Crapola!!!....P.E.D's in Cycling
- schroeds
Re: Crapola!!!....P.E.D's in Cycling
Postby schroeds » Fri Dec 20, 2013 1:03 pm
- Chuck
Postby Chuck » Fri Dec 20, 2013 1:17 pm
schroeds wrote:sounds like the ladies and gentlemen of the jury have reached their decision
schroeds wrote:Can't see how they could bust Conty and not Dodger unless he had photos of buying and eating beef, they track it down to a supplier test their products and find the substance...
I spose it's possible but I wouldn't be putting any bets on it
- schroeds
Postby schroeds » Fri Dec 20, 2013 1:38 pm
Sent from my SM-N9005 using Tapatalk 2
- brentono
Postby brentono » Fri Dec 20, 2013 1:56 pm
schroeds I didn't actually speak of just Clenbuterol,schroeds wrote:
Why would it be a mammoth task to add a threshold level of Clenbuterol?
I stated it be a mammoth task to add a threshold levels to ALL banned substances.
As found in the Contador case, the levels found, had no performance gain.
The mammoth task would be in determining at what level, each banned substance,
had the potential to enhance performance. So the easy way out is "no tolerance"
To others...
Having been a competitor at the highest levels in this sport, I am certainly NOT offering cheats
a leg up by supplying a ready made loophole, but actually allowing the possibility of false positives,
or even food or supplement contamination.
One would quite naive, to believe that there are only two places in the world where clenbuterol
is used in livestock. With some research, you can find it in many South American nations,
from when one of the Major meat suppliers, distribute worldwide (even EU),
in the era of global food networks.
It has been found even in the good 'ol U S of A (and yes, even in Spain)
... the point is, something to consider
To destroy a persons livelihood, by a technical injustice, doesn't see right to me,
but that is only my opinion.
The same would go for the present drug policies, for employment and employees,
in which clenbuterol figures, and people lose their employment.
I have never been, or condoned a drug, or any type of sporting cheat.
But I am not one of the "holier that thou" element that frequents the forum
when PED's are discussed here.
End of rave
- sogood
Postby sogood » Fri Dec 20, 2013 2:09 pm
Completely meaningless.brentono wrote:As found in the Contador case, the levels found, had no performance gain.
Blood level of a substance is always dynamic. What's of no performance benefit may not have been without benefit earlier. Then there's all the different theories out there, with or without scientific basis. The only question are positive or negative and intent.
Postby vander » Fri Dec 20, 2013 4:43 pm
Brentono read Tyler Hamiltons book and you will realise any little loophole they will abuse. You will also realise that they were all doing it and you will never defend a cyclist again.
- biker jk
Postby biker jk » Fri Dec 20, 2013 4:59 pm
Yes plasticisers were found suggesting a transfusion. Crazily out of the three scenarios (contaminated beef, transfusion, supplements) the authorities claimed the (least likely in my opinion) source of the clenbuterol was supplements.vander wrote:Wasnt the big sway in Contador's case the trace amounts of plasticisers found (or something similar) indicating it was likely that it was from a blood transfusion. I thought I remembered seeing that somewhere.
- find_bruce
- Moderator
Postby find_bruce » Fri Dec 20, 2013 5:21 pm
As biker jk says, the presence of plasticisers was considered "the big sway" by the comenterati, but not by the Court of Arbitration for Sportbiker jk wrote:Yes plasticisers were found suggesting a transfusion. Crazily out of the three scenarios (contaminated beef, transfusion, supplements) the authorities claimed the (least likely in my opinion) source of the clenbuterol was supplements.
Tread carefully my friend - if you read Brentono's post above, you would notice that he says that he was a competitor at the highest levels and may well take it personally for you to say "they were all doing it"vander wrote:Brentono read Tyler Hamiltons book and you will realise any little loophole they will abuse. You will also realise that they were all doing it and you will never defend a cyclist again.
Postby Dr_Mutley » Fri Dec 20, 2013 5:34 pm
Edit: Riccardo Riccò was the smart fella
Postby vander » Fri Dec 20, 2013 5:41 pm
I dont believe he competed on the road in Europe at that time. All was probably a bit much. Lets stick with 98%find_bruce wrote:Tread carefully my friend - if you read Brentono's post above, you would notice that he says that he was a competitor at the highest levels and may well take it personally for you to say "they were all doing it"vander wrote:Brentono read Tyler Hamiltons book and you will realise any little loophole they will abuse. You will also realise that they were all doing it and you will never defend a cyclist again.
- brentono
Postby brentono » Fri Dec 20, 2013 6:29 pm
Vander- Not a big sway.vander wrote:Wasnt the big sway in Contador's case the trace amounts of plasticisers found (or something similar) indicating it was likely that it was from a blood transfusion. I thought I remembered seeing that somewhere.
From the Final Document from the CAS
The Panel’s conclusions regarding the Blood Transfusion Theory.
THE SUPPLEMENT SCENARIO (which became the most plausible)454. To sum up, for the above reasons, the Panel finds that although the blood transfusion
theory is a possible explanation for the adverse analytical finding, in light of all the
evidence adduced and as explained above, it is very unlikely to have occurred
Thanks for the book heads-up, but I do understand that with the money and prestige today457. The existence of contaminated food supplements in general is uncontested and there are
numerous cases of athletes who have tested positive after having ingested contaminated
food supplements.
comes more pressure to cheat. Was not so in my time, but some still did it. It comes down
to each individual's conscience, and with the wrong choice, their disgrace ala L.A.
There may be some on here, that cheat to get from D to C grade, for prestige (it happens)
I say "ride to enjoy it" and when that stops, move on.
- sogood
Postby sogood » Fri Dec 20, 2013 7:18 pm
It's all relative. There's been no shortage of cheats in the past either. Comes with every generation.brentono wrote:...but I do understand that with the money and prestige today
comes more pressure to cheat...
- find_bruce
- Moderator
Postby find_bruce » Fri Dec 20, 2013 8:02 pm
At least they have weeded out the train riderssogood wrote:It's all relative. There's been no shortage of cheats in the past either. Comes with every generation.
- sogood
Postby sogood » Fri Dec 20, 2013 8:09 pm
- ldrcycles
Postby ldrcycles » Fri Dec 20, 2013 11:41 pm
Re the clenbuterol, i'm sure I remember reading an article about Contador saying something about how long clenbuterol stays in the animal's system, and how long it can remain in the meat after processing. Damned if I can find it now though.
- Alex Simmons/RST
Postby Alex Simmons/RST » Sat Dec 21, 2013 9:49 am
Brentono is right, there needs to be proper justice applied as is sogood on the issue of concentrations in blood/urine being dynamic and not always telling the full story. Clen has a half life of around 1.5 days IIRC so knowing what the concentration level is may provide a clue as to the level of plausibility of food contamination but it cannot tell us how the clen came into his system, although if the level is high, then it most probably wasn't from eating meat in China.
But the point is moot, the rules on strict liability are what they are, it was 2 months ago and opportunity to realistically investigate the contamination angle have long since passed. Clen is a prohibited doping product, it has been found in team doping kit bags from previous investigations and raids, and it most definitely is an ergogenic aid, and in various ways of benefit to cycling performance.
Advice not to eat the meat in China is not new, WADA have issued advice on this for many years, indeed China's own olympic athletes are not permitted to eat their own home grown beef.
There are already threshold levels for various substances in the prohibited list, so it's not something WADA do not or refuse to do, and of course for many substances that threshold level is zero.
In Roger's case, it all has a bit of an Al Capone feel to it.
But the issue as I said is complex, and the young Belgian rider who was also pinged for the same thing at same time/same race has just attempted suicide according to latest news reports:
http://www.cyclingnews.com/news/breyne- ... oping-test" onclick="window.open(this.href);return false;
Dope testing unfortunately has a very poor track record of actually catching dopers. The big fish that have been caught have mostly been reeled in by other means (investigate, confession etc). But this happens many many moons after the fact.
- Strawburger
Postby Strawburger » Sat Dec 21, 2013 11:22 am
- sogood
Postby sogood » Sat Dec 21, 2013 11:43 am
- clackers
Postby clackers » Sat Dec 21, 2013 11:49 am
- sogood
Postby sogood » Sat Dec 21, 2013 3:07 pm
- jules21
Postby jules21 » Sat Dec 21, 2013 9:22 pm
the certification of a test is not the decider of whether it can be used as evidence, but its weight as evidence. the testimony of former team members isn't certified either, but it was enough to sink Lance. in the end, it comes down to the strength of evidence - in all its forms. for example, if there was corroborating evidence of Contador engaging in blood doping, the plasticisers present in his blood (or urine?) sample may have been enough to secure a guilty finding.ldrcycles wrote:AFAIK, the plasticizer test is not approved/certified yet, so it can't be used as evidence (or something like that).
- ldrcycles
Postby ldrcycles » Sat Dec 21, 2013 10:52 pm
Thanks for clearing that up for me .jules21 wrote:the certification of a test is not the decider of whether it can be used as evidence, but its weight as evidence. the testimony of former team members isn't certified either, but it was enough to sink Lance. in the end, it comes down to the strength of evidence - in all its forms. for example, if there was corroborating evidence of Contador engaging in blood doping, the plasticisers present in his blood (or urine?) sample may have been enough to secure a guilty finding.ldrcycles wrote:AFAIK, the plasticizer test is not approved/certified yet, so it can't be used as evidence (or something like that).
- brentono
Postby brentono » Sun Dec 29, 2013 12:04 pm
...Trackies know, that when adding "Shellac solvent" to your party cocktails, always use a measure.“I think it is terrible and disgusting how everyone has treated Lance,
especially after what he has achieved in winning 7 Tour De France’s whilst on drugs.
When I was on drugs I couldn’t even find my bike”
Warning: some may find this really disturbing… about as disturbing as clown sex.
To All, All the best with your Cycling.
- singlespeedscott
Postby singlespeedscott » Wed Jan 01, 2014 10:43 am
http://www.cyclingnews.com/news/62-year ... -nationals" onclick="window.open(this.href);return false;
- biker jk
Postby biker jk » Wed Jan 01, 2014 11:07 am
Quite sad really.singlespeedscott wrote:Idiocy is not just limited to the Pro's
Return to “International and National Tours and Events”
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
