Postby westab » Fri Nov 08, 2013 3:02 pm
- Xplora
Postby Xplora » Fri Nov 08, 2013 3:24 pm
Postby Le Mong » Fri Nov 08, 2013 9:20 pm
File the quarq or the rings?Xplora wrote:I'm going the Full Retard, Tropic Thunder style. Quarq has advised that you can file down the proud edges on the earlier Quarqs to use the Rotor Aero Q-rings. Biggest issue was that you can't use a 52 at all without the modification. Just needs a proper calibration bwahahahahhahahahahahahahaha so here I go
Sent from my GT-N7105T using Tapatalk
- Xplora
- winstonw
Postby winstonw » Sat Nov 09, 2013 6:05 am
Postby simmo71 » Sat Nov 09, 2013 1:23 pm
No, only on TV like McGuyver. It just won't allow any stretch in the tube and just cracks off!winstonw wrote:makes me wonder if the superglue repair works.
My GF wish it did so she didn't have to be the but of all jokes;)
Sent from my ASUS Transformer Pad TF300T using Tapatalk 4
- biker jk
Postby biker jk » Thu Feb 20, 2014 4:16 pm
Postby YearoftheCat » Thu Feb 20, 2014 10:54 pm
Spokes with heads out both sides first then spokes with heads in!
Scot
Postby jasonc » Fri Feb 21, 2014 9:05 am
fluke I tells you.biker jk wrote:Serviced my Shimano hubs without dropping any of the ball bearings. The pen with a magnetic head I purchased sure works a treat to get all the ball bearings out in one go. As did inserting the axle while dropping the ball bearings into the cup so they can't fall through.
Postby ironhanglider » Sat Feb 22, 2014 12:15 pm
YearoftheCat wrote:It took me four goes to get my new front wheel laced up. 36H, 3 cross so nothing fancy but yeah, four goes. I have a 40H cross 4 to do next which I'll get first go!
Scot
Tandem wheel? I considered 4 cross, but eventually went with 3 for large flange hubs. 4 cross can overlap (or nearly overlap) which can make spoke replacement awkward if you ever have to.
As for multiple goes at lacing that happens, particularly if you are trying to get the hub logo aligned with the valve hole. Best to do that alignment with two spokes in the beginning.
Cameron
Postby YearoftheCat » Sun Feb 23, 2014 9:54 pm
The rear is a 40h Sturmey AW3, and was laced up cross 4 so I just did the same. I could probably have gone with 3. I needed washers under the spoke heads which makes it pretty tight for overlap at the flange but they do just make it. I almost got it laced up first go.
- ldrcycles
Postby ldrcycles » Mon Feb 24, 2014 9:18 am
Yea that hurt.
- justalf
Postby justalf » Mon Feb 24, 2014 12:05 pm
When installing a bolt, first rotate it backwards until it clicks. This positions it properly in the threads. Then wind forwards to install as normal. And use a little grease on the threads.
Postby jackthelad » Tue Feb 25, 2014 12:26 am
the thought of the job was harder than the actual job
SantaCruz Blur XC Carbon
Kona Kula Supreme(Retired/Spare)
Surly Karate Monkey
Ribble Rd Bike
- yugyug
Postby yugyug » Tue Feb 25, 2014 10:14 pm
- bychosis
Postby bychosis » Fri Feb 28, 2014 9:00 pm
- Xplora
Postby Xplora » Sat Mar 01, 2014 6:13 pm
How to measure a chain using vernier calipers.
- mark field
Postby mark field » Sun Mar 02, 2014 12:37 am
justalf wrote:Very basic tip that took me too long to discover, which helps prevent cross threading.
hi, can you be my new best friend? ive been telling people this for years but i just get blank stares like im from another planet. This tip is especially important with screws that have been from something that is plastic, most plastic parts during the manufacturing process have small holes with no thread, so when the factory worker or robot type thing is putting the screws in place they use screws that have a small groove that runs along the length of the screw which intersects with the screws threads thus making it a "self tapping screw" so if you remove one of these "self tapping " screws then you risk stripping the thread that has been made in the plastic unless it is re-seated correctly by the above mentioned method. this way you know that the start of the screw thread has met the start of the part thread which means clockwise turning will enable the screw to follow the same path that it had originally cut. If one accidentally strips the thread from a part then it is advisable to use another self tapping screw that is of a larger diameter. if you can.
but im a champion bike mechanic because i was having issues with the paint nozzle on a pressure pac can so while i was looking at it i decided to press it see if it was clogged. So basically i just sprayed paint directly into both my eyes. i dropped to my knees screaming to my friend im blind help me ahhh. but he pretended to not hear me , anyway i managed to find my way into the bathroom and wash my face under the tap. Then i contemplated my stupidity, went back out side to resume painting AND DID EXACTLY THE SAME THING AGAIN.
- Xplora
Postby Xplora » Sun Mar 02, 2014 1:03 am
50Nm torque wrenches are crazy expensive I borrowed one from Dad, but I'm not sure I got the right result. Slight rubbing, wonder if I've overtorqued a couple Nm?
- justalf
Postby justalf » Sun Mar 02, 2014 2:35 am
Mr Field, the honour is all mine. I laughed at that because I know what it's like.mark field wrote: AND DID EXACTLY THE SAME THING AGAIN.
And the screwing backwards thing should be taught in schools or something.
- bychosis
Postby bychosis » Sun Mar 02, 2014 7:04 am
On returning to the garage couldn't find the box anywhere, spent fifteen minutes looking for the red box with the new bar tape. Everywhere, including places I was sure I hadn't looked that morning and I knew I had seen the box earlier. Eventually found the plain cardboard coloured box, turns out the red box was was the previous bar tape box, not the current stuff. The new stuff had been in plain sight the whole time, just the wrong colour.
I've gotta tidy up.
- OnTrackZeD
Postby OnTrackZeD » Sun Mar 02, 2014 9:14 am
I hope you don't handle fire arm's because you just can't wash that mistake away.
- Xplora
Postby Xplora » Mon Mar 03, 2014 7:52 pm
Postby Stepr » Mon Mar 03, 2014 8:37 pm
- Xplora
Postby Xplora » Fri Jun 06, 2014 1:13 pm
Will give this a go tonight once I have some spare hands. Had to admit I was surprised how much the weights were "off" the designated weight. They have a rubber coating, but obviously that's added weight. Something to keep in mind if I ever need to start measuring kilojoules.
TL:DR I am going to calibrate my SRM today
