Trainer Vs Actual Ride
Postby vikramranna » Thu Jan 16, 2014 9:11 pm
Only recently I have started riding and am immense let enjoying it. I just completed my first 75Km ride and am hoping to gradually increase it so that in the next few months I can do a 200Km ride.
As part of my training I am following Scody 3 peaks challenge training that is available on their website. As per thier training plan it has 2 days of riding on indoor trainer and 2 days actual ride on weekends. Due to time constraints I can only do 1 actual Ride on the weekend but do squeeze in the indoor training in weekdays.
The question to other riders is, are there any advantages of training on a trainer or should I actually go on the road instead of indoor training.
Any feedback, suggestions would be great.
Vikram
Re: Trainer Vs Actual Ride
Postby slian » Thu Jan 16, 2014 9:23 pm
If I can add another one, is it possible to do the workouts from the plan on a roller or must it be a turbo?
Postby neild » Thu Jan 16, 2014 9:34 pm
Postby you cannot be sirrus » Thu Jan 16, 2014 11:03 pm
As boring as batshit but a very useful tool if time is an issue.
- nickobec
Postby nickobec » Fri Jan 17, 2014 12:03 am
Depends on where you ride, my commute has 18km of relative flat uninterrupted shared path ( no cars, no pedestrians, (except 500m a few km from end) so that is my training section, great for threshold session and intervals.you cannot be sirrus wrote:An hour on the trainer is worth two on the road IMO. No coasting, no stopping for lights, no distractions, no downhills.
It is all a case of finding the right roads and building training plans around them.
+1 I am stuck on a trainer at the moment, broken clavicle, and find it boring and mind numbing, at the moment it is all threshold and VO2 intervals as I do not want to stay on the bike than absolutely necessary. So no endurance sessions.you cannot be sirrus wrote:As boring as batshit but a very useful tool if time is an issue.
I have a decent trainer, lots of entertainment and I avoid the trainer unless absolutely necessary (like now).
Pros of trainer:
Easier to ride planned training sessions
Avoid bad weather, riding at night
Still ride if time poor or commitments requiring you to be at home
Cons
Boring
Not exactly like the road,
I sweat heavily and down about 5% in power in comparison to the road.
- foo on patrol
Postby foo on patrol » Fri Jan 17, 2014 7:25 am
Foo
Goal 6000km
Postby macca33 » Fri Jan 17, 2014 8:06 am
- Xplora
Postby Xplora » Fri Jan 17, 2014 9:34 am
Welcome to cycling. The trainer is a necessary evil, like nuclear weapons and chain cleaning.
Postby vikramranna » Fri Jan 17, 2014 10:03 am
Also on a trainer i seem to get pretty tired within 20 mintues even though i am only doing recovery rides (about 90rpm's) but if i go on a road ride i seem to be able to do longer rides without feeling like i am about to die . Is this common?
- g-boaf
Postby g-boaf » Fri Jan 17, 2014 1:15 pm
I'm thinking of fixed rollers and not the ones like Xplora is talking about.
- RonK
Postby RonK » Fri Jan 17, 2014 2:52 pm
Want to take the enjoyment out of cycling and demotivate yourself - just jump on a trainer.vikramranna wrote:Only recently I have started riding and am immense let enjoying it.
- Xplora
Postby Xplora » Fri Jan 17, 2014 6:38 pm
Yep, you REALLY need a good reason to get on the trainer to make it worthwhile.RonK wrote:Want to take the enjoyment out of cycling and demotivate yourself - just jump on a trainer.vikramranna wrote:Only recently I have started riding and am immense let enjoying it.
Postby vikramranna » Fri Jan 17, 2014 6:41 pm
Postby thearthurdog » Sat Jan 18, 2014 6:34 am
- toolonglegs
Postby toolonglegs » Sat Jan 18, 2014 7:15 am
Moi, je deteste le home trainer!. Actually it is painful not in a good way to ride my trainer... Maybe the flywheel needs to be bigger, I am not sure but it injures my hammies.
Much prefer rollers... Time passes quicker!
Postby zill » Sun Apr 06, 2014 10:57 pm
There are some realistic feeling trainers out there but I have realised after using trainers that it's the sensation your brain and face (and the rest of the body) feels when you move about on a bike that really make riding enjoyable.
- trailgumby
Postby trailgumby » Sun Apr 06, 2014 11:01 pm
+1. But I still have a trainer, and I use it.zill wrote:I found riding on a trainer so boring that I use to say that I will only use a trainer after I die.
- toolonglegs
Postby toolonglegs » Mon Apr 07, 2014 6:32 am
Postby sambo3 » Mon Apr 07, 2014 9:29 am
I agree with toolonglegs, they are much more like the road having come from trainers but I still get bloody bored on these.
You do have to concentrate and you have some movement but in the end its still a roller to nowhere.
I find setting up the laptop connected to a big screen works best.
I have been using these for intervals and simulating long climbs.
45 minutes though and I'm pretty much done. I need to extend this to an hour plus.
For more resistance I use a folded towel under the rear rollers.
- Derny Driver
Postby Derny Driver » Wed Apr 16, 2014 3:58 pm
Young DD has one the same as this in the garage. He uses it almost every night. Even when he does a road ride he jumps on it for a warm down.
In my opinion, no factory produced trainer goes close to these for feel. Unashamed plug for this, the last of 3 which my mate built.
http://www.ebay.com.au/itm/321375503796 ... 1423.l2649" onclick="window.open(this.href);return false;
- g-boaf
Postby g-boaf » Wed Apr 16, 2014 9:49 pm
Weather will get me on the trainer at home, or if I'm told to do 1 hour, I'll do it. Otherwise I'll use a computrainer with perfpro studio down the road from where I work for convenience of getting good training done quickly. It's the only way I can get that done with the time limits I have.Derny Driver wrote:I must admit I had to be desperate to get the indoor trainer out. 4 or 5 days of rain would force me onto it. Mind you it was a crappy mag trainer.
Trainers are harder than road riding I think - no coasting. It's just hard work. On a road ride, you get interruptions like traffic lights, traffic, etc. It's amazing what kinds if torture some people can inflict on you with a computrainer.
