Tyre life?
- mitchy_
Re: Tyre life?
Postby mitchy_ » Mon Jan 27, 2014 11:50 am
i'm not sure where you came up with the 3-6 month idea either, given your twice a week routine of 32km each way, that's roughly 6600km which would likely be one set of tyres.
Re: Tyre life?
Postby Stefan_A » Mon Jan 27, 2014 12:25 pm
Re: Tyre life?
Postby mick243 » Mon Jan 27, 2014 12:39 pm
Use quality tyres, use appropriate pressure, keep an eye out for damage (large punctures, cuts etc) and you will be ok. Change tyres before the threads are showing, but only just...
Re: Tyre life?
Postby tekapo » Mon Jan 27, 2014 12:44 pm
I don't think any one can give you a definitive answer. There are just so many variables.worzel wrote:Yep, 32km which is why I only do it twice a week. It is also behind my question - if I have a tyre bulge (had it happen a few times way back in my teens) its a long walk home so I would consider changing the tyre if it had clocked up a lot of km even if it showed no major signs of wear.rkelsen wrote:So your commute is >30km each way?
I could probably walk to a station in an hour from anywhere on my route but rather not. Whether I ride or get the train I leave home about 6.30 and get home about 6pm so my only chance to buy a spare is at the weekend. And if it is a weekend I am away diving etc it could take me weeks to get back on the bike.
Or put it this way, there are people with Marathon Pluses that never gets a puncture, but then there are people who gets one a few hundred ks in. Using better tires and replacing it often will reduce the probability of you getting a flat, but it will never be a guarantee. If you are concerned, I would suggest carrying a pump, tube or patch, and tire levers with you.
- Duck!
Re: Tyre life?
Postby Duck! » Mon Jan 27, 2014 6:25 pm
- Aushiker
Re: Tyre life?
Postby Aushiker » Mon Jan 27, 2014 8:51 pm
I last used a Vittoria Zaffiro Pro 700c x 23 back in 2008/2009. On the front of my commuter at the time I got 4,257 km out of it, which was pretty good in hindsight.Duck! wrote:The Zaffiro isn't a particularly soft tyre. 5000km would be easily achievable on a rear, double on the front.
Aushiker.com
Re: Tyre life?
Postby Lurkin » Sat Feb 01, 2014 5:34 pm
I have recently switched to the Schwalbe Lugano as:-
- it has lower rolling resistance to the zaffiro
- I got them for a similar price (aud 13, instead of 11 for the zaffiro)
- they are much easier to get on and off the rim
- it has a lower rolling resistance with less pressure, which means when I get a flat, less work with the hand pump
they are not really comparable to some of the other tyres in this thread because:-
- a touring tyre, like a marathon plus, is typically much more expensive per tyre
- they also have considerably higher rolling resistance
- rheicel
Re: Tyre life?
Postby rheicel » Sat Feb 01, 2014 7:09 pm
Re: Tyre life?
Postby Lurkin » Sun Feb 02, 2014 4:35 pm
checked the garage - still got 2x zaffiros sitting there.
Probably will keep riding on the luganos until I get through them. Frankly, I think they are fine for commuting on, but perhaps they are no good for more extreme riding?
- il padrone
Re: Tyre life?
Postby il padrone » Sun Feb 02, 2014 11:36 pm
Marathon Plus is not a touring tyre. It is super-tough and very heavy - much better suited as a heavy urban commuter tyre. They are very popular for e-bikes.Lurkin wrote:- a touring tyre, like a marathon plus, is typically much more expensive per tyre
For a quality touring tyre you would be much better off with the lighter Marathon Supreme (not so puncture protected) or the world-travelling Marathon Mondial (succesor to the tried and tested Marathon XR). Duremes are also very highly regarded. I also use the Vittoria Randonneur Cross and Randonneur Pro all of which have excellent puncture resistance, and the Continental Travel Contacts are also well-regarded.
All of these tyres are much lighter and better rolling than the Marathon Plus.
Re: Tyre life?
Postby mick243 » Mon Feb 03, 2014 9:33 am
So, the bead has separated from the rim.... Was the pressure too high, was the tyre the right size for the rim (including width), were you kinda fast and riding your brakes thus overheating the rim and making the bead more stretchy?rheicel wrote:Had this one on my new 300km Old Lugano. This happened after 500 m descend.
None of the above are the tyres fault.
- rheicel
Re: Tyre life?
Postby rheicel » Mon Feb 03, 2014 10:14 am
Wheelset is Shimano 7801 with standard 700C Rim. Tyre is 700x23.
I am riding on that same road at the same speed for many many times now using the same rim.
Possibly rim tyre combination problem.
Re: Tyre life?
Postby ironhanglider » Mon Feb 03, 2014 4:36 pm
And not possible to have an installation error?rheicel wrote:Pressure is 100 PSI, tyre specs says 90 PSI minimum.
Cameron
Re: Tyre life?
Postby stanzarallyman » Tue Feb 04, 2014 1:17 pm
I know that under the rubber is an orange band of puncture protection goodness. I dont throw the tyre out until the orange bank goes all around the tyre.
- InTheWoods
Re: Tyre life?
Postby InTheWoods » Tue Feb 04, 2014 1:55 pm
They're not that bad in 25mm format!! Never had a flat with them with over 10000km of commuting on them. Last forever. I'll take that over a 0.2 (or whatever) kmh penalty on a commuter.il padrone wrote:Marathon Plus is not a touring tyre. It is super-tough and very heavy - much better suited as a heavy urban commuter tyre. They are very popular for e-bikes.
Re: Tyre life?
Postby warthog1 » Fri Feb 07, 2014 3:51 pm
Re: Tyre life?
Postby tekapo » Fri Feb 07, 2014 4:05 pm
Re: Tyre life?
Postby Lurkin » Sat Feb 08, 2014 4:07 pm
http://commutercycles.com.au/accessories/tyres/" onclick="window.open(this.href);return false;
Re: Tyre life?
Postby Fletcher » Sat Feb 08, 2014 4:39 pm
I retired a Zaffiro from the rear of my bike recently after about 7,000km. It was down to the canvas. Surprisingly, only two flats in that distance.
Edit. To be precise, it was a 23mm Zaffiro Slick model.
- jacks1071
Re: Tyre life?
Postby jacks1071 » Sun Feb 09, 2014 10:47 pm
They are very durable, only warning is they are sketchy in the wet but other than that - awesome value for money.Fletcher wrote:Duck! wrote:The Zaffiro isn't a particularly soft tyre. 5000km would be easily achievable on a rear, double on the front.
Re: Tyre life?
Postby worzel » Mon Mar 10, 2014 10:41 pm
Re: Tyre life?
Postby ironhanglider » Mon Mar 10, 2014 11:09 pm
Has the tyre failed? Or was it a blow-off like in rheicel's picture.worzel wrote:Whoever was closest to 1700km wins. I thought I had been shot at when it popped on the way home tonight! To be fair, I don't know whether the tube exploded and took the tyre with it or whether the tube went because the tyre failed.
Most (not all) blow offs are the result of an installation error. They do not always happen at the time of initial inflation.
Cameron
Re: Tyre life?
Postby mick243 » Tue Mar 11, 2014 11:12 am
The tube is only there as a seal, it's the tyre that does the job of holding the pressure... So you can be 99% certain that the tube went because the tyre failed - the big question is why...worzel wrote:Whoever was closest to 1700km wins. I thought I had been shot at when it popped on the way home tonight! To be fair, I don't know whether the tube exploded and took the tyre with it or whether the tube went because the tyre failed.
Got pictures of tyre, tube and rim? You hadn't worn the rubber off and through the cloth layer had you? Damaged the bead with tyre levers? Worn the bead out changing multiple punctures? Had big punctures or tyre cuts that damaged the tyre casing?
What tyre, what rim, what pressure (cold) what temperature of day?
Does sound to me like possible installation error, or a possible "dud" you're, they shouldn't bulge and blow out for no good reason - I haven't had that happen in over 30 years of cycling... I have had tyres fail because of excess wear, maintenance failure (brake adjustment out, rubbed sidewall) incorrect seating on the rim, bought the cheapest tyre I could find, over pressurised then rode on a hot day.....
Re: Tyre life?
Postby worzel » Tue Mar 11, 2014 12:29 pm
