Recommend some road pedals
- trailgumby
Postby trailgumby » Fri Nov 29, 2013 9:19 am
Speedplay looks like a contender - the double sided entry is a definite plus but the setup looks expensive and with all the mechanics in the cleat maintenance costs could be high especially as I climb and descend the Harbour Bridge steps most weekdays.
Any other options? Lack of friction within the float range is the primary consideration followed by ease of entry. I've been getting it wrong too often which has made for quite a nervous last fortnight's commuting.
Thanks for your advice.
Sent from my android thingy using Crapatalk
- m@
Re: Recommend some road pedals
Postby m@ » Fri Nov 29, 2013 9:59 am
Have you considered mtb pedals though? I use eggbeaters on my commuter/runabout and with reasonably good shoes find them great... much easier to get into than anything else I've used, and lower maintenance than the speedplays.
- open roader
Postby open roader » Fri Nov 29, 2013 10:07 am
When I switched from using Shimano SPD on my road bike to using road cleats/pedals, my then LBS bloke (who is long term tied up with a local bicycle club thus has plenty of experience with different pedal requirements) gave me some very good advice as I insisted upon the ease of unclipping like an older well worm pair of SPD's offers in a road pedal cleat system. He recommended Time RXS (of which he had none to sell me) ........ I followed through on his advice and now count my lucky stars -
Time RXS :-
* Very low resistance in the float range which is 5 degrees both left and right direction which for me with slightly angled cleat mounts means perfection for my ankles
* Easiest system to unclip out of (3 tension settings) even easier to escape than a nicely worn SPD set up
* Once you get accustomed to the angle the pedal needs to be on in order to clip in - even a brand new cleat locks in first time every time
As I stated before, my primary concern was ankle strength and subsequent pain from the unclipping process. RXS suits me to a T in this regard and the float really is a float - your shoe rotates without having to think about it. I have 3 road bikes now, all fitted with RXS pedals.
- flex5150
Postby flex5150 » Fri Nov 29, 2013 10:40 am
Speedplay are lighter. Easier to get in and out of
Fully adjustable float. Much easier to set up cleat position (if you use specific sole shoes)
Did I say easier to get into at lights.
Weight tunable if that's important to you.
Cleats last longer that keo but cafe covers are a must.
Ill never go back. The best decision I ever made.
Giant PROPEL SL RED22.
BMC SLR01 '18 E-TAP
- im_no_pro
Postby im_no_pro » Fri Nov 29, 2013 11:42 am
Sent from my GT-I9210T using Tapatalk
Postby george-bob » Fri Nov 29, 2013 12:13 pm
Postby Baalzamon » Fri Nov 29, 2013 12:53 pm
- jacks1071
Postby jacks1071 » Fri Nov 29, 2013 3:02 pm
Sounds like you've got a knee alignment issue, float is a good bandaid / insurance option but you should consider getting a knee/pedal alignment done.trailgumby wrote:I've been using Shimano 105 pedals for the last few weeks on the roadie and while I really like the extra stability compared to mtb pedals, the high drag in the float action is giving me knee pain. WD40 on the cleat before a ride helps but is not sustainable.
I recommend Speedplay X5 pedals if you want float, they are probably around $150?
- trailgumby
Postby trailgumby » Fri Nov 29, 2013 3:56 pm
My current mtb pedals are XT and I previously have not had this issue except when I used the Ergon cleat tool to set the cleats dead straight in line with the heel.
This is different. The amount of rotational resistance is similar to a *very* stiff fluid panhead camera tripod.
- familyguy
Postby familyguy » Fri Nov 29, 2013 4:10 pm
Or maybe a set of the platform+SPD pedals to get the extra area under your foot. Plus: use your MTB shoes, easy walking. Minus: change pedals if you want anything else on a weekend.
There's only one true solution...n+1 with n+1 shoes and n+1 pedals to keep your systems separate!
- jacks1071
Postby jacks1071 » Fri Nov 29, 2013 4:44 pm
Do you mean you set the side to side the same on both shoes? Keep in mind your MTB Q-factor is probably wider than your road bike.trailgumby wrote:Already done on the MTB with carbon shoes and have followed the same position on the road shoes for heel in/out. I'm very slighyly heel in. Will review fore/aft placement tonight but should be close.
Wear on speedplay cleats is only really an issue for people who either have never used them, or those who walk around in sand and mud. I get around 10,000kms out of a set of cleats which I think is double what Speedplay say is possible. I don't do anything special, try to keep them clean and a bit of oil from time to time.
The pedals I like are Shimano, Speedplay and Keywin. All offer good levels of adjustment, Keywin are the easiest to swap axle lengths on, speedplay have the most float and Shimano are the best value and are also the most readily available.
You might find this video interesting, there is quite a lot involved to do an accurate knee alignment - this is obviously only one system. An experienced person can do a similar job with a laser level.
http://www.youtube.com/watch?v=12_zpaWMUaw" onclick="window.open(this.href);return false;
- trailgumby
Postby trailgumby » Fri Nov 29, 2013 9:19 pm
- jacks1071
Postby jacks1071 » Sat Nov 30, 2013 1:13 am
I'd get a new set mate, they come with cleats which regularly cost around $70 so the pedals arn't expensive new and you know what you are getting. I keep the service up to mine (very simple to grease them) and have never worn a set of bearings out.trailgumby wrote:So does anyone have any Speedplay road pedals and cleats they want to clear out?
http://www.this link is broken.au/speedplay-x5-c ... ly-pedals/" onclick="window.open(this.href);return false;
- m@
Postby m@ » Sat Nov 30, 2013 5:49 am
Postby antipodean » Sat Nov 30, 2013 1:05 pm
Light, secure, easy to clip in/out, plus they come with 2 sets of cleats - 6 degree and 0 degree float.
Recommended.
- flex5150
Postby flex5150 » Sat Nov 30, 2013 2:14 pm
BMC SLR01 '18 E-TAP
- Jean
Postby Jean » Sat Nov 30, 2013 2:39 pm
I'v been wondering about those. I'm going right off composite body pedals - as soon as you start researching all there is is tales of breakages (a minority probably, but still I want pedals that will last). There is not much around in metal bodied pedals these days - Shimano, Ritchey (Echelon) and these Xpedos seem about the sum of it. The Xpedos are certainly keenly priced and seem to be serviceable, which is good. Reviews are scarce, but the vibe is positive.antipodean wrote:Recently purchased a set of these http://www.cyclingdeal.com.au/buy/xpedo ... ble/RF07MC" onclick="window.open(this.href);return false; and find them to be fantastic.
Recommended.
I'm sure Speedplays are great to pedal on, but I just can't come at that kludgy cleat set up. I'd love to stick with Time pedals, but the breakage I've had (not catastrophic, but still disappointing) puts me off.
- m@
Postby m@ » Sat Nov 30, 2013 2:51 pm
I was a bit skeptical about the Speedplay "worldview", but wouldn't go back to traditional designs; I'm not alone which makes me suspect they're onto something - but enough proselytising from me
- trailgumby
Postby trailgumby » Sat Nov 30, 2013 5:11 pm
Might as well be made from recycled coffee cups. A triumph of form over function ... nice looking kit, but it breaks. Frequently. Or it needs the guts replaced annually, and then becomes like Grandpa's axe. It's had three new handles and five new heads, but gee it's been a great axe. Pedals, seatposts, cranks, you name it. Chronically under-engineered.
I wouldn't touch anything with their logo on it unless it was a two-for-the price of one deal, at 50% off RRP for the first item, so that I can put the other one on the bike while the other is being fixed under warranty.
Actually, scratch that. I want to keep my teeth intact, thanks. Make that "I wouldn't touch anything with their logo on it, period.:
Postby Le Mong » Sat Nov 30, 2013 7:24 pm
Easy choice.
Postby eeksll » Sat Nov 30, 2013 7:55 pm
spds with platform: I have a set of Shimano DX M647 Pedals, the friction of my shoes sole agains the platform messes with the float. So if you go that route you'll have to get creative by trying the sand down some shoe sole or a spacer under the cleat. I tried neither and went straight back to normal spd.
Postby Nobody » Sat Nov 30, 2013 8:33 pm
Tell us what you really think.trailgumby wrote:Crank Bros!
..."I wouldn't touch anything with their logo on it, period.:
- jacks1071
Postby jacks1071 » Sat Nov 30, 2013 11:10 pm
Speedplay have a few models, I use the X-series which use no pressure to unclip - once you heel is at the release angle you are out. No need to SNAP or FLICK it out..eeksll wrote:speedplays are harder to get our of than spds. Normally never had an issue, but after a couple of hard runs (as in running) my ankles where a bit sore and unclipping the speed plays (zeros) was almost a clipstack moment.
Most people these days tend to purchase the Zero model but I still prefer the older X-series.
- m@
Postby m@ » Sun Dec 01, 2013 6:54 am
I just replaced the bars on my Anthem with a set of Cranky Cobalt 11s (carbon)... so if I suddenly stop posting you'll know why
- toolonglegs
Postby toolonglegs » Sun Dec 01, 2013 6:01 pm
But I digress ... pedals, only ever ridden Times since 1997, love them so much I moved next to the factory .
