Dyno Hub Device Recharging
- rifraf
Re: Dyno Hub Device Recharging
Postby rifraf » Tue Jan 07, 2014 1:09 pm
I'm sure thats a informative spiel but it went right over my head.
I tried a Babelfish translation but wasnt sure what language was used.
Any chance of a very condensed version in extreme laymens terms of your electrickery experiment?
How are you getting on with that 23,000mAh battery
Have you had a chance to try charging it lower than 15v
- il padrone
Postby il padrone » Tue Jan 07, 2014 2:00 pm
'Twas the same for me but I didn't want to say I was not copingrifraf wrote:G'day Daggo,
I think this bit was the summary to use:rifraf wrote:Any chance of a very condensed version in extreme laymens terms of your electrickery experiment?
Charging a phone I'd leave the "Voltage Controller" inline. If you want to charge a battery and it can handle between 4V to 7V then remove the "Controller"
- RonK
Postby RonK » Tue Jan 07, 2014 2:16 pm
Postby Daggo » Tue Jan 07, 2014 2:33 pm
The 7 Watts advertised is in the real world about 1½ Watts if you use the inline "Voltage Controller". The "Voltage Controller" makes sure that the voltage, that you plug your expensive phone into, will stay at 5 volts (5 volts is the USB standard which is what charges your phone).
If you don't have the "Voltage Controller" inline then the raw output from the panels is there. So at midday in full sun, with the panels at the just the right angle you might get 6 to 7 volts. Which might not be good for you expensive phone. But there will be more watts for you to use to charge things. About 2½ Watts
The "Voltage Controller" needs some power to run itself (plus that little light on the side so you can feel good that it's working). And the cost for that is about a 1 watt. I didn't test what happens to the output of the "Voltage Controller" if the input is below 5 volts (like on cloudy day or in forest) will check that later. So like I said:
I did a quick test of the 23000mAH battery as I had forgot to do it No you don't need 15V to charge it! It will try to charge down to 3.5V but the charging circuits won't start till around 6.5V. So to be safe I'd say from 7 volts up. Here is another But. But I don't know if it will start charging when the battery is flat (below 25%) at less then 15 volts. I'll flatten it today and test that tonight.Charging a phone I'd leave the "Voltage Controller" inline. If you want to charge a battery and it can handle between 4V to 7V then remove the "Controller".
Now I know that the battery is NOT a 23AH (1000mA = 1A). Here is a picture of a 8.4 AH (8400mAH) 13.2 Volt LiFePo battery.
And it weighs 1 kg. So based on weight alone there is no way that there is a 23AH battery in the S23000.
Another got ya for the S23000 is the LiPo batteries in the thing. LiPos are very fussy things. They need very controlled, strict charging conditions. Do we remember all those Dell laptops catching fire???? If I know I not going to be using my LiPos (like the one in the picture) for a few weeks I will charge them in a "storage" state. I have a flash battery charger that will do that for me. And when I am going to use them I give them a proper charge the night before so they are ready to go. Storage charging will increase the life of the batteries.
In the S23000 there is nothing that smart for managing the batteries so I'd expect a useful life of about 1½ ~ 2 years before it won't hold a charge. Much like the batteries in your phones or laptops. They last for every when the things a new but after a few months.....
Here is some light reading on LiPo batteries.
Daggo.
- il padrone
Postby il padrone » Tue Jan 07, 2014 3:34 pm
So you are suggesting my nice Powermonkey Extreme is not the stated 9000mAH ???
It is specified as this, with a 5v 700mAH USB output, and a 5v 2.1A seperate cable-jack output.
Postby Daggo » Tue Jan 07, 2014 4:25 pm
Also Powermonkey spend some money on proper RD and designed the thing right. Not like the S23000 slapped together in China somewhere. And 9Ah is a lot less then 23Ah.
Edit:
Did some number crunching. The blub with the S23000 says "23000AH or 85WH" I dunno how they get those figures. If I use the 85 Watts and 12 Volts I get 7.1A (7100mA). If use the 5 Volts I get 17A (17000mA). The only way I can get 23A (23000mA) is if the voltage is 3.7 Volts. And 3.7 Volts is what a 1 cell LiPo battery is. So maybe the S23000 has only one LiPo cell in it. A single 2200mAH cell weighs about 80gms and it would take 10 of them for 22000mAH, which is 800gms. There goes the weight.
Postby jemo27 » Wed Jan 15, 2014 10:38 am
Is that what you are talking about when you suggest a battery to charge from your dynamo
- rifraf
Postby rifraf » Wed Jan 15, 2014 12:54 pm
Hi Jemo27,jemo27 wrote:I saw these in Jb hi if http://www.jbhifionline.com.au/mobile-p ... lue/695694" onclick="window.open(this.href);return false;
yes, thats the sort of thing we've been talking about but really, ones with a lot more grunt.
Notice the mAh figure you link to (6600)? It would still make a working cache battery, but I'd personally aim a bit higher on the mAh stakes.
Postby jemo27 » Sun Jan 19, 2014 4:29 pm
It's made by the same company that makes ewerk but is only USB and has a built in battery.
- rifraf
Postby rifraf » Sun Jan 19, 2014 4:44 pm
Hi Jemo,jemo27 wrote:USB-werk anyone used this?
Few thoughts:
I think its a short sighted approach.
Last I looked it wasnt significantly cheaper than the standard E-werk.
http://www.bike24.com/1.php?content=8;n ... duct=12776" onclick="window.open(this.href);return false;
http://www.bike24.com/1.php?content=8;n ... duct=38306" onclick="window.open(this.href);return false;
Yes with the standard e-werk your probably up for the extra cost of a cache battery but, and its a big but, you get to choose which size which size battery you get.
The standard E-werk can be set to power different voltages and amps.
This is unlikely to be significant currently but already we see there are different standards of USB.
The iPads as an example prefer a higher draw of power than say your average mobile phone.
With the standard E-werk, you can charge, albeit slowly, some larger ticket items than just phones or gps's.
I guess what I'm suggesting is that there is greater potential future proofing with the standard unit.
I'm going to be buying yet another recharging unit shortly for my Extra-wheel trailer build.
At this stage, having looked at the current crop of competition, I'm inclined to fork out for a second standard E-werk.
Others requirements and opinions are likely to be different.
Postby jemo27 » Fri Jan 24, 2014 5:34 pm
- rifraf
Postby rifraf » Sat Jan 25, 2014 12:00 am
Well there is a lot to be said for ease of use.jemo27 wrote:Rifraf you make sensible points. It just seems to me the the USB-werk is simpler to use but I will do more research before deciding
I didnt find the E-werk (standard) hard to set up once I'd carefully read the instructions about what to set it to with the cache battery but admit to being lucky in that I'm not really a details person and really was only interested in the outcome of being able to charge my junk and I dont give a monkeys about how it works.
I think it would have been easy to stuff it up if I'd approached it in a rush or in the wrong frame of mind.
I've heard a few tales of woe from people who've fried a few things by setting it up wrong.
- RonK
Postby RonK » Mon Jan 27, 2014 9:59 am
And if that is not big enough there are lots of 70,000 mHa batteries becoming available now. Here's an example.
- Tim
Postby Tim » Mon Jan 27, 2014 10:57 am
What is also interesting is that these batteries will accept up to 10 Watts input (5Volts, 2 Amps). They will recharge twice as quickly as most of the USB type rechargeable batteries around. Most will only recharge at standard USB, 5 Volts, 1 Amp (5 Watts).RonK wrote:limeade have recently released a 24000mAh version of the limeade blast. Interestingly this battery has a 2.1 amp USB port so it can be used to charge an iPad - and an iPhone at the same time.
Not quite as good as my Minigorilla, it recharges at 9 Volts, 1.2 Amps, 10.8 Watts.
Heaps cheaper than the Minigorilla and a good range of different capacity models, I like them. I can see one in my kit some day.
These batteries are ideal for touring and charging off the dynohub. Most hubs can produce up to 18 Watts output at 15KPH and faster.
A big day, or two shorter days on the road would see one of them fully recharged.
Postby irrelevant_apple » Mon Jan 27, 2014 1:16 pm
http://www.fasttech.com/search?Enb%20battery
http://www.fasttech.com/products/0/1000 ... ble-li-ion
coupon code BLF for 5% off
the predecessor model tested and reviewed http://budgetlightforum.com/node/22752
- Tim
Postby Tim » Mon Jan 27, 2014 1:35 pm
irrelevant_apple that little twin ENB battery charger/recharger looks very usefull.
My mind is swirling with all the possibilities.
Ron, I note the limeade battery has "anti explosion protection".
Just what I need for the next time I ride into the back of a Federal Policeman.http://www.bicycles.net.au/forums/viewt ... l#p1078016
Postby irrelevant_apple » Mon Jan 27, 2014 2:20 pm
edit: the old one that can is available here http://www.buyincoins.com/item/25240.html
code: 2dropper2014
recommender: discounter
for 5% off
- il padrone
Postby il padrone » Mon Jan 27, 2014 10:05 pm
Beware, some of these batteries may lack the durability required in their charging connections to survive a bouncing in your handlebar bag. Certainly Kogan's 11,000 mAH battery with its 1 amp and 2.1 amp port did - the input charging port failed on my recent 8 day tour. The Powermonkey Extreme has stood the test of time - seems much more robustly built ie. for adventure travel uses.RonK wrote:limeade have recently released a 24000mAh version of the limeade blast. Interestingly this battery has a 2.1 amp USB port so it can be used to charge an iPad - and an iPhone at the same time.
Postby irrelevant_apple » Tue Jan 28, 2014 3:09 pm
the triple enb has lasted a few months now in my top tube bag for a phone as a bike computer. It does pause after a large bump but resumes automatically.il padrone wrote: Beware, some of these batteries may lack the durability required in their charging connections to survive a bouncing in your handlebar bag.
I'm going to try the old double and see how it goes. If it works well I plan to combine it with a Instapark 10 watt solar panel for touring http://www.outdoorgearlab.com/Solar-Cha ... Mercury-10. With the double for actively keeping the phone computer alive and other minor devices. The triple on the instaparks second usb output as extra spares for my 1x18650 torch. By my mental model it should be enough power
- il padrone
Postby il padrone » Tue Jan 28, 2014 9:25 pm
By "lacking durability" and "the input charging port failed", I mean the connector broke off while connected to my phone for charging. I now have a fully charged lithium that I cannot recharge. I am not skilled enough to attempt a repair job. In summary, it is a fine battery for indoor use, not in a pack or bouncing bag.irrelevant_apple wrote:the triple enb has lasted a few months now in my top tube bag for a phone as a bike computer. It does pause after a large bump but resumes automatically.il padrone wrote: Beware, some of these batteries may lack the durability required in their charging connections to survive a bouncing in your handlebar bag.
Beware cheap batteries not fit for your use.
- Aushiker
Postby Aushiker » Tue Jan 28, 2014 10:52 pm
That is handy to know. I think the extra $ are worth it for a decent standard of reliability and product features. Nothing worse that having a failure when you really need it.Tim wrote:Not quite as good as my Minigorilla, it recharges at 9 Volts, 1.2 Amps, 10.8 Watts.
Aushiker.com
Postby jemo27 » Sat Feb 01, 2014 3:50 pm
I'm wondering what battery I should get, any suggestions?
- il padrone
Postby il padrone » Sat Feb 01, 2014 4:20 pm
- RonK
Postby RonK » Sat Feb 01, 2014 5:52 pm
If you look back just a few posts, you'll see that I suggested a Limeade Blast. That's what I may use for my iPad Mini.jemo27 wrote:I'm wondering what battery I should get, any suggestions?
The point in using a Mini is defeated if the battery is bigger and heavier than the device.
It's debatable if a battery is needed all - with 10 hours of battery life the Mini will last me 20 days when used with care.
Postby jemo27 » Sun Feb 02, 2014 7:38 pm
I'm still deciding if it's worth carry all these extra gadget but it does get annoying having to find a power point every so often.RonK wrote:If you look back just a few posts, you'll see that I suggested a Limeade Blast. That's what I may use for my iPad Mini.jemo27 wrote:I'm wondering what battery I should get, any suggestions?
