Hmmm....I think you may have got those flange distances a bit wrong!find_bruce wrote:Hmmm, I pulled the miscreant wheel apart last night so I could measure the rim & hub & figure out where I went wrong. Can anyone spot why the dimensions I entered cannot be right for a front wheel ?
Rim 604 mm
Hub PCD left 58 mm right 52 mm
Flange distance left 66 mm right 60 mm
No spokes 32
No intersections 3
Wheel building
- queequeg
Re: Wheel building
Postby queequeg » Thu Apr 18, 2013 2:14 pm
- find_bruce
- Moderator
Re: Wheel building
Postby find_bruce » Thu Apr 18, 2013 2:45 pm
Yep, it would be quite difficult to build a wheel where the flanges were outside the locknuts, hence the blushing when I realised my error. Like many daft mistakes, it was obvious when I thought about it. Oh well, no harm done & hopefully I will learn from it.queequeg wrote:Hmmm....I think you may have got those flange distances a bit wrong!find_bruce wrote:Hmmm, I pulled the miscreant wheel apart last night so I could measure the rim & hub & figure out where I went wrong. Can anyone spot why the dimensions I entered cannot be right for a front wheel ?
Rim 604 mm
No spokes 32
No intersections 3
- HappyHumber
Re: Wheel building
Postby HappyHumber » Thu Apr 18, 2013 2:48 pm
+1queequeg wrote:Hmmm....I think you may have got those flange distances a bit wrong!find_bruce wrote:Flange distance left 66 mm right 60 mm
Without having read any of your earlier posts, considering the most common Outer Lock-nut Dimension (OLD) by far for front wheels is 100mm... divide that by two for each side, giving 50mm from the centre line through the rim & hub, and allowing 12-15mm at least for a symmetrical wheel (i.e. non disc) I'd expect this figure to be (in mm) in the high 40s at most.
- Mulger bill
Re: Wheel building
Postby Mulger bill » Thu Apr 18, 2013 6:25 pm
Shaun
- biker jk
Re: Wheel building
Postby biker jk » Thu Apr 18, 2013 7:17 pm
Given the left hub flange has a larger PCD than the right it looks like a disc brake front wheel. That is, it's dished.Mulger bill wrote:Bruce, did you pick a disc braked wheel?
Shaun
- find_bruce
- Moderator
Re: Wheel building
Postby find_bruce » Thu Apr 18, 2013 9:51 pm
Well I guess the gig is up - as you correctly deduced it is a disc hub - a dynamo to be exact. It actually not dished in that the flanges are equidistant from the centre- the drive side has the electrical connector. I still haven't figured out why the disc side has a different diameter flanges.biker jk wrote:Given the left hub flange has a larger PCD than the right it looks like a disc brake front wheel. That is, it's dished.Mulger bill wrote:Bruce, did you pick a disc braked wheel?
Shaun
Re: Wheel building
Postby Crawf » Fri Apr 19, 2013 2:44 pm
Your flange distances should be 25mm & 25mm, shes a very narrow hub.
Re: Wheel building
Postby ironhanglider » Fri Apr 19, 2013 4:39 pm
There is a minimum size required to not interfere with the disc mount when you are trying to insert the spokes. However that doesn't prevent them making the other side the same size to ensure the same spoke length. It surely isn't a weight issue since disc-dynohubs are not sold to weight weenies.find_bruce wrote:Well I guess the gig is up - as you correctly deduced it is a disc hub - a dynamo to be exact. It actually not dished in that the flanges are equidistant from the centre- the drive side has the electrical connector. I still haven't figured out why the disc side has a different diameter flanges.biker jk wrote:Given the left hub flange has a larger PCD than the right it looks like a disc brake front wheel. That is, it's dished.Mulger bill wrote:Bruce, did you pick a disc braked wheel?
Shaun
Perhaps it is to ensure a different spoke length so that you can use different spokes on either side if you perceive that that is required.
That's my best guess but it's not that good.
- biker jk
Re: Wheel building
Postby biker jk » Fri Apr 19, 2013 5:03 pm
I presume the larger left hub flange diameter is to provide a better bracing angle to offset the torsional force applied to the front wheel from the disk brake.find_bruce wrote:Well I guess the gig is up - as you correctly deduced it is a disc hub - a dynamo to be exact. It actually not dished in that the flanges are equidistant from the centre- the drive side has the electrical connector. I still haven't figured out why the disc side has a different diameter flanges.biker jk wrote:Given the left hub flange has a larger PCD than the right it looks like a disc brake front wheel. That is, it's dished.Mulger bill wrote:Bruce, did you pick a disc braked wheel?
Shaun
Re: Wheel building
Postby usernameforme » Fri Apr 19, 2013 6:39 pm
http://www.rockx.net/cfw/cruisinn/spd10.htm
- find_bruce
- Moderator
Re: Wheel building
Postby find_bruce » Sun Apr 21, 2013 4:26 pm
- find_bruce
- Moderator
Re: Wheel building
Postby find_bruce » Sun May 05, 2013 9:03 pm
I have been having issues with breaking spokes on the rear wheel, with an alfine hub & Mavic A719 rim. The flange PCD is quite large (92.6 mm) which means quite an angle at the nipple. The rim has eyelets which force the nipple to be perpendicular. The LBS has rebuilt the wheel twice under warranty, I think using DT Swiss champion spokes, but it kept breaking spokes, each time at the point where the thread starts. This was part of what prompted me to learn to build wheels myself. Having given up on the LBS, I have been replacing broken spokes with Sapim race double butted - my thinking being that the butting will help the spoke bend slightly without as much stress where it enters the nipple. The replacements seems to be holding up well so I stripped the wheel & rebuilt it with the sapim spokes. Built up easily & looks good so we will see how it lasts.
I also finished building the dynamo wheel. I ran into a few issues (1) the shimano brake disc came with T25 screws. 6 bolts later & the torx driver was a twisted wreck, so time to hunt for a better quality tool. (2) when installed, the spokes were hitting the caliper and (3) when looking for the cause of the caliper strike I noticed the rim was not centred. Not sure whether it wasn't straight in the stand or I stuffed up measuring but it was about 2.5 mm towards the disc.
I re-centred the wheel & moved the caliper 1 mm on the mounting which got me just enough clearance. I am still trying to get my head around why. I will post some pics later in the week, just to make sure I haven't made some stupid mistake in lacing the hubs
- biker jk
Re: Wheel building
Postby biker jk » Sun May 05, 2013 9:28 pm
Have you considered Sapim Polyax nipples? They allow for a better line from spoke to nipple.find_bruce wrote:Sucess!! it seems I am getting the hang of this wheel building trick. On my usual form, that means I will start getting careless
http://www.sapim.be/nipples/brass/polyax
- find_bruce
- Moderator
Re: Wheel building
Postby find_bruce » Sun May 05, 2013 10:15 pm
Consider them, I hadn't even heard of them until your post. I just went scurrying out to the garage to see what nipples came with the sapim race spokes & we have a winner - at least one of the reasons why the sapim race DB spokes look like they have a better angle at the nipple is because they DO have a better angle at the nipple - they shipped standard from Bike24 with brass polyax nipples.biker jk wrote:Have you considered Sapim Polyax nipples? They allow for a better line from spoke to nipple.
Thanks biker jk, I can go to bed knowing I have learnt something today
- stevecassidy
Re: Wheel building
Postby stevecassidy » Sun Sep 08, 2013 7:55 pm
a question to the wheelbuilders - where do you source parts? Are there any local suppliers of rims?
I was rear-ended last week and so have a Shimano RS80 wheel minus the hub. I'll get some new wheels but I'm thinking that I might try to re-build the wheel to keep as a spare/training wheel. I've built a few wheels (although never a dished rear wheel) so feel up to the task. However I can't see anywhere locally I could find a suitable 20 hole rim.
Browsing some of the links in this thread I found these:
http://www.bikehubstore.com/KinlinXR270-p/xr270.htm" onclick="window.open(this.href);return false;
which look suitable. Are there any local suppliers of a similar rim or is somewhere like BHS the place to go?
Thanks,
Steve
- biker jk
Re: Wheel building
Postby biker jk » Sun Sep 08, 2013 8:12 pm
I source my parts from BHS. They have good prices on Kinlin rims. However, you will pay a fair bit for postage (it cost me US$55 for two rims, hubs and spokes). I have a wheelset with the Kinlin XR-270 rims but it's 24r spokes. It's a stiff rims and only 445g but I don't know what you weigh and whether 20r spokes will be enough for you. You will need to use straight pull spokes with the RS80 hubs. Make sure you measure the hub dimensions correctly before plugging into a spoke length calculator.stevecassidy wrote:Hi all,
Thanks,
Steve
- stevecassidy
Re: Wheel building
Postby stevecassidy » Sun Sep 08, 2013 9:39 pm
I'll take a look at the postage rates etc. and see if it makes sense. I might pick up another rim to replace the one on my Aksium rear wheel - I just noticed when swapping it in for the bent wheel that the brake track is pretty badly worn. The two together might make it worth getting a package sent over.
Steve
- Velo13
Re: Wheel building
Postby Velo13 » Wed Sep 18, 2013 10:58 am
IMO, Hplusson make the finest quality AL rims on the market.Crawf wrote:ftssjk, consider the H+ Son Archetype, definitely a better quality rim all round, just bit more $.
There are lighter, and a few with some more bells and whistles, but Hplusson are very reliable, straight and round, and finished beautifully. Weights are competitive, and (for the weight) they seem to be far stiffer than the competition.
- Velo13
Re: Wheel building
Postby Velo13 » Wed Sep 18, 2013 11:12 am
Dan, IMHO there is no such thing as a "round" AL rim* - there are always inconsistencies in extrusion, metal density, and just the quality of the rim roll(ing) procedure. As a result, getting a rim evenly tensioned by tightening "equally and systematically" is not going to result in even enough tension. It is hard to gauge that tightening process accurately, and then you have the rim inconsistencies I have mentioned.Dan wrote:Tensionometer is good idea, but as long as you start with a round rim, and tighten equally and systematically, you should end up with an equally tensioned wheel. If you do this, the spokes should have the same relative tension - a tensionometer will confirm this, as well as telling you what the actual tension is (good for build where its necessary to know this, but with a standard build its kind of irrelevant, in my opinion).
I lace a wheel and get it straight, round and up to rideable tension in 25-30mins. But at that point all the hard work starts – getting the tensions as even as possible. This takes that amount of time again, sometimes more.
I am a complete proponent of using a tensiometer to get tensions uniform. Without (and using the "pluck the spokes" method) I can get tensions to about +/- 15%) This is probably good enough for a lot of builders, and should produce a reasonably reliable wheel.
I target 5% tension variation on all my builds. Only possible with an accurate tensiometer.
*or "flat" or "straight" AL rim either. Carbon rims are another story (and challenge) - they can be straight and round to tight tolerances, but they still suffer a bit from inconsistencies in the carbon layups.
- Velo13
Re: Wheel building
Postby Velo13 » Wed Sep 18, 2013 11:26 am
Sounds like you need a 20h rear rim, around 23mm deep.stevecassidy wrote:Hi all,
Thanks,
Steve
Your options are limited there:
- 1. XR-200 will be too light at 20h (even a 28h rear is very light on this rim)
2. Velocity A23 would probably be quite close, but I think they are too light as well
3. XR-270 will be too deep at 27mm (unless you want to roll longer threads on the spokes, or get new ones) - might also be a bit light
4. H+Sons Archetype will be too deep at 26mm (unless you want to roll longer threads on the spokes, or get new ones)
5. XR-300 will be too deep at 30mm (unless you want to get new spokes)
I would recommend the H+Sons Archetye - reasonable weight, close to the original rim depth, extremely stiff, beautiful finishes.
- elStado
Re: Wheel building
Postby elStado » Fri Nov 01, 2013 1:24 am
Are there any good hobby wheel builders in/near South Perth?
Someone crashed into the back of me last year and cracked two of my spokes and put my wheel out of true.
I replaced the spokes myself and got the wheel 98% true, as best I could without a stand, but the wheel was/is slightly out of round still. Also a year later the wheel is a bit more out of true again. I figure it probably needs some TLC by someone with better tools, equipment and knowledge that I do.
It's a heavy duty touring bike, so the wheels are pretty tough. If anyone is interested to see if they can get the spoke tension sorted out and the wheel true & round again I would really appreciate it. I'd also like to watch and take notes as well, so if you have an hour free over the weekend to look at it let me know via PM.
- biker jk
Re: Wheel building
Postby biker jk » Mon Dec 23, 2013 10:39 am
http://www.theteamrobot.blogspot.ca/201 ... ot_20.html
- jules21
Re: Wheel building
Postby jules21 » Mon Dec 23, 2013 10:46 am
- biker jk
Re: Wheel building
Postby biker jk » Mon Dec 23, 2013 11:04 am
24 rear spokes, radially laced non-drive side? Thin DT Revolution spokes? Watch out for spoke wind up with those thin spokes. If you haven't taken the twist out then they will unwind again, even with linseed oil.jules21 wrote:partly rebuilt my rear Reynolds Solitude yesterday. the non-drive side spokes (with lower tension) kept coming loose. bought some linseed oil, loosened all the non-drive spokes, dipped the threads in the oil and tensioned them back up. i used the pluck method - listening for the frequency. it's pretty rough i know, but the wheels are pretty straight. hopefully the spokes stop unwinding..
- jules21
Re: Wheel building
Postby jules21 » Mon Dec 23, 2013 11:09 am
when i went for a test ride afterwards, i could hear them unwinding - that crackling sound as the spoke tension pulls on the thread interface with the nipple.biker jk wrote:24 rear spokes, radially laced non-drive side? Thin DT Revolution spokes? Watch out for spoke wind up with those thin spokes. If you haven't taken the twist out then they will unwind again, even with linseed oil.
do you know how i should take the twist out?
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
