How much would you pay to save weight?
- munga
Re: How much would you pay to save weight?
Postby munga » Thu Aug 29, 2013 6:29 pm
- g-boaf
Postby g-boaf » Thu Aug 29, 2013 9:27 pm
I could probably shave weight with carbon bars and a new saddle, but those are going to be exxy. It does have carbon Ultegra pedals though. I won't give up Di2 however. Like that too much. already have fairly light wheels so I don't need to do anything there.
I'm already light myself at ~60kg so I can often beat quite a few people up hills. I can get quicker still if I really focus on trying to get my heart rate lower.
It's still fun to do bike upgrades - it makes the bike very personal.
Postby Nobody » Thu Aug 29, 2013 11:21 pm
Agree, but upgrades don't have to be WW.g-boaf wrote:It's still fun to do bike upgrades - it makes the bike very personal.
- trailgumby
Postby trailgumby » Fri Aug 30, 2013 7:38 am
Postby autumn acid » Fri Aug 30, 2013 10:57 am
Otherwise, if I had the money I would burn quite a bit on having a lightweight ride for bragging rights.
Postby Dimis » Fri Aug 30, 2013 3:12 pm
This is very true... But at the same time no one talks about how much better a lighter bike can handle (provided you haven't entered wet noodle territory).trailgumby wrote:What is often forgotten in the pursuit to save weight is the impact on handling. What good is a super light bike if it flexes (and handles) like a wet noodle?
Light bikes are a heap of fun to throw around. Particularly in the short and sharp twisters on a descent.
So the trick is light but stiff.
- flex5150
Postby flex5150 » Fri Aug 30, 2013 6:55 pm
saddle
speedplay pedals
light alloy stem or stiff carbon ( note there is about 5g between the Zipp scsl al and bontrager xxx. carb 110mm stems)
sram red group
Booteek brakes that dont work with zipps D'oh!!
Zipps
dodgy ultra light chinese clinchers
latex tubes
tyres with no puncture protection
tubs
Pawni's chain
,....what have i missed
it seams to me if you get the right frame the only slop is in the bars and stem ..or am I missing something?
Giant PROPEL SL RED22.
BMC SLR01 '18 E-TAP
- toolonglegs
Postby toolonglegs » Fri Aug 30, 2013 7:17 pm
Last night I found out my frame wasn't playing up... huge cracking noise everytime I hit a good sized bump. Thought it was slop in the bearing to frame interface like it was on an early frame. Turned out it is the Thomson stem and alloy bars slipping every so slightly causing a huge noise for the amount of movement. Going to go back to a heavier stem ... all my bikes get "down graded" weight wise ... carbon saddle rails, carbon stems, carbon bars, carbon seat posts ... Etc etc all get changed for alloy .
- andione1983
Postby andione1983 » Fri Aug 30, 2013 7:40 pm
Sent from my Galaxy far far away....
MTB - Boardman Team Pro (2013)
- flex5150
Postby flex5150 » Fri Aug 30, 2013 8:16 pm
Agree on the wheel comment but what works for one .......
Andi, you are right of course but a few of us like to play games with our toys
BMC SLR01 '18 E-TAP
Postby pawnii » Fri Aug 30, 2013 8:18 pm
Pawnii's brakesflex5150 wrote:Start with a light but stiff frame..... mmm.. like a madone or a tarmac then select light parts that dont affect noodleisms..
saddle
speedplay pedals
sram red group
Zipps
latex tubes
tubs
Pawni's chain
2012 Scott Foil Premium
- flex5150
Postby flex5150 » Fri Aug 30, 2013 8:27 pm
BMC SLR01 '18 E-TAP
Postby pawnii » Fri Aug 30, 2013 8:38 pm
Postby Dimis » Fri Aug 30, 2013 8:54 pm
Haha, I missed this...Nobody wrote:$10 a gram! That's $10,000 to save 1Kg. They must have started with 6Kg bikes. My bike is 11.6Kg and therefore would cost me $48,000 to get it down to 6.8Kg. Somehow I think the bike mag might be a bit off on what the average consumer will spend.Dimis wrote:FWIW - I was reading a cycling mag that said "market research suggest consumers will average a spend of about $10 per gram, in their quest to save weight."
It was a road cycling mag, they were talking about "real" bikes. :-p
You know, the ones that you buy that start off at around 8kgs Haha.
Sorry, just playing.
So I guess that might actually close to what rrp on some items suggest.
As for you two buggers (pawnii & flex) - I'm targeting sub 20mins up the 1/20 tomorrow. :-p
I haven't broken 20min since goodness it was that long ago, there was a "1" in front of the year on my calendar.
Sheesh, I'm getting old.
- flex5150
Postby flex5150 » Fri Aug 30, 2013 9:05 pm
BMC SLR01 '18 E-TAP
Postby Dimis » Sat Aug 31, 2013 10:53 am
Oh the shame... big effort on my part, but only a fraction over 23 minsflex5150 wrote:I'll be up there about 8am. If you see the Madone say hi. I'll be the one getting dropped by the seniors.
I have no Idea what why either, I wasn't even feeling leg heavy.
Sub 20... who am I kidding...
Oh well Still a fun ride though and there's always next week
I might need pawnii's light weight brakes... haha
- flex5150
Postby flex5150 » Sat Aug 31, 2013 11:35 am
BMC SLR01 '18 E-TAP
- singlespeedscott
Postby singlespeedscott » Sat Aug 31, 2013 12:29 pm
- toolonglegs
Postby toolonglegs » Sat Aug 31, 2013 3:27 pm
Postby pawnii » Sat Aug 31, 2013 3:57 pm
hmm that would be hardsinglespeedscott wrote:What I would like to see is a weight weenie build that is restricted to only aluminum and steel. I reckon 6.8 kg is possible. I wonder how expensive that would be though?
- toolonglegs
Postby toolonglegs » Sat Aug 31, 2013 4:10 pm
- singlespeedscott
Postby singlespeedscott » Sat Aug 31, 2013 6:11 pm
Light weight oversized steel and aluminum would hardly be a noodletoolonglegs wrote:Oh you mean just alloy and steel parts... No carbon allowed. Meh... You would be building the ultimate noodle.
- winstonw
Postby winstonw » Sat Aug 31, 2013 6:45 pm
that's the obvious and logical question to ask.....but people don't make gear choices based on logic.andione1983 wrote:Why not just loose a kilo or two weight... If you are like me I can afford to loose a few.. I started at 108 now down to 98... thats the best way to drop grams... Lol
fwiw, 2 consults with a dietitian would cost ~$160 net.....and the weight loss would be from above ride centre of gravity. so handling would improve better than with any other weight saving imho. plus, you'd clear fat from arteries and get more blood to muscles, thereby improving lactate threshold significantly. but, all this gets in the way of "the dream". most of my mates have bought new bikes in the last 2 years. mine is just over 3 years old now, and I am resisting new gear, and going to keep focusing on engine reconditioning!
- foo on patrol
Postby foo on patrol » Sat Aug 31, 2013 6:57 pm
Foo
Goal 6000km
- toolonglegs
Postby toolonglegs » Sat Aug 31, 2013 7:15 pm
If you are a wippet it might be fine... but it would have to be pretty light weight if your going to run alloy forks and standard wheels. Personally I wouldn't ride a super light weight alloy coke can ... maybe a CAAD10 though ... but I will keep the carbon fork.singlespeedscott wrote:Light weight oversized steel and aluminum would hardly be a noodletoolonglegs wrote:Oh you mean just alloy and steel parts... No carbon allowed. Meh... You would be building the ultimate noodle.
On how much people spend ... I turned up to a stage race in June where everyone was running super lightweight clinchers etc ... I had a fat day .
