STI cable detatched?
Postby nezumi » Tue Jan 28, 2014 6:45 pm
Got out of the carpark ok. Rolling along the road I shift down, all good. Pull up at the lights and shift up as I approach... nothing. Move off and try shifting some more, no joy. Feels like I have one click each way and that's it, and my rear mech just seems to be doing its own thing, eventually settling on the smallest cog.
I am guessing that my rear shift cable has become unseated somehow - does this sound right?
If so, is there an easy way to check/fix it, or am I up for a trip to the mechanic?
For reference, my levers/drivetrain is Shimano 105 - 5700.
2015 Merida Scultura 5000
- RonK
Postby RonK » Tue Jan 28, 2014 6:53 pm
Re: STI cable detatched?
Postby ironhanglider » Tue Jan 28, 2014 7:15 pm
If so then the cable has broken or you have problems with the shifter.
If not then it may have just slipped.
Cameron
- Duck!
Postby Duck! » Tue Jan 28, 2014 7:44 pm
- Derny Driver
Postby Derny Driver » Tue Jan 28, 2014 7:48 pm
Don't fiddle with the lever, take it to the LBS.
- Tim
Postby Tim » Tue Jan 28, 2014 9:27 pm
Less than six months and less than 5000km's.
Doesn't seem like great mileage for a super-dooper Dura Ace polymer coated inner.
Postby R12RT » Tue Jan 28, 2014 11:12 pm
Took about 30 minutes to get the frayed ball end out of the shifter.
About 10 minutes to install the new cable and adjust the derailleur.
2010 Malvern Star Oppy C6
2014 Giant Propel Advanced 1
- Derny Driver
Postby Derny Driver » Tue Jan 28, 2014 11:40 pm
My son has Ultegra shifters, they routinely break cables at 3000km or 10 weeks. Sick of them failing at inconvenient times and the trouble to get the frayed end out, now I just change the inner every 8 weeks. I think perhaps the shifter mechanism is a bit roughed up inside, which makes them break prematurely.Tim wrote:Frayed, almost broken cable for me too earlier this week.
- Duck!
Postby Duck! » Tue Jan 28, 2014 11:53 pm
All STI-type levers, whether they're Shimano, Campag or SRAM suffer the same kind of cable breakage, due to the quite tight wrap around the shifter guts. The problem is compounded by the use of stainless steel cables. The trade-off for the smoother material (therefore lower friction) compared to non-stainless cables is the fact that the stuff work hardens, becomes brittle and then breaks at the stress point where it wraps around the shifter guts.
Postby lobstermash » Wed Jan 29, 2014 12:45 pm
- Aushiker
Postby Aushiker » Wed Jan 29, 2014 2:10 pm
I change mine at 10,000 km. No idea if that is a recommendation or not but ... just trying to avoid a pre-mature failure.lobstermash wrote:No issues yet, but is there a recommended change over km point (as a rough guide)?
Aushiker.com
- RonK
Postby RonK » Wed Jan 29, 2014 2:16 pm
About now would probably be a good time - for the rear shifter at least. They don't cost much and are easy to change (before they break).lobstermash wrote:Hmm. Got around 3000km on my 105 cables atm... No issues yet, but is there a recommended change over km point (as a rough guide)?
Postby nezumi » Wed Jan 29, 2014 2:22 pm
I've been reading up on this now to avoid a repeat.lobstermash wrote:Hmm. Got around 3000km on my 105 cables atm... No issues yet, but is there a recommended change over km point (as a rough guide)?
Apparently you can shift all the way onto the big cassette cog, then shift all the way down *without* using the pedals. This gives you slack to the cables, which you can then push out of the levers to check for significant wear.
- RonK
Postby RonK » Wed Jan 29, 2014 3:03 pm
Postby lobstermash » Wed Jan 29, 2014 3:09 pm
I'll be checking my cable tonight (assuming Murphy doesn't dictate a breakage on the way home!!!)...
Postby nezumi » Wed Jan 29, 2014 4:16 pm
Technically, I *could* have kept riding, however I didn't like the prospect of climbing hills at 36 x 12. I need to learn more trail/touring skills for situations like this. If I had been on the trail someone would likely have stopped, but in the CBD I didn't neccesarily look like someone in trouble. :/RonK wrote:As I've posted previously, it's easy to carry one of these in your toolkit to get you home in case of a breakage.
- RonK
Postby RonK » Wed Jan 29, 2014 5:33 pm
The point is, with this you could have selected an appropriate gear, say the 17t sprocket, and had two rideable gears to get home. Why would you want to rely on somebody stopping? And what makes you think they could have helped. Be prepared. Be self-sufficient.nezumi wrote:Technically, I *could* have kept riding, however I didn't like the prospect of climbing hills at 36 x 12. I need to learn more trail/touring skills for situations like this. If I had been on the trail someone would likely have stopped, but in the CBD I didn't neccesarily look like someone in trouble. :/RonK wrote:As I've posted previously, it's easy to carry one of these in your toolkit to get you home in case of a breakage.
Postby nezumi » Wed Jan 29, 2014 7:48 pm
I didn't say I *wanted* to rely on someone stopping - in fact I said the opposite, that I need to develop the skills so I don't have to rely on someone stopping. However, having never had this happen to me before, and having only had a bike with STI levers for 5 months, I had no idea that this was a possibility. It's not like there's a label saying "this is a semi-frequent problem, and here's the solution".RonK wrote:The point is, with this you could have selected an appropriate gear, say the 17t sprocket, and had two rideable gears to get home. Why would you want to rely on somebody stopping? And what makes you think they could have helped. Be prepared. Be self-sufficient.nezumi wrote:I need to learn more trail/touring skills for situations like this. If I had been on the trail someone would likely have stopped, but in the CBD I didn't neccesarily look like someone in trouble. :/
- wombatK
Postby wombatK » Wed Jan 29, 2014 8:54 pm
And therein lies another great advantage of the di2 shifters. Go the electronicsDuck! wrote: All STI-type levers, whether they're Shimano, Campag or SRAM suffer the same kind of cable breakage, due to the quite tight wrap around the shifter guts
Postby ironhanglider » Wed Jan 29, 2014 9:05 pm
Or DT shifters. Go the retrogroucheswombatK wrote:And therein lies another great advantage of the di2 shifters. Go the electronicsDuck! wrote: All STI-type levers, whether they're Shimano, Campag or SRAM suffer the same kind of cable breakage, due to the quite tight wrap around the shifter guts
Or SS/FG. Go the hipsters and trackies
Or hub gears. Go the hubbards
And despite all this I haven't had a gear cable break in decades.
Cameron
Users browsing this forum: mikesbytes
