Water bottle holder on front fork of bicycle
Postby jemo27 » Sun Mar 02, 2014 8:23 pm
What do others use?
- il padrone
Re: Water bottle holder on front fork of bicycle
Postby il padrone » Sun Mar 02, 2014 8:41 pm
I carry all my bidons on the main frame tubes, with a big 1.5L bottle cage under the down-tube. Waterbags in the panniers (2X10L) carry far more than any bottles for remote camping tours. These days I have seen some bikes with bidon eyes on the forks, and any bidon could be fastened to them. Or are you after some other special type of water bottle holder?
Postby jaffaman » Sun Mar 02, 2014 9:11 pm
- m@
Postby m@ » Sun Mar 02, 2014 9:18 pm
I guess it would help to keep the center of gravity low, but unless you're touring i.e. carrying a lot of weight, I'd lean toward the tri-style mounts - on the bars and behind the seat.
- il padrone
Postby il padrone » Sun Mar 02, 2014 9:22 pm
Many years ago a good friend of mine mounted a rear-view mirror on his front fork - the old-style 'steel bar with rectangular mirror-type'. Going down a big hill at speed, mirrror came loose, swung the whole kabootz into his front wheel. He was lucky to come out of it with just a badly broken arm
Postby lard » Sun Mar 02, 2014 10:00 pm
reminds me of this from the tour last year.. http://i.imgur.com/w2OH7.jpg" onclick="window.open(this.href);return false;
- redsonic
Postby redsonic » Sun Mar 02, 2014 10:46 pm
^^^lard wrote:Sound like a recipe for disaster to me, and imagine reaching down for you bottle and getting a finger in the spokes...
Wow, Velominati rule no. 5 personified
- il padrone
Postby il padrone » Mon Mar 03, 2014 12:16 am
Two fork legs - two 700ml bottles = 1.5L . Mehm@ wrote:I guess it would help to keep the center of gravity low, but unless you're touring i.e. carrying a lot of weight....
When I'm touring I carry a 6L waterbag and if it needs to be full it goes between the panniers, under my tent pack on the rear rack. Much better water supply. Never experienced any destabilising effects from this.
Postby Baalzamon » Mon Mar 03, 2014 2:42 am
Then get another Surly Rack Front Flat Sliding Plate
Now I can use that to put on 2 bottle cages. Will it come off, not with nyloc nuts.
Postby jemo27 » Mon Mar 03, 2014 10:45 am
I would have any water bottles coming out 90 degrees to the wheel. I have a vivente world randourner, it already has a single hole on each fork for putting a front rack on. I would not imagine I would ever reach for the water bottle while cycling.il padrone wrote:The sort of thing some cyclists do which I would be very, very wary of.
I was looking at the front to try and even out my weight from the back of the bicycle. I would aim to be able to carry two 1.5 litre bottles, giving me about 6.5 litres capacity without needing to carry a water bladder on my back rack.
- rifraf
Postby rifraf » Mon Mar 03, 2014 3:51 pm
WarrenH of this forum springs to mind.
Whoops - already mentioned here:
I've even seen it done with four bottle cages per fork leg although I suspect 4 x 1 liter might have some affects on handling though less than a couple of panniers I guess.m@ wrote:Cable ties + standard plastic cages will work - do a search for warrenh's posts for some photos.
Edit: Actually WarrenH has some pics somewhere of his Giant Anthem with 4 cages on his front suspension forks.
I'll let him link to any pics he wants up, although you will find them if you checkout his photobucket pages he's left links to elsewhere.
Alternatives might include stem and seat mounts.
I'm lucky in that my frame has three cage mounts with which I include 2x 1.5 liter bottles.
I utilise the third for fuel and like IP I have 2x 10 liter waterbags to be carried in panniers when needed.
- WarrenH
Postby WarrenH » Tue Mar 11, 2014 1:22 pm
There isn't much water up high on the Great Divide, even at the best of times. So fitting a goodly capacity to the bike, installed as low as possible, is a wise move.
This shot from the August 2012 issue of BNT Tracks magazine. The article by Dave McLeod is about mountain biking on the BNT during extreme weather conditions ... like during heat waves. The photo shows from L-R Brad McCullach, Terry Montgomery and Jeff Coward hiking and hauling, Terry's bike and BOB up (what I think is) the nightmare called Lazareni Spur in the Victorian High Country.
I fitted road cages, they're slightly lighter than MTB cages. I used hose clamps to secure the cages with strips of inner tube under the clamps to stop the issue that il Padrone has mentioned, about the set-ups on the fork possibly moving and fouling the spokes ... the rubber also protects the paint. On the round profile of the fat Fox fork the cages might sit better than on a skinny oval profile found on a road bike fork.
I tried how the extra weight felt when it was ahead of the fork, then behind the fork ... and without any issues apart from gaining some weight up front when the biddons are full (which isn't a bad thing on dirt with the load down the back) I settled on both sides of the fork, and set the cages as low as my speedo and brakes will allowed.
A use Velcro straps to tether the biddons. All up my bike has six 850ml biddons installed, about 5lts. I also take a 5lt bladder to fill when ever possible with creek water, to be processed, and two additional 1lt Nalgen bottles. It is thirsty work off-road touring. The Velcro straps I purchased from a Chinese dollar shop (from Hot Dollar) ... you can get Velcro straps from Bunnings Hardware. Bunnings has a wall dedicated to Velcro, but the Velcro at Bunnings is extremely expensive.
Warren.
- rifraf
Postby rifraf » Tue Mar 11, 2014 7:50 pm
throwing up a link I spotted today:
https://www.cyclingexpress.com/?lang=en ... ottle+Cage" onclick="window.open(this.href);return false;
No idea if its any good or not but may save you a trip to Repco in search of radiator hose clips.
- Aushiker
Postby Aushiker » Wed Mar 12, 2014 1:37 pm
Aushiker.com
Postby just4tehhalibut » Wed Mar 12, 2014 5:13 pm
Nice idea, if I upgrade forks there's several brands around that can take these cages, worth bearing in mind.
- il padrone
Postby il padrone » Wed Mar 12, 2014 5:49 pm
I would never be entrusting anything on my front forks to the "security" of a velcro or nylon strap mount..... no matter how trendy it seemsAushiker wrote:Plenty of photos around the place of Salsa Anything Cages on front forks. They use nylon straps to attach the cage to the bike.
I really don't see what the problem is with a well-loaded and balanced pair of front panniers, and a waterbag (up to 10L) in the rear panniers or on the rack top. Each to their own I guess. In Central Australia, where we needed water for 3-4 day stretches, we carried two 10L bags each.
- Aushiker
Postby Aushiker » Wed Mar 12, 2014 6:02 pm
My bad. Thanks for correcting.just4tehhalibut wrote:I was under the impression that the Salsa cages bolt onto the fork and that they prefer forks with a 3-bolt pattern such as their own. The straps are actually for whatever the cage is holding since the cages aren't designed for bidons so much as tents, sleeping mats, thermos bottles, puppies.
Aushiker.com
- Wingnut
Postby Wingnut » Wed Mar 12, 2014 6:50 pm
il padrone,il padrone wrote:I would never be entrusting anything on my front forks to the "security" of a velcro or nylon strap mount..... no matter how trendy it seems
Theres "Touring" and then there's "Bikepacking" which is basically travelling lighter so the bike feels less like an aircraft carrier and more like a mountain bike to ride single trails etc. Refer below...
- il padrone
Postby il padrone » Wed Mar 12, 2014 7:10 pm
You won't get too far in the outback with that rigWingnut wrote:il padrone,
I am aware of the idea of bikepacking. I personally do not see it as impossible to do using full panniers. I have ridden some fairly extreme stuff with panniers.
Mawson Trail north of Hawker
Snowy Mts and the Nine Mile Pinch. Not full-tilt single track I know, but remote and rough enough.
But even with bikepacking, if you are going to need water supplies (ie. in dry country) you would be better off carrying a water bag that can carry anything from 0.5L to 10L as you desire, and stashing it securely in a bag or under a gear strap. I guess the loaded frame triangle does prevent frame-mounted bottles.
- Wingnut
Postby Wingnut » Wed Mar 12, 2014 7:17 pm
- Wingnut
Postby Wingnut » Thu Mar 20, 2014 10:45 pm
http://joecruz.wordpress.com/2013/05/09 ... hing-bags/" onclick="window.open(this.href);return false;
Postby rama » Sun Mar 23, 2014 8:36 pm
Excellent point. I have seen speed & cadence sensors tie wrapped to the fork/frame get hit by spokes, and they luckily broke in pieces and turned around because of their small size without causing a crash.il padrone wrote: ....I would never be entrusting anything on my front forks to the "security" of a velcro or nylon strap mount..... no matter how trendy it seems
A larger component like a water bottle & its cage would definitely jam the wheel instantly.
Sensors, pumps, bottles etc should be mounted to your frame & fork "downstream" of the wheel turning direction.
Postby jeremy11 » Tue Jun 17, 2014 6:48 am
Wingnut wrote:These are interesting...
I make and sell these bags... and have a couple pairs over in Australia. They can hold 2L of water on each side just fine.
Any questions, please ask away.
- Mugglechops
Postby Mugglechops » Tue Jun 17, 2014 12:28 pm
- Wingnut
Postby Wingnut » Tue Jun 17, 2014 8:55 pm
Do these bags just screw directly into the standard Anything Cage mount holes? Are there any choices with regard to the bag materials too?jeremy11 wrote:Wingnut wrote:These are interesting...
