Installing new Ultegra Levers and cables.
Postby def » Sun Aug 25, 2013 12:51 pm
Do you need to lube a brand new cable set? The previous campagnolo installations I've done say there's no need but there was discussion over coffee aprė velo yesterday that you need to syringe lube into cables before installing.
If so, what's the best lube to use?
On a related note, I tried to take apart and investigate the internals of the old 105 levers. What a mess they are inside. I replaced the internals of my veloce levers a few years back and although it was fiddly it was at least doable!
Re: Installing new Ultegra Levers and cables.
Postby r2160 » Sun Aug 25, 2013 1:00 pm
Glenn
"Pain is temporary. It may last a minute, or an hour, or a day, or a year, but eventually it will subside and something else will take its place. If I quit, however, it lasts forever" Lance Armstrong
- Duck!
Postby Duck! » Sun Aug 25, 2013 4:17 pm
Postby su-pista » Sun Aug 25, 2013 6:03 pm
Postby macca33 » Sun Aug 25, 2013 6:18 pm
I'd agree with this comment!Duck! wrote:No need to lube the cables. The supplied outers are greased as well as having a Teflon liner, and the inners (assuming 6700 shifters) are also Teflon-coated.
Postby def » Sun Aug 25, 2013 10:07 pm
I had assumed that Ultegra 10sp is Ultegra 10sp. So long as you avoid 11sp surely 10sp will work OK? Seemed to be OK with 105 levers I've just done even
though the new levers had no "lobster antennae" sticking out of them.
- Duck!
Postby Duck! » Mon Aug 26, 2013 12:28 am
- QuangVuong
Postby QuangVuong » Mon Aug 26, 2013 6:35 am
What happened to the 105 lever you dismantled? And which series was it?
- Duck!
Postby Duck! » Mon Aug 26, 2013 9:01 am
Any reduction in shift quality with internal routing is due to the inherently greater friction of the design.
- Dan
Postby Dan » Mon Aug 26, 2013 11:04 am
Here we go again... Internet expert V bike mechanic.QuangVuong wrote:Not necessarily, Duck. The internal routing of the 6700 levers have a slightly different cable pull than levers with the cables sticking out the side. It should still work, but the shifting may not be as good as it can be.
Postby warthog1 » Mon Aug 26, 2013 3:23 pm
Postby def » Mon Aug 26, 2013 5:48 pm
The old 105 levers are in bits in the bin. I got fed up with failing to diagnose the problem (some weird issue with an escape mechanism).QuangVuong wrote:Not necessarily, Duck. The internal routing of the 6700 levers have a slightly different cable pull than levers with the cables sticking out the side. It should still work, but the shifting may not be as good as it can be.
I'm pretty sure they are 5600 series - the last series with the antennae as far as I know (not a shimano expert).
- Duck!
Postby Duck! » Mon Aug 26, 2013 7:23 pm
Not an early ('06-'07 model years) left shifter in particular by chance? Those things (also '07 4500 Tiagra) were not separate double/triple-specific units, instead one shifter for both crank arrangements. The mechanism between the second & third gear positions was quite delicate, and when used on a double, if the upper derailleur limit & cable tension weren't absolutely spot on, the shifter would start to "overshift" into the third gear zone and blow up its guts terminally. From '08 (mid-'07 release) to the end of production, there were separate double & triple-specific shifters to address the problem. The simple way to tell which version is to look at the nameplate on the left shifter; if it only says 105, it's an early one - the later ones had the word "double" or "triple" as appropriate just under the 105 logo.def wrote:The old 105 levers are in bits in the bin. I got fed up with failing to diagnose the problem (some weird issue with an escape mechanism).
Postby def » Mon Aug 26, 2013 7:58 pm
I don't believe so. It was the RH shifter that shat itself. It wouldn't change with the big lever (ie from small cogs to big cogs on the back). I could make it work by pushing on a bit of sticky-out metal whilst applying tension to the cable and it would change down fine. Like I said earlier, there is some problem with some escape mechanism.Duck! wrote:Not an early ('06-'07 model years) left shifter in particular by chance? Those things (also '07 4500 Tiagra) were not separate double/triple-specific units, instead one shifter for both crank arrangements. The mechanism between the second & third gear positions was quite delicate, and when used on a double, if the upper derailleur limit & cable tension weren't absolutely spot on, the shifter would start to "overshift" into the third gear zone and blow up its guts terminally. From '08 (mid-'07 release) to the end of production, there were separate double & triple-specific shifters to address the problem. The simple way to tell which version is to look at the nameplate on the left shifter; if it only says 105, it's an early one - the later ones had the word "double" or "triple" as appropriate just under the 105 logo.def wrote:The old 105 levers are in bits in the bin. I got fed up with failing to diagnose the problem (some weird issue with an escape mechanism).
I've dug the bits out of the bin and they are 5600 - that's what's stamped on the plastic housing. Also, there is no "3" or "2" under the 105 on the LH lever.
Unsure of the year but I don't think they go back to 2007. They're of a mate's bike who only recently got into riding - 2010 comes into mind but that could be wrong - time flies past and I've lost track.....
