I can't get past 50kms
Postby Davidrnau » Wed Sep 25, 2013 10:58 am
I don't get a chance to ride my bike as much as I would like too presently, however, I do quite abit of walking, the problem seems to be when I am on my bike and I get around 50kms my legs just feel like lead and so sore, feel like I am going to have a clip stack, and my bottom gets so sore also, can only ride about 10-12kms then have to stop for abit......I am by nature a fidgety person and can find it hard to stay on the bike for extended times....perhaps having the flat bar bike doesn't help either, maintaing the same arm position.
I feel okay within myself did 44kms this morning, took a sandwich, and a small protein bar and water.....as I say around 50kms thats it...I could barely get up a 1% incline...well perhaps not that bad
Should I perhaps ride less but more often.
Advice appreciated.
David
I
- trailgumby
Re: I can't get past 50kms
Postby trailgumby » Wed Sep 25, 2013 11:09 am
You need 0.8-1.2g per kg of body weight per hour, depending on intensity. What you're eating doesn't sound like nearly enough. How long are you taking to get to 50km?
REgarding your butt, a set of good quality bibknicks goes a long way (boom-tish ) when matched with a saddle that fits your sit-bones. Drop bars help, but are not the only solution. Relaxing your grip and trying to use your core more to support yourself will help, as will large diameter grips like ODI Rogue.
- sogood
Postby sogood » Wed Sep 25, 2013 11:27 am
Endurance takes time to build up. Regular riding to strengthen your legs and bottom.
You'll get there soon enough, especially if you ride 3-4 times a week. One other thing. Don't just sit on the saddle the whole way. Stand on the bike regularly to give your bottom some airing and circulation. Or you'll be looking at the "saddle syndrome".
Postby lobstermash » Wed Sep 25, 2013 11:36 am
- DoogleDave
Postby DoogleDave » Wed Sep 25, 2013 12:24 pm
At what intensity do you ride at?
How long does it take you to ride the 40-50km's?
What is the general terrain like (flat, hilly, surburban with lots of traffic light stops or rural with minimal stopping)?
How would you rate your fitness level?
How long have you been cycling for?
Do you feel comfortable when riding your bike?
Has the bike been fitted to you?
There are any number of things that could be causing you to "hit the wall" so to speak around the 50km mark, but the suggestions above sound quite valid places to start.
Dave
Postby Davidrnau » Wed Sep 25, 2013 1:37 pm
Yes I agree David, good advice.....DoogleDave wrote:Some good advice above....however I feel we need some more information.
Dave
- Leisurely
- around 3 hours perhaps a little more I am not sure (I stop alot)
- Hilly, not difficult some fast downhills very few traffic lights (minimal stopping)
- Average for my age (pushing 50)
- On and off for years, back on the bike after three years (one month now)
- I feel comfortable on the bike I have followed fit to the letter from what I have found on the net, the bike is not professionally fit
- The bike itself is in excellent condition, is very heavy though must be around 10kgs
David
Postby Nobody » Wed Sep 25, 2013 6:21 pm
Only one month on the bike and almost 50? Give yourself another couple of months to build up to it.Davidrnau wrote:- Average for my age (pushing 50)
- twizzle
Postby twizzle » Wed Sep 25, 2013 6:52 pm
- DoogleDave
Postby DoogleDave » Wed Sep 25, 2013 7:15 pm
Thanks David.Davidrnau wrote: Yes I agree David, good advice.....
- Leisurely
David
My take on the situation....
Although you have prior years on the bike, after your three year hiatus it will take you some time to get your body used to riding for that duration of time.
Riding for three hours is a good effort only one month into your return to cycling so I would just continue on doing what is comfortable for you to do and over the next few months I am sure you will start to see improvement in how you are feeling after this duration/distance.
It is good that you are taking some food and drink with you and it is important that you eat before you feel hungry and drink before you feel thirsty.
Once you hit the wall (if this is what is happening), eating something after that point won't have an immediate affect. You need to consume food before you reach this point.
It may also be that your legs aren't yet used to being pushed for three hours....something only kilometres on the bike will remedy.
I'm not sure what gearing you are using however you should be trying to ride at a comfortable cadence (usually around 80-90 rpm).
If you are working a harder gear and turning the pedals slowly you may be making your legs work harder than they need to. If this is the case, try riding in an easier gear and pedal a bit quicker. This will work your cardio a bit harder but will save your legs. in time you will find the right balance in choosing a gear that you can pedal at a comfortable cadence without working your cardio or legs too hard.
Keep on turning those pedals!
Dave
- cyclotaur
Postby cyclotaur » Wed Sep 25, 2013 9:38 pm
These days I aim for 200+ kms per week and my rides range from 40-90 kms. So it just needs a bit more persistence I'd say. Endurance will come. [WINKING FACE]
My old blog - A bit of fun
- Xplora
Postby Xplora » Fri Sep 27, 2013 9:49 pm
- twizzle
Postby twizzle » Sat Sep 28, 2013 4:47 pm
Umm.... "Base" means training up your slow-twitch aerobic capacity via long hours. Full adaptations to training is supposed to occur within 6 weeks (that's where the 42 day CTL moving average comes from!), after which you are supposed to increase intensity or volume. Hard intervals is more like Carmichael's "time crunched" plan, which gives rapid gains but requires more recovery time after your "race" block. Long term gains (unfortunately) require lots of saddle time.Xplora wrote:4 weeks?! LOL give yourself a chance to adjust. If you want to do it NOW, then ride as hard as you can for 45 minutes 4 times a week to build up a bit of a base. If you have to rest, stop your watch. Get that 45 minutes in. That's going to push you quite a bit; if you are fit now, you'll go faster. You should be smashing it in after a couple months. Your body takes weeks and weeks to adapt to the new stress level. Give it time!
- Xplora
Postby Xplora » Sat Sep 28, 2013 6:36 pm
I think that's something that can't be underestimated - a lot of people aren't told "go out and flog yourself silly for 45 minutes, better that than 2 hours cruising" because I know I got very little out of my commutes adding to 210kms a week except pinch practice. 8 hours a week was not structured too good - and I struggled to put in a hard 50km effort.
Either way, if the OP wants to improve he'll need saddle time. Great way to "suffer" "sorry babe, gotta get some exercise"
Postby vander » Sat Sep 28, 2013 6:48 pm
Not really adaptations are very individual and I am yet to see anything to convincingly say 6weeks is how long it takes. The 42 days is just a fairly arbitrary number and was programmed so it could be changed to the individual person. I feel like your not really meaning to say it but it comes across as your saying base = 6weeks. Again that isnt correct, its highly individual and often people need much longer (I did around 3months of base stuff and would probably still be doing it if I didnt need to get some race form).twizzle wrote: Full adaptations to training is supposed to occur within 6 weeks (that's where the 42 day CTL moving average comes from!), after which you are supposed to increase intensity or volume.
- twizzle
Postby twizzle » Sat Sep 28, 2013 7:41 pm
As for the six weeks - as I said, "within". Some people will adapt faster and can use a shorter period, but if you increase stress too quickly then you supposedly don't get the benefits. The six weeks is supposed to be long enough to ensure the adaptations are complete. Most of this stuff I picked up in J Daniels book, "the running guide" or "the runners guide". And see "Daniels Points" in GoldenCheetah.
Edit: The book is called "Daniels' Running Formula"
Sent from my iThingy...
Postby SEQrider » Fri Oct 11, 2013 12:05 pm
At first I tried to do it on the cheap, cheap knicks, cheap shoes, but I have learned that a good pair of bib knicks is vital to surviving any decent ride, so now I have 3 or 4 bibs with 2 of them being my favourites. Well worth the cost.
Get your cadence up. I started with a cadence around 75, thinking that was a good comfy range, now I naturally spin at 90+ with an average of 87 to 90 over 75 klm up hill and down dale. Without thinking about it I spin at 90 to 100, that has become comfortable and my default rpm.
Stick with it, drink more than you think you need and get some food into you. Bananas, nuts, energy bars, plenty of food to choose from that is easy to carry and easy to eat. The 2cnd last hill before home is always the hardest one for me, but it's not always a physical challenge, sometimes it's a mental challenge that you need to overcome.
Postby autumn acid » Mon Oct 14, 2013 4:27 pm
First couple of months were hell. Any ride longer then 30ks was excruciating. Lower back problems, thighs rubbing. Not fun at all.
I did persist though, given I was slowly losing weight which was a good thing.
A few months ago, I bit the bullet and got a fit done at Velofix in Sydney on the back of some recommendations. It resulted in some fairly major changes to my bike.
Results were immediate. Here are some of the major improvements:
- Sit bones properly supporting my weight, decreasing lower back pain;
- Pedaling efficiency; and
- A weird pain in my left knee gone.
These changes allowed me to push my rides out further and improve my endurance, not to mention enjoy cycling more. I have gone from a ~100k a week rider to a 200k a week rider quite rapidly.
My recommendation is to pursue a fitment, or, perhaps more appropriately get some guidance as to what you can do that will help you achieve your goals. Leg pain, bum pain and pain in general can boil down to a lot of things!
Best of luck.
Postby specialized sl2 » Mon Nov 11, 2013 8:34 am
