Wamuran Rail Lines
- Paddles
Wamuran Rail Lines
Postby Paddles » Thu Dec 19, 2013 2:14 pm
- RonK
Re: Wamuran Rail Lines
Postby RonK » Thu Dec 19, 2013 2:41 pm
You will find information on railtrails.org.au
- Paddles
Postby Paddles » Thu Dec 19, 2013 3:04 pm
- Lukeyboy
Postby Lukeyboy » Thu Dec 19, 2013 5:40 pm
- RonK
Postby RonK » Thu Dec 19, 2013 6:02 pm
Yeah, there a pictures on the web, some showing rails, some just the railbed. According to railtrails.org.au it is "partially completed".Lukeyboy wrote:Pretty sure the rails are actually still there as its still a valid railway corridor.
Postby Ryanhyltoncummins » Fri Dec 20, 2013 2:38 am
there is a bike path that follows Toohey St and into Del Rosso which takes it past the schools I haven't been any further
- Lukeyboy
Postby Lukeyboy » Fri Dec 20, 2013 11:17 am
- ldrcycles
Postby ldrcycles » Fri Dec 20, 2013 11:46 pm
- Orion
Postby Orion » Sat Dec 21, 2013 11:56 am
Most of the line is still in place although small sections have been ripped up due to road works - mainly around King St and County Drive.
You can follow the line along Toohey St to the end of Del Rosso Rd in Caboolture. There is a vague track from the end of Del Rosso Rd but there is a fence blocking access to a power line easement (High Voltage lines). I'm not sure on the condition between there and King street or even if it is possible to get through. One alternative is to cross the train line and cut through the nearby housing estate onto King St then along to the line just before you meet the D'aguilar Highway. The shoulder is reasonably wide but the speed limit is 80kph, so I wouldn't recommend it for kids depending on how old they are. Option 2 from the end of Del Rosso Rd would be to go under the D'aguilar highway (there is a tunnel underneath it) onto Cayenne Rd, follow around to Greening Rd, turn left then left again onto Williams Rd. Go over the highway then right onto King St. This will bring you out about 200m up from the train line. This way is much quieter - virtually no traffic except for a small amount on Williams Rd. Turn left onto Quarry Rd then follow to the end and then onto the rough dirt track beside the train line.
When you get to a dirt driveway you will see a sign (Private property - no tresspassing). Ignore this because you're still on railway property. Cross over the railway line to your left and follow the track along (with the train line now on your right).
Follow the track through to County Drive - they have recently removed the old white picket fence here so no need to go near the highway anymore.
Cross County Drive and continue along keeping the train line on your right. You will see a couple of old train signs as you ride along this section.
The line continues on behind the Wamuran Sawmill. There is a lot of woodchip on the track which can be a little difficult to ride through.
As you approach Wamuran you have two options:
1. You will see a short section of the track covered with coarse gravel about 300m before the D'aguilar highway overpass, cross the train line here and continue under the overpass. You will see an old mechanical thingy they used to move the trains onto a different track (sorry don't know what it's called). Go under the overpass (usually lots of rubbish here unfortunately) and you will come out at the National Serviceman's Park.
2. Continue straight ahead, the track will go down into a shallow gully and climb again and you will come out behind the old school house.
There is an IGA and a bakery in town if you're hungry/thirsty by this stage.
At the park you will see the old line continue into the carpark of the Wamuran Co-Op. That's about where it ends. You can continue along Station Rd and later Gamgee Rd and follow the course of the railway corridor which is now on your left through the trees.
When you get to the end of Gamgee Rd where it meets the D'aguilar highway there is a house. Between the house and the highway there is a track where the railway line use to go but I can't remember whether it's been fenced off or not. If not you should be able to ride along here into the forest and join up with the rail trail that runs through to D'aguilar.
I'd be happy to join you and show you along the trail. It's a good ride but I would like to see it turned into a formal Rail Trail. It would be a good Touristy thing and good for commuting between Wamuran and Caboolture.
Brad
- Paddles
Postby Paddles » Mon Dec 23, 2013 7:32 pm
- Orion
- Paddles
Postby Paddles » Fri Dec 27, 2013 2:38 pm
- Orion
Postby Orion » Fri Dec 27, 2013 2:57 pm
I've only done that bit from the end of Del Rosso Rd through to powerline easement once a couple of years ago. At the time I didn't feel like lifting the bike over the fence but it's good to know it's possible to get through. Most of the trail is reasonable although rough.
Sorry to hear about the flat. I'm not sure who dismantled it (Qld Rail or the Council) but either way they wouldn't really care what they left behind. You could try claiming negligence on their part and hit them up for a new tube
- Paddles
Postby Paddles » Fri Dec 27, 2013 3:45 pm
- singlespeedscott
Wamuran Rail Lines
Postby singlespeedscott » Fri Dec 27, 2013 4:22 pm
I too wish they would connect it all up officially. What would be really cool would be to run it all the way to Moore and connect it with the Brisbane Valley rail line and have it run all the way to Kingaroy and beyond.
- foo on patrol
Postby foo on patrol » Fri Dec 27, 2013 5:12 pm
Foo
Goal 6000km
- Orion
Postby Orion » Wed Jan 15, 2014 3:04 pm
Earlier I said that I wasn't sure if it was possible to access the old railway from the end of Gamgee Rd. It appears possible but looks like it may now be on private property. There was a open gate near the road but then another, closed gate, about 100m along. From what I could tell that gate had a chain and padlock.
The official rail trail from the end of Mylett St to Raaen Rd has had some work done to it recently. There were sections that were eroding due to small water courses crossing the track and then tumbling down into the gullies below. These sections have been redone with some gravel/rock and it's bloody awful. On the upside there are no longer any large pools of water to traverse.
- Paddles
Postby Paddles » Wed Jan 22, 2014 8:52 am
- Orion
Postby Orion » Wed Jan 22, 2014 11:16 am
- Orion
Postby Orion » Sun Jul 26, 2015 1:34 pm
Just thought I"d let you know in case you'd like at easy off road ride.
- roosta
Postby roosta » Tue Mar 01, 2016 11:02 pm
After being open for a few months now, the gate has been shut and padlocked again on the trail at the end of Del Rosso Rd.
This wasnt done by council or QR, but by a tow truck driver that used the trail to fetch a car that had come off the d'aguilar highway about 200m down the track.
The gate was open when he got there, but he took it upon himself to close and padlock it when he left, even getting a padlock out of his own truck.
I know this because i rode through as he was arriving, and came back through as he was locking it up and leaving.
One alternative (mentioned by Orion in a previous post) is to turn right at the end of the straight stretch of Del Rosso Rd, go through the small tunnel under the highway and through to Cayenne Rd. From there, go left onto Greening Rd, left again on to Williams Rd and back to King Street where you can turn right and join back up with Quarry Rd - and back onto the trail.
As you can see on the railtrails.org website, the closed/gated section is listed as 'Possible Rail Trail'
https://www.railtrails.org.au/index.php ... Itemid=216" onclick="window.open(this.href);return false;
89 Southern Cross Decathelon MKII
95 Giant YukonSE
96 Shogun Trailbreaker 3
09 Shogun Katana
