially used non-tubeless tyres.
Another high bang-for-buck improvement was getting nutrition on the bike right.
- ldrcycles
Postby ldrcycles » Sat Aug 24, 2013 10:46 pm
- toolonglegs
Postby toolonglegs » Sun Aug 25, 2013 12:34 am
- singlespeedscott
Postby singlespeedscott » Sun Aug 25, 2013 4:16 am
- Dan
Postby Dan » Sun Aug 25, 2013 6:33 am
At less than $300 per set for ~1620g, very happy.
I also stopped carrying the second bidon I never used...
- familyguy
Postby familyguy » Sun Aug 25, 2013 1:31 pm
2. Swapping to Arione seats on my three main bikes.
3. Buying a $35 eBay runabout for riding with the kids.
Postby Cruiserman » Sun Aug 25, 2013 7:33 pm
Not hard at all haven't had a tube in my roadie for two years now. Don't actually still own a tube that holds air. Dont carry a pump, CO2, a tube or patches. Dont swerve to miss glass either. Had two punctures in 12k that caused problems - both from trying to get to the holidays on the old rear tyre. Once damaged it on the edge of a sharp pothole and the other I stuck a 5mm twig through it when I ran over a stick. Had lots of punctures that were sealed up by the sealant doing its job and a few where I stuck a piece of old inner tube in through the cut - old school style car tyre fix - all done by the comfort of my desk at work.trailgumby wrote:Very true on tyres. Tubes ... I'd prefer to ditch entirely, but that's much more of a challenge with roadie tyres than off-road.gabrielle260 wrote:True too!!trailgumby wrote:Losing a couple of Kg from around the middle has been the best performance upgrade I've ever done. Cheap too
To quote an advertising line - JUST DO IT
1986 Spokesman Model 11 Racing - Campag Nuvo Record - Stronglight - Shimano 600
- munga
Postby munga » Mon Aug 26, 2013 7:09 am
- Dan
Postby Dan » Mon Aug 26, 2013 7:48 am
Don't forget the generic brand froot loops.munga wrote:drinking coffee at home
Postby drpants » Mon Aug 26, 2013 9:52 am
Bike fit, tape, saddle, tyres, wheels, frame, gruppo
If you're chasing weight, these are the best value:
skewers, tubes, wheels, tyres, brakes
Postby Dimis » Mon Aug 26, 2013 10:17 am
To be able to "cycle" my pedals, rather than just push down perceivably meant I went faster for longer
After that, wheels, wheels, wheels... but there's no bang for buck there. So I'll go with Sleep, Sleep and more Sleep for the money value.
