The Green Bike...
- WyvernRH
The Green Bike...
Postby WyvernRH » Sun Sep 01, 2013 10:02 pm
I am wondering if it may have been meant for bamboo rims and tubular tyres? Would these have been 622mm in those days? 700C was the 'fat' tyre size after all. I am estimating mid 20's as a date but would be interested if anyone has any better guesses, especially for the original components and wheels.
I took it around the town a few times and even given my rusty fixed riding technique it went very well, the handling especially was pretty tight, no barge rudder steering like on a lot of the roadsters of the day Quite a high bottom bracket too, pedaling around corners at speed was easily possible (important on fixed especially for me!)
It does have a frame number stamped on the left side of the seat lug (which I will edit in here later) Normal large font same as used a lot by Speedwell/Malvern Star etc etc.
All and any suggestions as to date, manufacturer, components etc appreciated. Oh yes, ignore the vertical drilling in the curved rear bridge for a mudguard, This is a blatant non-original bogan bodge. The fork has no drilling at the back for a mudguard. Also the Williams chainset is my addition so no dating of that sadly.
Meanwhile I'm going to ride it around town and hope Henry approves.
Re: The Green Bike...
Postby Torana68 » Tue Sep 03, 2013 7:47 am
Have you tried a set of 28 x 1 3/8 in there? can we get a close up of the head tube pls?
Roger
ok found some other picks, no idea as to maker, date? '25 to '28, HM stamping started in '24 , doubt we would have had any so stamped before 1925. General look of the frame would have been a bit dated by '30 so I think its earlier than that by a little.
"It's only original once"
- WyvernRH
Postby WyvernRH » Fri Sep 13, 2013 9:18 am
Here is a picture of the headtube:
Now It did have a set of 28x1 3/8 in there when Henry rode it but the clearances were very close, too close I thought for the period. Then I found this photo.
The two bikes at the front are pretty much identical in construction to my green bike and look how close the clearances are! Using 28" Westwoods I would say
I'm told this was the start of a race in the late 20's but did that style of toeclip exist then?
So, looks like I maybe should hunt up some lightweight (sic) 28" Westwoods....
Postby LG » Fri Sep 13, 2013 9:00 pm
Postby Torana68 » Fri Sep 13, 2013 9:13 pm
Im onto another bike with similar lugs will let you know if I get any replys from the owner, I believe the toeclips are probably ok, I have a mid 20's racer on the roof of my car,will post a pickie of the pedals etc when I get it down , its very original but I have to empty the car of campy/duraace crap firstWyvernRH wrote:Thanks Roger, Here is a picture of the headtube:
Cheers Richard
Roger
Postby dayne » Fri Sep 13, 2013 10:22 pm
The bikes in the photo look 1915ish, They have bsa tube rear stays and fork set's.
Your bike has a flat top fork crown and im guessing probably around 1930?
I could be way off but regardless it would be built for westwood 28"s i would think
I may be way off though
Postby Johnj » Fri Sep 13, 2013 11:33 pm
This is a Sam Hood photo taken at the start of the Goulburn Sydney race. I believe it is probably 1932. Definitely not 1915ish, Hood only started photographing sports events in the early 1920s. One of the other photos in the set shows these same riders departing Goulburn in the pouring rain (rain was a feature of the 1932 race). I think these are probably amateur riders, perhaps accounting for their rudimentary equipment.dayne wrote:I would have thought it was 1928 and on,
Postby Torana68 » Sat Sep 14, 2013 10:05 am
This is a Sam Hood photo taken at the start of the Goulburn Sydney race. I believe it is probably 1932. Definitely not 1915ish, Hood only started photographing sports events in the early 1920s. One of the other photos in the set shows these same riders departing Goulburn in the pouring rain (rain was a feature of the 1932 race). I think these are probably amateur riders, perhaps accounting for their rudimentary equipment.[/quote]
cant blow it up much, would love a big copy cant see any wingnuts , they appeared here on production bikes post '25 ish so Id bet racers would have been quick to fit them, especially as they are expecting punctures, looks like the bike in front is newer that some in the background, it has tapered chainstays so that could be newer than ''25 (assuming the photo is somewhere around that date) don't look like pro's do they that may mean they are on older bikes and the photo is more towards the late twenties?
Below is the latest find, most probably a Speedwell Special Racer c 1924 ish (haven't really looked at it much yet) , it was all nickel plated and all bits show the same amount of deterioration, when they added straps to toeclips I dunno but it was before the 20's
Postby Torana68 » Tue Sep 17, 2013 11:13 am
ok found a better copy , blew it up and as Johnj has pointed out before the first two guys are Speedwell (in team jerseys?) riders so they would be on the latest bikes or close to it. Front one blown up, looks like it may well be straight chainstays, not later tapered, with cast BSA "Track" type lug, its similar spec to the bike I retreived from Sydney . If its straight stays the photo is probably somewhere around 1924/5. The clothing on the spectators seems to suggest twenties as well. There are some older bikes in there if you look . (PM sent to Richard).
- WyvernRH
Postby WyvernRH » Wed Sep 18, 2013 7:24 pm
I will also have to go look in the 'reserve' stash of frames that were put in the 'too hard basket' due to damage etc under the house as I am sure I have something very simular under there.
Postby Johnj » Thu Sep 26, 2013 10:25 pm
Further pondering suggests that you're right Roger. Almost all the bikes have Ducks roller brakes and no-one has a handlebar mounted bidon. The Goulburn Sydney race photos dated 1932 or later show Philco or other caliper brakes, with bidons on the handlebars. The riders in those later photos also tend to be wearing cycling caps, compared to the rather eccentric headgear on show here.Torana68 wrote:Front one blown up, looks like it may well be straight chainstays, not later tapered, with cast BSA "Track" type lug, its similar spec to the bike I retreived from Sydney . If its straight stays the photo is probably somewhere around 1924/5. The clothing on the spectators seems to suggest twenties as well. There are some older bikes in there if you look . (PM sent to Richard).
I found a series of photos of these blokes on the road, including Madden, Cameron and Hofman (Hoffman?) at feeding stations, Hofman pictured below:
Madden and Cameron both started the Goulburn to Sydney in 1923 and 1924, but I haven't found Hofman yet. However, 1923-1926 is probably about right. Here's another view of that wacky start lineup, with Hofman (I think) second from left. Full size image here.
- Kid_Carbine
Postby Kid_Carbine » Fri Sep 27, 2013 7:02 am
I seem to remember being told bt Jack Hepher [RIP] that Dunlop made the first high pressure 27's in 1935 or '36
Postby silverlight » Fri Sep 27, 2013 9:48 am
I had someone tell me a while back that 27" Tyre [& rim] came in the mid 1930's also and it does seem correct with the bike finds i come across as those post war do have the 27"
I also believe that Malvern Star first introduced them into their star range in 1939
I've always remembered it as that but honestly not sure.
SL
- WyvernRH
Postby WyvernRH » Sun Sep 29, 2013 4:24 pm
Were there such things as 'lightweight' Westwood rims? I have a pair of narrow steel Westwoods on my Speedwell but those are the only 'light' (sic) version I have seen of the Westwood rim.
This has turned out to be a fun bike to ride with the 1960's alloy wheels fitted, I have now added a 1935 Phillips 'Agrippa' clamp-on front brake with an ALPS Guidonnet lever to add confidence (and legality) when riding around the area. Mind you, even with modern pads fitted the brake screams like a stuck pig under any sort of braking load - sets off every dog for miles around
- ldrcycles
Postby ldrcycles » Sun Sep 29, 2013 5:46 pm
WyvernRH wrote: Mind you, even with modern pads fitted the brake screams like a stuck pig under any sort of braking load - sets off every dog for miles around
