Claud Jubilee - 1954 (sort of)
- WyvernRH
Postby WyvernRH » Sun Mar 24, 2013 6:09 pm
I bought this frame off Karen several years ago. It is solid but the chrome needed attention, either re-chorme or paint over (which needs a decent painter!) and the brain went into vacillate mode.. So it hung on the wall until I got a blue anodized Burlite brake off eBay (a forum member if IRRC) and I snapped! I really wanted to ride this biKe! Inspired by a 1950's Freddie Grubb that an old clubmate had back in London with all 1950's blue anodized parts (Airlites etc) I decided to do a BLUE bike and go for 'patina' on the frame!
The chrome was neutralized and polished and as many period parts used as possible, but preferably blue. Modern parts that looked period were used if the 'real stuff' wasn't available. Decals were planned and positioned to hide the worst defects in the chrome. While I'm pretty sure no Jubilee ever left the Clapham works looking exactly like this I reckon there were a few that were damn close The Burlite levers hoops would only fit the diameter of steel bars so that fixed the bar choice,,,,
Fit out ended up as:
Stem: GB
Bars: geneic steel randonneur
Brakes: Burlite
Chainset: Magistroni steel with Campag alloy 3-arm rings 50/40
Pedals: Wellgo track with Welgo bluee clips
Wheels: Unknown blue 32 hole hubs with velocity rims
Gears : Cyclo push/Pull top action at front, Zeus Alfa Huret copy acrosss a 14-22 Atom at the back, Simplex levers
What do you think, OK or a bit 'flash' It rides really well!
Re: Claud Jubilee - 1954 (sort of)
Postby LG » Sun Mar 24, 2013 7:52 pm
- WyvernRH
Postby WyvernRH » Mon Mar 25, 2013 8:35 am
Yes, that's the idea. Might be a long wait tho, I might be lucky enough to score a pair of blue Airlite hubs sometime but I feel the chances of me finding the ultra rare blue anodized Holdsworty or Lyotard pedals is highly unlikely, let alone another blue Burlite brake. Likelihood of picking up a blue dyed Brooks as seen (according to 'Cycling' magazine) at the 1952 Earls Court bicycle show is basically zero..LG wrote:Well I like what you've done with it. Are you planning to gradually replace the non-period parts as appropriate ones become available?
Most other bits are period or very close to.
Postby silverlight » Mon Mar 25, 2013 9:27 pm
That looks great, I have a soft spot for that blue anodizing.
There is on ebay at the moment a pair of brake anodized blue levers GB brand which may be of interest. (item# 121085883271)
Never say never on those seeking parts, they will turn up.
SL
- WyvernRH
Postby WyvernRH » Sat Feb 15, 2014 6:40 pm
Never thought I'd get one of these at a sensible price (did you see the scandalous price they were asking for the Olympic specials !)
For those interested Pushys also had red, lime green, white and yellow versions
So, another period part added, the search continues!
- singlespeedscott
Postby singlespeedscott » Thu Feb 20, 2014 12:02 am
- Clydesdale Scot
Postby Clydesdale Scot » Mon Mar 03, 2014 7:21 am
Coloral Pair vintage cycling Bottles and Cage Blue
- WyvernRH
Postby WyvernRH » Mon Mar 03, 2014 7:29 am
However, I have a sad suspicion that a pair of Coloral bottles in such good nick are going to end up way above my budget...
- Clydesdale Scot
Postby Clydesdale Scot » Mon Mar 03, 2014 7:32 am
- Clydesdale Scot
Postby Clydesdale Scot » Wed Mar 12, 2014 4:48 pm
Item Ended
Item condition:Used
Ended: 12 Mar, 2014 10:11:26 AEDST
Winning bid:AU $224.72
[ 12 bids ]
Postage: AU $20.00 Standard Postage
Richard,
did you get them??
- WyvernRH
Postby WyvernRH » Wed Mar 12, 2014 9:32 pm
Er no... I bottled (no pun intended) circa $200.00 which was way more than I really wanted to pay but I was subbed by SWMBO - someone out there really wanted them!Clydesdale Scot wrote:Coloral-Pair-vintage-cycling-Bottles-and-Cage-Blue
Item Ended
Item condition:Used
[ 12 bids ]
Richard,
did you get them??
Postby geoff_tewierik » Thu Mar 13, 2014 11:10 am
http://www.ebay.com.au/itm/Rare-Vintage ... 6e7&_uhb=1" onclick="window.open(this.href);return false;
- ldrcycles
Postby ldrcycles » Thu Mar 13, 2014 3:15 pm
- WyvernRH
Postby WyvernRH » Thu Mar 13, 2014 5:20 pm
That's correct, it's a retro thing.ldrcycles wrote:I really like the front derailleur arrangement, but i'm curious as to why? Is it a period thing or did you only have 2 single boss clamp ons and no double boss clamp?
If you look closely you can see that the activator chain exits the right side of the Cyclo front changer (ie directly above the cage) so you cannot pull from below, you must pull from above and on the right of the tube so you cant use a down tube lever to activate it (without a big fiddle)
I prefer the front changer lever on the seat tube with an open direct pull cable but some people used to use a bar-end lever or a lever on the top tube using a cable with an outer along the top tube and down to the cable stop above the derailleur.
- Clydesdale Scot
Postby Clydesdale Scot » Sat Mar 15, 2014 12:31 pm
at least you can have blue Shockstops
your choice of either of the two blues
see you at the Classic Bike Show next weekend
- WyvernRH
Postby WyvernRH » Sun Nov 16, 2014 5:13 pm
- singlespeedscott
Postby singlespeedscott » Sun Nov 16, 2014 9:46 pm
- WyvernRH
Postby WyvernRH » Sun Nov 16, 2014 10:25 pm
Well, whatever Greg had in there last was never washed out. Whatever it was (no names, no pack drill) 40 years later has encrusted itself firmly to the internal aluminum and defies removal. I have tried most things short of strong acids to shift it but no.... So, probably harmless but I'm not going to risk it. The fact that whatever spilled managed to remove the lacquer on the outside alloy is sufficient for me...singlespeedscott wrote:What makes them unfit for drinking?
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
