Extrawheel
- clackers
Re: Extrawheel
Postby clackers » Thu Feb 06, 2014 11:25 am
- rifraf
Re: Extrawheel
Postby rifraf » Fri Feb 07, 2014 3:18 am
They also provided an Auspost tracking number.
Re: Extrawheel
Postby just4tehhalibut » Fri Feb 07, 2014 11:44 am
- rifraf
Re: Extrawheel
Postby rifraf » Fri Feb 07, 2014 1:26 pm
Good to be aware of.just4tehhalibut wrote:Found this review of an Extrawheel Voyager being towed behind a semi-recumbent tandem. They suffered failures when the trailers started wagging and in the 'comments' section had long discussions with Edward from Buff Downunder to try to sort out the issue. They're now somewhere in Laos and the 3rd trailer back in the UK so this one won't have an answer for some time. I do however look forward to if this couple ever rides in Australia.
Thanks Just4tehhalibut
- Aushiker
Re: Extrawheel
Postby Aushiker » Fri Feb 07, 2014 1:43 pm
Thanks for the link. I have added it to my review of the Extrawheel Voyager.just4tehhalibut wrote:Found this review of an Extrawheel Voyager being towed behind a semi-recumbent tandem.
Aushiker.com
- il padrone
Re: Extrawheel
Postby il padrone » Fri Feb 07, 2014 4:39 pm
1. Rythmic waves or undulations in the sealed surface - one bit of road I could ride on the sealed shoulder where there was a persistent undulation (trailer wobbling) and then onto the road lane (trailer stopped wobbling), then back into the sealed shoulder (trailer wobbled again).
2. Weight in the trailer - I found no oscillations if I packed light, bulky gear in the trailer panniers, and heavy items (waterbags, stove, fuel bottles, etc) in the bikes\'s rear panniers.
- rifraf
Re: Extrawheel
Postby rifraf » Fri Feb 07, 2014 5:24 pm
One of the thoughts that went into the purchase decision was to unladen my rear wheel as much as possible for longevity and put my waterbags (2x 10 liter Ortliebs) in the trailers panniers.
I dont plan to haul around 20 liters willy nilly, but liked the idea of being able to share the weight evenly (ie. 5 liters each instead of one bag with 10).
In fact water haulage was one of the main reasons for purchasing the trailer.
Oh well, I'll have to see how it pans out.
I ride slow so maybe it wont show up as much as its manifested on your rides Pete.
I tend to meander around 15 to 17 kmph on the flat without a trailer so for me it'll be interesting
to see what happens.
The two wheeled Carry Freedom trailer certainly slows me down and another reason for the Extrawheel appeal was its lack of wind resistance compared to the bulky (with bin) Y-frame trailer.
Anyway, thanks for the heads up.
I'll have a rethink of my usual packing strategy.
- il padrone
Re: Extrawheel
Postby il padrone » Fri Feb 07, 2014 7:48 pm
Oh, and also make sure the bags on the trailer are very closely balanced in weight. It seemed to make a difference, much more so than it would on the bike.
We rode all the way from Melbourne to Adelaide on tarmac and I noticed no wobble until descending the Adelaide Hills. With headwinds most of the way a lid was kept on our speeds. Also we rode 1600kms in the Red Centre last September and I used the Extrawheel. A large proportion of this was on sealed roads and on this tour I had no problems with the wobble. Again I carried the waterbags (when we had them full) in the bike's rear panniers.
I've never played around with adjusting the tension on the trailer mounts. Seen the allen bolts but never knew what they did. What are the guidelines for doing this adjustment? How tight? Does tightening reduce or increase wobble?
- rifraf
Re: Extrawheel
Postby rifraf » Tue Feb 11, 2014 2:54 am
Appreciate the info.il padrone wrote:Rifraf, the difference in weight was really only fairly minor - only about 2-3kgs I'd say, but a small change made a big difference in the wobble. I was carrying two 10L water bags so when full they had a fair bit of concentrated mass. I carried one in each rear pannier, with the cooking and kitchen kit, and some food. Most food went in my front panniers.
Thanks heaps
- rifraf
Re: Extrawheel
Postby rifraf » Tue Feb 11, 2014 3:14 am
what width tire are you utilising for mixed surface (tarmac and off road) use?
I've got to make an order for amongst other sundries, a tire and some tubes for the trailer
and am finding it difficult to make a choice.
I know the trailer can use up to 2.30 width but I suppose I'm unsure what the best balance is between weight and usage.
The trailer will, I expect, be used for longer trips where water carrying will be necessary like another Nullabor trip to South Australia.
As has been discussed, I'll put my Ortlieb water bags in the bikes rear panniers and lighter bulkier stuff in the trailer in attempt to eliminate trailer sway and its inherent frame fatigue.
For mixed surface touring, the bike will be shod with 2.00' Mondials.
I'm wondering whether to just grab a Mondial of the same width for the trailer or go skinnier.
Opinions welcomed.
I've no immediate plans for Gibb River Road sand conditions, but want the trailer suitable for unplanned off road excursions should the opportunity arise.
I'm seriously considering a Munda Biddi Trial trip in the medium future but dont think theres an actual need to take a trailer on that journey.
I'm also contemplating an Adelaide trip which may turn out to be quite extended by heading northward after visiting a friend in that city.
Should that eventuate, a Mawson Trail trip would likely be on the cards in which the trailer would be coming with me.
Informed opinions welcome
- Aushiker
Re: Extrawheel
Postby Aushiker » Tue Feb 11, 2014 1:01 pm
Aushiker.com
- rifraf
Re: Extrawheel
Postby rifraf » Tue Feb 11, 2014 3:59 pm
That was my inclination too Andrew,Aushiker wrote:My standard approach is to use a wheel and tyre that matches the bike.
but I thought I'd seek a few opinions before I jumped the gun having overlooked something.
- rifraf
Re: Extrawheel
Postby rifraf » Thu Feb 13, 2014 2:11 pm
My reasoning being the trailer is for mixed surface tours only and not for general tarmac touring which the Carry Freedom trailer can manage with aplomb.
Well that and Andrews confimation that same tires as bike makes sense, especially using the logic that the Extrawheel is supposed to be a backup unit for the bike in case of wheel failure.
Two ordered tires being one for the trailer and one for a spare (both folding).
Also grabbed an E-werk, 3 suitable tubes and an oil change for my Rohloff.
The coffers are a little bare so I'll put off my pillow order till payday next week.
- KenGS
Re: Extrawheel
Postby KenGS » Thu Feb 13, 2014 5:04 pm
OT but I ordered the 250ml bottle of oil and cleaning fluid plus a few of the small plugs. Gives me about five years supply so I can keep riding the Rohloff even if the global economy collapses.rifraf wrote:Also grabbed an E-werk, 3 suitable tubes and an oil change for my Rohloff.
Helmets! Bells! Rego!
- rifraf
Re: Extrawheel
Postby rifraf » Thu Feb 13, 2014 5:13 pm
A good plan KenGS,KenGS wrote:OT but I ordered the 250ml bottle of oil and cleaning fluid plus a few of the small plugs. Gives me about five years supply so I can keep riding the Rohloff even if the global economy collapses.rifraf wrote:Also grabbed an E-werk, 3 suitable tubes and an oil change for my Rohloff.
alas after paying out for the trailer with panniers with sundries,
E-werk, tires and tubes and Rohloff oil
Synmat 7 UL, phone credit and 12 gigs of prepay internet my funds are kinda spartan by
appearance,
otherwise I'd have followed your thoughtful example and grabbed the large oil pack too.
I cant believe how much I've gone through only a week into the fortnight of my pay period.
- il padrone
Re: Extrawheel
Postby il padrone » Thu Feb 13, 2014 6:21 pm
+1KenGS wrote:OT but I ordered the 250ml bottle of oil and cleaning fluid plus a few of the small plugs. Gives me about five years supply so I can keep riding the Rohloff even if the global economy collapses.rifraf wrote:Also grabbed an E-werk, 3 suitable tubes and an oil change for my Rohloff.
Just recieved mine from bike24. Much cheaper way to buy it, especially as now we have three Rohloff hubs in the household.
- rifraf
Re: Extrawheel
Postby rifraf » Mon Feb 17, 2014 2:01 pm
The box had taken a bit of a hammering but everything appears to be there as ordered.
I've got to go out but I'll try to grab some picks when I return and throw one or two up.
Anyone care to comment on techniques for adding the forks to the trailer frame?
Hmmmm, I noticed there was no Extrawheel logo on the Ortlieb panniers......
I was sure there was supposed to be.
Oh well.
I grabbed both the quick release and a couple of trailer nutz.
The Ogre is infamous for twisting of the rear axle without using tugnuts for alignment and a very grunty quick release.
Hopefully if the QR isnt suitable then I wont have too much of an issue getting appropriately threaded bolts to attach the nutz to the bike frame.
- Aushiker
Re: Extrawheel
Postby Aushiker » Mon Feb 17, 2014 2:11 pm
Glad to hear.rifraf wrote:Trailer arrived safely today.
Muscle. It really is as simple as that. You to pop in the bottom of trailer into the fork and then pull on the top of the fork to slip it over the top connection point on the trailer. Not hard really.Anyone care to comment on techniques for adding the forks to the trailer frame?
It shows you in this video around the 54 second mark.
Aushiker.com
- rifraf
Re: Extrawheel
Postby rifraf » Mon Feb 17, 2014 2:52 pm
Sweet!Aushiker wrote: Muscle. It really is as simple as that. You to pop in the bottom of trailer into the fork and then pull on the top of the fork to slip it over the top connection point on the trailer. Not hard really.
Thanks Andrew
Yeah no worries once you know how.
Appreciate the video clip.
- rifraf
Re: Extrawheel
Postby rifraf » Mon Feb 17, 2014 4:16 pm
Also the trailer nuts by themselves wont work at first glance without some machining of the tugnuts.
The problem with ordering a QR (extra long) is that its still a maybe in that the QR may not be strong enough to stop twisting of the axle which the Ogres are infamous for.
Bit of an oversight on my part when ordering as I ended up having to buy an oversized QR before to fit my rear wheel (I'd forgotten).
I'll make a second trip out today and try to get to Bunnings to see if they've any bolts and spacers to fit the trailer nuts thread of 10mm x 1mm pitch.
I tried to ring Buff who are/were the Extrawheel agents.
Not having their number I got their webpage up.
When on the extrawheel.com.au page and clicking on shop, the page says;
We can only accept PAYPAL payments until March 11. We apologize for any inconvenience caused
This Category is currently empty.Last Updated: Monday, 17 February 2014 05:09"
Of interest is the "This Category is currently empty."
I wont speculate on whats occurred till I've managed to contact Edward from Buff.
- il padrone
Re: Extrawheel
Postby il padrone » Mon Feb 17, 2014 5:42 pm
You've lost me there What are "tuggnutz"? How do they render your Rohloff and the Extrawheel incompatible? I've used the Rohloff with the Extrawheel skewer for the trailer with no ill effects. The Ogre has vertical drop-outs with the long slot for Rohloff doesn't it? If so there should not be any "twisting of the axle".rifraf wrote:Ok the standard QR is not suitable for the Ogre with Rohloff and tuggnutz.
[edit] Ah now I see. Tugnuts. And you have horizontal drop-outs.
Does the Ogre run with a QR skewer? If so, why doesn't the Extrawheel skewer work??
I'd be very wary of this. The skewer ends are spherical joints that are designed to match with the trailer. They are also supposed to be lubed occasionally to help minimize damaging wear. I strongly doubt that a couple of bolt-ends would be acceptable to Extrawheel's manufacturers.rifraf wrote:Bit of an oversight on my part when ordering as I ended up having to buy an oversized QR before to fit my rear wheel (I'd forgotten).
- rifraf
Re: Extrawheel
Postby rifraf » Mon Feb 17, 2014 6:00 pm
The QR I bought was a standard length which was too short.
The "Long" would have been a better choice.
The Ogre has a reputation for axles moving under load and as a remedy requires a superior QR.
Most of the available cam action skewers arnt strong enough to hold it in the dropouts under load.
Older XT ones are recommended for their supposedly superior grip and cam action.
The Ogres dropouts come with some threaded holes (10 x 1mm) to add trailer nuts (available from Extrawheel stockists seperately).
These dropout holes are also suitable for Bob trailer nuts which also are available with different threads.
I'm looking at some bolts inserted from the inside of the dropouts with a pipelike spacer (5 or so mm) to allow the trailer nut to sit proud of the tuggnuts.
Threaded rod may be an other option depending on space between the hub and head of the nut when tightened fully.
Pete if you check out the page:
http://extrawheelshop.com/en/quick-release.html" onclick="window.open(this.href);return false;
and scroll down you should see you've a choice of three small boxes with pics.
The middle one shows two nuts without a skewer.
Now if you scroll back up and to the right, theres a drop down box, directly above the "Add to shopping cart" which offers choices including QR's both standard and long, as well as nuts by themselves with 5 different thread choices.
Surly seems obsessed with 10mm with a 1mm thread pitch which is a little unusual and often not stocked it seems - especially in stainless steel.
- rifraf
Re: Extrawheel
Postby rifraf » Mon Feb 17, 2014 8:23 pm
I ordered a two inch Mondial but now know it isnt going to fit under the guard.
Definitely under prepared for the variables.
33 degrees today and doesn't make the head any clearer for thinking.
Glad I'm not riding today as I've had a couple of showers already today and I'm soaked yet again from sweat.
Anyone considering an Extrawheel, be sure to ask what size tyres fit under the mudguard before purchasing.
- il padrone
Re: Extrawheel
Postby il padrone » Mon Feb 17, 2014 8:43 pm
26x2.0" Mondials fit on the Extrawheel with heaps fo space for the mud-guard. If you are running 700C then 2.0 may be too big.
- rifraf
Re: Extrawheel
Postby rifraf » Mon Feb 17, 2014 8:56 pm
Wish I knew IP.il padrone wrote:Why can't you just use the QR? Even if you get the longer one - it seems like a lot less faffing about. If the axle is secured with a QR, and the chain held tight with tugnuts, how can the axle shift about The tugnuts are holding the load on the axle, surely?
There is a common theme with needing especially strong QR's as well as utilising at least one tugnut on more than one forum.
Even people utilsing the tugnut have had QR issues.
Having read this I decided not to skimp but to get two tugnuts.
I bought a recommended QR as well but decided to take my chances with the trailer QR deciding that I'd covered the bases with the purchase of the nuts as well.
I did fail to remember to get the oversized trailer QR despite having been through this once before.
I was unable to get hold of anyone from Buff today to enquire about availability of any Extrawheel accessories/parts so I may have go through Poland.
Yeah, I'm running the 700c's (622).il padrone wrote:26x2.0" Mondials fit on the Extrawheel with heaps fo space for the mud-guard. If you are running 700C then 2.0 may be too big.
