Road Pedals/Shoes on a 29er?
Postby WarbyD » Fri Jan 10, 2014 6:38 pm
Now, my predicament.. I quite liked the clipless pedal arrangement and intend to stick with it. I don't know if I'd be so keen to be clipped in when playing on the trails though, so am considering just taking my Shimano SPD-SL pedals from the cannondale and using those with my current northwave road shoes to commute on the 29er. Hunting around online I see lots of discussion about using SPD shoes on a road bike, but nothing about SPD-SL shoes on a MTB being used almost exclusively for commuting...
I know that the road shoes would be rubbish for anything offroad due to the lack of grip off-bike/poor mud clearing/etc etc, so would be intending to swap over to the stock flat pedals and use standard sneakers on the odd occasion I do go for a play on some trails. I think I can quite safely say that this would only be a temporary arrangement until I head out onto some trails and decide I want SPD shoes/pedals, but What are people's thoughts on this arrangement in the meantime? Any significant disadvantages? Any reason that I'm missing as to why I couldn't/shouldn't do this?
Re: Road Pedals/Shoes on a 29er?
Postby lobstermash » Fri Jan 10, 2014 6:53 pm
- trailgumby
Postby trailgumby » Fri Jan 10, 2014 8:54 pm
The upside is of course being able to dab when you need to. So I guess I'm pointing out that while flat pedals are a good idea when starting out riding off-road, they are not risk free and you are to a large extent replacing one set of risks with another, albeit different.
My skills acquisition phase may have been accomplished more quickly with flats as the fear of clipstacking on techy descending sections led me to walk a lot of stuff early on, but now I generally feel horribly insecure if I'm not clipped.
These days the only time I baulk on an obstacle on a xc trail is if I'm not sure I have enough momentum to get up a tricky step-up and don't like the risk of falling backwards from a height.
The only risk with road pedals on an mtb when commuting is getting funny looks from people like me
Howver when you do decide to venture off road with the 29er you will want double sided pedals for sure. Road pedals require too much concentration and force to clip into and you may not have the distance to do that before you need to negotiate a trail obstacle. The result is you'll end up walking a lot more than necessary and miss out on the sense of accomplishment from having pedalled your way over a fun bit of track.
Sent from my android thingy using Crapatalk
Postby alexander » Mon Jan 13, 2014 9:23 am
Postby WarbyD » Tue Jan 14, 2014 10:13 am
For now, I'm just riding on the stock flat pedals with sneakers.. Hasn't actually made as much difference as I expected it to lol so not going to bother with putting the spd-sl pedals on, but still tossing up whether or not to go SPD..
Postby alexander » Tue Jan 14, 2014 1:07 pm
Also with the pedals, it's just user preference. Candy's are no better, no worse than the Shimano SPD SL's. Just a different offering, that I thought might better suit your needs.
- TonyMax
Postby TonyMax » Tue Jan 14, 2014 1:21 pm
If you're used to some form of cleat/pedal I'd say get some for all your bikes, unless the type of riding you're doing has extended downhill/coasting periods where you're just standing on the pedals.
Tony
- queequeg
Postby queequeg » Tue Jan 14, 2014 2:07 pm
I have two pairs of shoes, a road pair (RT-31s) and a commuter pair (MT42s).
The single biggest reason I like them is that the SPD cleat is recessed into the sole of the shoes, so I can walk around normally without destroying cleats or doing a duck waddle. They are also far easier to use for commuting where I need to constantly clip and unclip.
Postby WarbyD » Tue Jan 14, 2014 2:32 pm
- trailgumby
Postby trailgumby » Tue Jan 14, 2014 8:58 pm
For e xa ple, why would you not have a reverse thread on the RH pedal retaining nut? When the bearings die because the seals are so rubbish and they have only a cheap plastic bush on the inside that wears fast, the nut unscrews itself and the pedal falls off. Doesn't happen to everyone but it does happen a lot. Not nice when you're 10km from the nearest road. The springs also wear and get soft.
Shimanos on the other hand weigh a bit more but are bullet proof. You never have to touch them except for replacing cleats every couple of years.
Postby WarbyD » Sun Jan 19, 2014 3:08 pm
Sent from my C6903 using Tapatalk
- trailgumby
Postby trailgumby » Sun Jan 19, 2014 3:22 pm
Postby WarbyD » Fri Jan 24, 2014 2:37 pm
First ride in on them this morning.. extended my usual 15km commute to 30km. Certainly no complaintstrailgumby wrote:Let us know how you get on
- trailgumby
Postby trailgumby » Mon Jan 27, 2014 10:44 am
Postby WarbyD » Tue Jan 28, 2014 10:01 am
Was getting some numbness in my toes on the ride home on Friday, advised to not do the straps up so tight and see how it went.. Had them looser today, took a few adjustments during the ride to find a spot that didn't cause numbness but still felt tight enough and was happy days when I found it
