Tips for bikes on train
- provoked
Postby provoked » Tue Apr 22, 2014 8:53 am
Long time no post. Recently started cycling to the station and then from Flinders to work and was wondering if anyone has any tips/trick for placing the bike in the carriage (i.e. Seat near the door, seats near the back of the car etc etc). I've tried a couple ways, most of which are not very comfortable and end up holding the handle bars the whole trip. I know I can't go in the front carriage, however that's the only guidance I've ever been able to find.
Cheers!
The mind is its own place, and in itself, can make heaven of Hell, and a hell of Heaven. - John Milton
- Mulger bill
Re: Tips for bikes on train
Postby Mulger bill » Tue Apr 22, 2014 8:20 pm
As to storage, IME, it's best to work around the population of the car, sometimes that means you and the bike will have to stand.
If the train isn't too crowded, you han hook either dropbars or front wheel into the handrail either side of the doorway.
Golden rule for me is don't be a dick. Be polite, say your pleases, thank yous and excuse mes and most people will let you in OK.
- kb
Postby kb » Wed Apr 23, 2014 6:42 am
- provoked
Postby provoked » Wed Apr 23, 2014 7:17 am
Long time no talk Mulger! Tried this this morning - sat in the back of the carriage with my flat bar grip sitting in the rail - worked a treat! And agree with the rest of your comments.Mulger bill wrote:If the train isn't too crowded, you han hook either dropbars or front wheel into the handrail either side of the doorway.
Unfortunately - no, South Morang Line. I've had to shift my work hours to make things easier. On the train at 6am to get to work and back on the train by 4.30pm - 4.45pm to get home. As I get used to facilities/getting ready, should be able to get to Flinders for the home trip even earlier hopefully. Things aren't too bad at that time, but it doesn't leave me with a lot of contingency if I'm running late...kb wrote:If you're on a fairly well provisioned line like Lilydale / Belgrave, it can be worth trading 10 minutes for a stopping all stations train. They can be practically empty.
Postby TTar » Wed Apr 23, 2014 10:44 am
For one thing, our trains are double decker which is futuristic and glamorous compared to tedious old fashioned Melb trains which look like they'd rather be trams.
They're also much better for travelling with your bike, even though they're not designed for it. My preferred method is to "lean" the bike against the central handrails in the vestibule;
It's best to avoid the side neatest the stairs as there's (oddly) a little less distance between the handrails and stairs than the distance to the cabin on the other side. So, with the bike on the near side in the photo, I thread the helmet straps though the front wheel and around the down tube and the handrail and all's good. Prams and the frail sometimes experience difficulty navigating around the bike, but usually aren't too fussed.
There's no restrictions on which carriage you can use, but obviously it's best to avoid the crowds and that means up front or toward the back.
- provoked
Postby provoked » Wed Apr 23, 2014 11:13 am
You could be right - I was surprised I couldn't find anything detailed on the subject on the forum - only a few comments to avoid the front carriage as it's earmarked for disabled entry.TTar wrote:This thread has the potential to become one of those valuable resource-rich mega-threads that goes on for years, contains sound advice for taking bikes on trains in every city on earth, clocks up scores of pages and hosts a flame war or two;
Perfect example! Never thought of that one - will try tonight!TTar wrote:I thread the helmet straps though the front wheel and around the down tube and the handrail and all's good.
- provoked
Postby provoked » Thu Apr 24, 2014 2:48 pm
Postby TTar » Thu Apr 24, 2014 5:41 pm
provoked wrote:Couldn't get the helmet trick to work Ttar! Kept rolling off. I reckon if I tie my brake lever with something I'll be saved from a lot of hassle as the problems mainly come with the bike rolling away...
Oh dear, I didn't really explain myself very well.
The bike stands with both wheels on the floor. These are Sydney trains remember, I googled pix of Melb train interiors and the don't seem to have the handrails in middle of the vestibule.
I just clip the helmet straps on the bike as if I'm locking it with a cable lock to a lamppost.
The grey MTB in the pic is what I mean. Thankfully there's usually not so many bikes on board.
- Mulger bill
Postby Mulger bill » Fri Apr 25, 2014 8:30 pm
Take one shagged MTB tube and cut a 20mm wide section. It will sit neatly on your RH grip and when stretched over the brake lever makes an excellent parking brake.provoked wrote:Couldn't get the helmet trick to work Ttar! Kept rolling off. I reckon if I tie my brake lever with something I'll be saved from a lot of hassle as the problems mainly come with the bike rolling away...
- KGB
Postby KGB » Sat Apr 26, 2014 6:59 am
Depending on how your brakes are set up, you can try winding the barrel adjusted all the way out until the brakes clamp on the rim.provoked wrote:Couldn't get the helmet trick to work Ttar! Kept rolling off. I reckon if I tie my brake lever with something I'll be saved from a lot of hassle as the problems mainly come with the bike rolling away...
- m@
Postby m@ » Sat Apr 26, 2014 9:45 am
This is the best option from what I've observed, provided there's space to manouvre.Mulger bill wrote:If the train isn't too crowded, you han hook either dropbars or front wheel into the handrail either side of the doorway.
Incidentally, g'day!
Postby tubby74 » Tue Apr 29, 2014 10:59 am
you can't be in the space behind the drivers cabin, at least that's what drivers have told me on interurban services. Also worth noting that with an opal card you no longer need to buy your bike a child's ticket during peak hoursTTar wrote: There's no restrictions on which carriage you can use, but obviously it's best to avoid the crowds and that means up front or toward the back.
Postby TraceyG » Tue Apr 29, 2014 12:56 pm
Postby TTar » Tue Apr 29, 2014 2:52 pm
tubby74 wrote:you can't be in the space behind the drivers cabin, at least that's what drivers have told me on interurban services. Also worth noting that with an opal card you no longer need to buy your bike a child's ticket during peak hoursTTar wrote: There's no restrictions on which carriage you can use, but obviously it's best to avoid the crowds and that means up front or toward the back.
Had the driver on a metro train jump out of his cabin one time and tell me I couldn't put the bike in the front vestibule of the front carriage. No idea why, but I didn't know it was routine on the interurbans -- thanks for telling us, it's good to know.
Speaking of the intercity trains, on Sundays you can buy a "family day" (or something) ticket for $2.50 that allows unrestricted travel (multiple stops if you chose) all day on the entire network. So you could ride from Newcastle to Bathurst to Goulburn to Wollongong and back to Newcastle, about 1,400kms by my rough calculation, for $2.50! It might be the world's cheapest form of travel per kilometre.
You'd be hard pressed to do it all in 24hrs, but the tickets remain valid until 4am the next day, so if you started at midnight...
There's a challenge for some dope! I think I might go check Cityrail's timetable.
Postby zebee » Wed Apr 30, 2014 7:13 am
you can check http://transportsydney.wordpress.com/20 ... -02102013/" onclick="window.open(this.href);return false; for tips...TTar wrote:tubby74 wrote:TTar wrote:
I have had drivers on the Newcastle Express ask me to move the Brompton (admittedly unfolded) to the next car. I think because in that particular train config the first car didn't have bike slots and they wanted the bike well out of the way. Since the timetable changes (and the move to 4 cars from 6) the Newcastle train isn't worth it for me. Bad timing for changes and crammed full. Used to be a guy taking a fullsized ebike and there just wasn't the room. Barely the room for my tiny folded package.
I think if bikes on trains get popular then it's going to be difficult to fit them on in Sydney. Already can be on a lot of peak and close to peak services. I suspect the single deck trains on the new North West Rail Link won't have any room for full sized bikes as they won't have the same vestibule setup.
I find the Brom perfect for multi mode commuting. For one thing I don't care when buses replace trains, I just fold the Brompton and take it on the bus. Do that with your roadie!
- ColinOldnCranky
Postby ColinOldnCranky » Wed Apr 30, 2014 3:27 pm
When talking volumes of bikes on trains, as well as space the time it takes to get on and off is important to train operators. Adding 1 minute to a stop (as it easily would with several bikes in a fairly full carriage) so adding time to a couple of thousand passengers at every stop is not something that transport authorities are keen about. Purpose built bike arriages are probably the only way to get bikes in numbers on and off quickly.zebee wrote:I think if bikes on trains get popular then it's going to be difficult to fit them on in Sydney.
Postby rjk » Fri May 02, 2014 8:49 am
They get the ramps out for the wheels chairs and the people tell the drivers at what station they want to disembark.
I use the last carriage on the melb trains as that has the largest space for bikes, also 2 bits of velcro, one to wrap around the brake locking it on and one to wrap around the top tube and what you want to secure it to
Postby guyc » Fri May 02, 2014 10:03 am
Easy to find them on Ebay.
Postby DJIntegr8 » Mon May 05, 2014 10:04 am
I use toe straps on the Comeng and Xtrapolis trains, roll the pedal back against the post and secure the seat tube/seat post with the strap. The Siemens trains have a bit more space at the ends, and I normally hook my drop bars into the flip-up seats and roll the pedal into the seat base.
Brendan
- Bentnose
Postby Bentnose » Tue May 06, 2014 9:08 pm
Postby Lurkin » Sun May 25, 2014 8:26 pm
Postby Zcootz » Tue May 27, 2014 10:45 pm
Do you know if that's a Vic wide thing ? I thought I had to take apart my bike and box it up on Vline?TraceyG wrote:Sounds as though one of the small advantages of Vline trains in regional Victoria is that they are a little more bike-friendly than Metro. Just look for the bicycle symbol at the carriage door and you will find that end of that carriage has a space where you can place your bike out of everyone else's way.
Postby Zcootz » Tue May 27, 2014 11:01 pm
- Jangari
Postby Jangari » Sun Jun 08, 2014 2:51 pm
This is on their 'train', which is roughly equivalent to a Melbourne tram.
Postby zebee » Sun Jun 15, 2014 7:43 am
I can't use them because I have a 'bent which doesn't lend itself to that and even if I was using a diamond frame bike my dodgy right shoulder won't take me lifting something that heavy above shoulder height.
