Show us your super light road bike
- singlespeedscott
Re: Show us your super light road bike
Postby singlespeedscott » Mon Jan 13, 2014 12:10 pm
- biker jk
Postby biker jk » Mon Jan 13, 2014 2:03 pm
Don't be tempted. Given you weigh next to nothing, on that light bike a gust of wind will blow you away.g-boaf wrote:Blimey! 4.94kg!! I want to know what it is like to ride a bike that light. With the slightest effort the thing must explode away.lannes wrote:Litespeed Ghisallo
Those wheels alone are amazing.
- g-boaf
Postby g-boaf » Mon Jan 13, 2014 2:34 pm
I went looking at those wheels. Now I'm not interested in them. Damn nice wheels, damn expensive! They seem to be the same price as my whole bike (sans the wheels BikerJK saw).singlespeedscott wrote:I reckon the bank account would be looking pretty "light"as well.
Oh don't worry - the bank balance will prevent that. I need to get a hell of a lot faster and fitter before I can justify anything lighter or better. Now it's all hard work.biker jk wrote:Don't be tempted. Given you weigh next to nothing, on that light bike a gust of wind will blow you away.g-boaf wrote:Blimey! 4.94kg!! I want to know what it is like to ride a bike that light. With the slightest effort the thing must explode away.lannes wrote:Litespeed Ghisallo
A slight kitchen appliance crisis also prevents any further bike spending apart from the basics.
Postby lannes » Mon Jan 13, 2014 9:52 pm
TriRig Mercurywarthog1 wrote:What pedals are they?
http://www.tririg.com/articles.php?id=2 ... ury_Pedals" onclick="window.open(this.href);return false;
Postby lannes » Mon Jan 13, 2014 9:56 pm
Definitely accelerates easily, easy to keep up at speed.g-boaf wrote:Blimey! 4.94kg!! I want to know what it is like to ride a bike that light. With the slightest effort the thing must explode away.lannes wrote:Litespeed Ghisallo
Major draw back is the lightness of the front end, the wind lifts it up quite easily with the 40mm profile wheels, so you need to keep a watch out. Also front end tracking over bumps is less sure
Postby lannes » Mon Jan 13, 2014 9:57 pm
Thanks very much, it's just a frame I got back in 2007 that I have upgraded over time, with newer parts.Cul wrote:Lannes, saw this on the Weight Weenies forum yesterday evening, beautiful looking bike.lannes wrote:Litespeed Ghisallo
Postby lannes » Sat Jan 18, 2014 7:59 pm
I'll ride it for a while and then cut the fork to lower the front end by 10mm and get rid of a spacer, but it's finally finished.
- mitchy_
Postby mitchy_ » Sat Jan 18, 2014 8:04 pm
mine's nice and light in this configuration. will be under 7kg once finished, including hydraulic disc brakes.
Postby jasonc » Sat Jan 18, 2014 9:10 pm
looks great mitch. what size frame is it?mitchy_ wrote:is it just me, or is your brake pad upside down?
Postby lannes » Sat Jan 18, 2014 10:03 pm
Nice build, why are you using cross stop levers ?mitchy_ wrote:is it just me, or is your brake pad upside down?
The Ciamillo pad holders are junk, you have to mount then upside down when you use the Reynolds Cryo blue pads, as they is nothing to hold the pads in and they get ejected if the holders are the right way up.
- mitchy_
Postby mitchy_ » Sat Jan 18, 2014 10:34 pm
thanks! it's a 53cm (540 ETT)jasonc wrote:looks great mitch. what size frame is it?
i'm not, i did however originally have it built up as a flat bar commuter, with Hope hydraulic mtb brakes. but now i have decided to go the whole hog with drop bars and a Hope V-Twin setup, so i'm keeping the original calipers and the line was already routed through the frame. only item that isn't carbon now is the saddlelannes wrote:Nice build, why are you using cross stop levers ?
original build
Postby lannes » Sat Jan 18, 2014 11:17 pm
- g-boaf
Postby g-boaf » Sun Jan 19, 2014 7:25 pm
That is a beautiful bike. I thought I recognised the brake calipers - I almost ordered them myself.lannes wrote:Just finished the build, added the Enve 1.0 fork, the Cane Creek AER Headset and the AER spacers, used lighter bar tape and cut 1cm off the bars , these changes drop it by another 90 grams.
My Giant TCR Advanced SL3 (Medium) has these calipers on it:
These are the same brake calipers as that BMC seen recently in this very topic. Quite pleased with them. They work well. Not too costly either.
It is 7.45kg with everything on it, and a bit more with Garmin on it.
Postby lannes » Sun Jan 19, 2014 9:38 pm
Nice calipers and bike, the Ciamillo's, I've got are over rated, hard to set up and too expensiveg-boaf wrote:lannes wrote: My Giant TCR Advanced SL3 (Medium) has these calipers on it:
Postby kingswood » Mon Jan 20, 2014 7:24 pm
Hi Mitchy. Both versions look great.mitchy_ wrote:thanks! it's a 53cm (540 ETT)jasonc wrote:looks great mitch. what size frame is it?
i'm not, i did however originally have it built up as a flat bar commuter, with Hope hydraulic mtb brakes. but now i have decided to go the whole hog with drop bars and a Hope V-Twin setup, so i'm keeping the original calipers and the line was already routed through the frame. only item that isn't carbon now is the saddle :lannes wrote:Nice build, why are you using cross stop levers ?
What wheelset is that on the original version?
- mitchy_
Postby mitchy_ » Mon Jan 20, 2014 11:50 pm
Thanks! They are Crank Brothers Cobalt 3's. Not light by any standard as they're a 29er mtb wheel, but they were pretty!kingswood wrote:Hi Mitchy. Both versions look great.
- biker jk
Postby biker jk » Tue Jan 21, 2014 10:32 am
http://theteamrobot.blogspot.com.au/201 ... ot_20.htmlmitchy_ wrote:Thanks! They are Crank Brothers Cobalt 3's. Not light by any standard as they're a 29er mtb wheel, but they were pretty!kingswood wrote:Hi Mitchy. Both versions look great.
Postby kingswood » Tue Jan 21, 2014 6:56 pm
Postby adamr » Wed Jan 22, 2014 3:42 pm
- ldrcycles
Postby ldrcycles » Thu Jan 23, 2014 10:36 am
Hell one of mine would be about that for just the frameset and front wheel!rheicel wrote:Mine is 4.9 kg too, but excluding wheelset and crankset
- flex5150
Postby flex5150 » Wed Jan 29, 2014 11:23 pm
My guess was 6045gadamr wrote:At Garmin stand at the the TDU village in Adelaide there is a competition to guess the weight of a Cervelo Rca to the nearest gram. It has Lightweight Obermeyer wheels, schmolke seatpost and, I think, seat, Tune stem and cranks, Red 22 group. I am trying to work out the weight. Certainly low 5kg at most. Possibly under 5 as it has no pedals. I will try to post a photo tonight.
Giant PROPEL SL RED22.
BMC SLR01 '18 E-TAP
Postby pawnii » Sun Feb 02, 2014 10:12 pm
2012 Scott Foil Premium
- QuangVuong
Postby QuangVuong » Sat Feb 08, 2014 11:44 pm
- g-boaf
Postby g-boaf » Fri Feb 14, 2014 2:49 pm
I've got a medium TCR Advanced SL1 on order, 2014 model to replace the written off SL3. It is 6.6kg before adding bidon cages and pedals. It has Dura Ace 9000 mechanical groupset (11 speed). I was going to consider another Di2 bike, but I've heard good reports on DA9000 so I'm giving it a go.
My Trek Madone 4.5 will be converted over to Ultegra Di2 with the components from the Giant TCR SL3. The front left shifter will need to be a new one. The rest will be okay.
- QuangVuong
Postby QuangVuong » Fri Feb 14, 2014 4:28 pm
If you dont mind me asking, what happened to your Giant?
