Chain ring noise problem?
Postby irrelevant_apple » Wed Oct 16, 2013 11:15 pm
Here's a video showing the perceived problems
https://www.youtube.com/watch?v=s00eOZZoZKU
- Mulger bill
Re: Chain ring noise problem?
Postby Mulger bill » Wed Oct 16, 2013 11:32 pm
Postby irrelevant_apple » Wed Oct 16, 2013 11:53 pm
- Mulger bill
Postby Mulger bill » Thu Oct 17, 2013 10:33 am
Hard to tell, does it occur every crank rotation or at that point of the chain?
Postby irrelevant_apple » Thu Oct 17, 2013 11:07 am
every crank rotation that parts the loudest noise. But there's also noise coming out other points too. The part shown is the only visible reference I've noticed
earliest I remember noticing it was switching crank from standard to compact. Back then my hanger was bent so I thought it was that. Is the crank faulty? Also is the chain getting stretched abnormally like that?
- Mulger bill
Postby Mulger bill » Thu Oct 17, 2013 11:19 am
Does it happen on both rings?
- Saturnstarzz
Postby Saturnstarzz » Thu Oct 17, 2013 12:29 pm
Sounds like it the chain is rubbing on the front derailuer.
Had this happen once and there a few pins slighlty out whack, check for bent or dodgey links too.
What other noises can you hear and from where on the bike?
If its from the rear near/jockey wheels my money will be on the chain.
Postby irrelevant_apple » Thu Oct 17, 2013 1:41 pm
Postby irrelevant_apple » Thu Oct 17, 2013 9:39 pm
Studying the large chain ring I can't really note any striking issue? I.. don't know
edit: small big i meant. So lowest gears
Postby eeksll » Fri Oct 18, 2013 12:08 am
Is the chainring square with the frame?
It looks like the teeth is catching on the inside plate of the chain, are there any missing spacers to push the crank out further?
Postby irrelevant_apple » Fri Oct 18, 2013 1:38 am
The compact 4600 didn't come with any spacers. No spacers came off the standard 4600 either.
Postby eeksll » Fri Oct 18, 2013 8:27 am
also if you didnt remove the bottom bracket then squareness is probably not the issue. I think the main place for it to be out of square is at the bottom bracket/frame interface.
Thinking along those lines, if you put the old crankset back on, does it line up to the same spot on the front derailleur as the compact crankset?
Thats all i got
Postby irrelevant_apple » Fri Oct 18, 2013 11:02 am
I'll test the old standard crank to see when I remove the chain next for a degrease. Unless I should ASAP because of risk of stretching the chain like this?
Thanks for trying to think of the solution.
Postby eeksll » Fri Oct 18, 2013 2:00 pm
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
