Broken teeth
Broken teeth
Postby Adriano2610 » Thu Dec 05, 2013 1:26 am
I had an accident with a bicycle and broke my teeth, a local dentist wants to charge $ 4,500 to repair.
I do not have that kind of money right now, has anyone any idea how we solve this problem?
- ldrcycles
Re: Broken teeth
Postby ldrcycles » Thu Dec 05, 2013 9:14 am
- Summernight
Re: Broken teeth
Postby Summernight » Thu Dec 05, 2013 10:49 am
The technology, equipment and time necessary to create crowns and restore teeth is not cheap or quick. Dentists aren't usually out to gouge you, that is just the true cost of the work and the required materials.
If you have private health insurance you may be covered for dental.
Just remember that if you do it overseas you don't have the same surety regarding quality or getting things fixed if they are stuffed up and if they do get stuffed up you'll have to pay more to replace them back in Australia.
That's because we've been spoiled by virtually free or heavily subsidised medical so our idea of the true cost is a bit warped. Dental procedures are not currently subsidised (unless you are really poor I believe) so that is why you see the higher prices. I'm glad we are spoiled like we are with respect to medical, but you do have to take that into consideration.ldrcycles wrote:The cost of dental work in this country is disgusting.
As an example, if you don't have ambulance cover and get taken by ambulance to hospital - that can easily be $1,000 just for the care and ambulance ride. Is that disgusting? Probably, but that is the cost of having 2 paramedics dash out to your place and use materials/drugs to try and save your life.
Just my 2 cents.
Good luck with getting your teeth fixed, Adriano and I hope you find a solution.
- grimbo
Re: Broken teeth
Postby grimbo » Thu Dec 05, 2013 2:56 pm
Will probably see about converting to caps at some time depending on time, money and the pain involved.
- sogood
Re: Broken teeth
Postby sogood » Thu Dec 05, 2013 3:18 pm
As some have already suggested. Try a second opinion/quote and make sure you understand their suggestion/s and the durability of such treatment. With 3 or more teeth involved, be prepared to pay a significant amount. Then it's a question of for the same money, who is the best to carry out the job. Like all, some are better than others.
Re: Broken teeth
Postby Coolabah » Sun Dec 22, 2013 8:52 pm
What a (refreshingly) intelligent and accurate post. I agree, with all medical/dental etc stuff there is always more than one choice. ( edit : following comments directed to the OP) I would actually first ask your own dentist ( whom you obviously know and trust ) if there is another choice- composite restorations are not as predictable as crowns but cheaper and might buy you some time. As for overseas medical treatment of any kind... just remember that there are usually no controls in a lot of these countries - you might be risking Hepatitis B or C , HIV, Staph Aureus... just for starters. You always hear the stories about "my mate went overseas , paid $2 for treatment worth $100,000 and he has no problems ( yet/ that he knows about ) ... yeh right but no-one admits to the times when they have problems...Summernight wrote:Get the second opinion, but fixing those teeth isn't just a case of whacking on some tooth coloured cement in 5 minutes - it may involve filing back the teeth and putting crowns over the top to restore them to toothy goodness as you've done a good number on them.
Just my 2 cents.
Australia is one of the most over - regulated countries in the world for medical stuff. Even then we have problems that surface... but they DO surface because these problems are recognised when they occur. Some of these medical tourist destinations would not even KNOW if there is a problem eg failed autoclaving of instruments- assuming they even do this... big assumption here guys !.
All I can say is... do you feel lucky ? Well, DO YA , punk ??
( apologies to Mr Clint Eastwood)
- sogood
Re: Broken teeth
Postby sogood » Sun Dec 22, 2013 9:11 pm
Well, not all of them are like that. The hard part is for a foreigner to know which of the many providers are suitably qualified. One fear I have with these tourism health services is in situations when things go wrong. It may be a <1% probability, but when it does, the cost of extending the stay alone may make it not worthwhile. As for life, it's a game of probabilities and some get luckier than others.Coolabah wrote:Australia is one of the most over - regulated countries in the world for medical stuff. Even then we have problems that surface... but they DO surface because these problems are recognised when they occur. Some of these medical tourist destinations would not even KNOW if there is a problem eg failed autoclaving of instruments- assuming they even do this... big assumption here guys !.
Re: Broken teeth
Postby Coolabah » Sun Dec 22, 2013 9:23 pm
sogood wrote:Well, not all of them are like that. The hard part is for a foreigner to know which of the many providers are suitably qualified. One fear I have with these tourism health services is in situations when things go wrong. It may be a <1% probability, but when it does, the cost of extending the stay alone may make it not worthwhile. As for life, it's a game of probabilities and some get luckier than others.Coolabah wrote:Australia is one of the most over - regulated countries in the world for medical stuff. Even then we have problems that surface... but they DO surface because these problems are recognised when they occur. Some of these medical tourist destinations would not even KNOW if there is a problem eg failed autoclaving of instruments- assuming they even do this... big assumption here guys !.
not sure at all where you get the less than 1% from as I understand the true figure is way higher. I have a friend who had severe issues (still ongoing) after doing this exact same tourism thing .
read this document it is really understated if you ask me :
http://www.ada.org.au/app_cmslib/media/ ... ber_12.pdf" onclick="window.open(this.href);return false;
People seem to assume that all dentists/doctors/engineers/you name it , world wide, are absolutely equivalent in training/knowledge/skills.... all I can say is ... this is absolutely not the case.Why do you think many doctors with overseas qualifications have to train for many years before they are allowed to practice in Australia ???
Anyway , I guess I'm getting off topic here . OP : I hope you heal well
- sogood
Re: Broken teeth
Postby sogood » Sun Dec 22, 2013 9:26 pm
I said "It may be a <1% probability", as in a best case scenario, to demonstrate the risks. At the same time, ADA isn't completely unbiased either.Coolabah wrote:not sure at all where you get the less than 1%...
There are some excellent services overseas and there are some sub-par services locally. The really hard part for most is knowing how to find the best. Comes back down to how well one can manage the risks.
Re: Broken teeth
Postby Coolabah » Sun Dec 22, 2013 9:35 pm
oh, OK. Sorry to sound pedantic but it would be clearer to have stated " I would guess that..." rather than implying you were quoting a statistic available somewhere... but then again ,even though it may be that >87.299772 % of all statistics are made up, I still believe the statisticians ( see what I mean ! )sogood wrote:I said "It may be a <1% probability", as in a best case scenario, to demonstrate the risks.Coolabah wrote:not sure at all where you get the less than 1%...
- ldrcycles
Re: Broken teeth
Postby ldrcycles » Mon Dec 23, 2013 7:19 am
- RonK
Broken teeth
Postby RonK » Mon Dec 23, 2013 9:16 am
Treatment overseas might seem an attractive option, but keep in mind that medical and dental procedures can and do go wrong in any country, even here, but should you be forced to get a botched job fixed locally, or return to your os practitioner, then any savings may evaporate.
On the dental profession, there is a large contingent of dentists in my local bunch, and it has become apparent to me from listening to their comments and conversations that they are quite adept at maximising their incomes.
- AUbicycles
- Site Admin
Re: Broken teeth
Postby AUbicycles » Sun Jan 12, 2014 11:17 pm
But onto the question how to afford this - even if you can get a more competitive price from an equally skill dentists, the options are asking about a repayment plan (preferably no interest) or if not possible, ask family for a loan. If you havn't already had the work done, it is something that would be preferable paying back than saving up for.
- wombatK
Re: Broken teeth
Postby wombatK » Mon Jan 13, 2014 10:22 am
Your teeth are the first part of your digestive system - and the first thing you need in good order to get proper nutrition. If you are
in your late teens or early twenties, they've got to last you some 50+ years - so get them fixed properly. Spread even over 10 years
(and you should get better), the cost is not going to be a major element in your budget.
FWIW, if you get wisdom teeth that need extracting, you could be up for $6,000 or $7,000 plus. Health insurance that covers dental
can be very sensible.
- sogood
Re: Broken teeth
Postby sogood » Mon Jan 13, 2014 12:37 pm
