The new and interesting touring gear thread...
- il padrone
Re: The new and interesting gear thread...
Postby il padrone » Fri Apr 25, 2014 10:21 am
- Wingnut
Postby Wingnut » Fri Apr 25, 2014 10:00 pm
Looks like Blackburn are coming out with a larger cage for touring types...
http://www.bikerumor.com/2014/04/25/pro ... more-77756" onclick="window.open(this.href);return false;
Personally I'd like to see King Cage put these into production...an early one off cage...
- Aushiker
Postby Aushiker » Sat Apr 26, 2014 11:57 pm
Thanks for the link. Another possible option in the large water bottle cage market.Wingnut wrote:Looks like Blackburn are coming out with a larger cage for touring types...
Aushiker.com
- RonK
Postby RonK » Wed Apr 30, 2014 9:04 am
Instantly share any Internet connection and stay secure with firewall protection for public hotspots with NETGEAR Trek™ Travel Router and Range Extender. No longer pay multiple access fees for each device and turn a wired internet connection into a WiFi hotspot.
Postby piledhigher » Wed Apr 30, 2014 9:40 am
- Aushiker
Postby Aushiker » Sat May 03, 2014 12:00 am
http://www.senzumbrellas.com/collection/drycycle" onclick="window.open(this.href);return false;
Aushiker.com
- Aushiker
Postby Aushiker » Sun May 04, 2014 11:07 pm
Aushiker.com
- Leaf T
Postby Leaf T » Mon May 05, 2014 10:17 am
I use this and maybe not big on looks I can't fault it for function.Aushiker wrote:Thanks for the link. Another possible option in the large water bottle cage market.Wingnut wrote:Looks like Blackburn are coming out with a larger cage for touring types...
http://www.amazon.com/Zefal-Spring-Cage ... B001NOEC38" onclick="window.open(this.href);return false;
It holds any size plastic bottle like the 2l water bottles from the servo etc and more importantly it holds long necks of Coopers sparkling ale
Not good for under down tube mounting though.
- RonK
Postby RonK » Fri May 16, 2014 1:58 pm
Recalling all the times when I've sat on the floor in a hotel assembling/disassembling my bike, it would have been great to have a work stand to do it on, and then just put the whole thing into the bag.
Pros:
Rugged nylon shell expands around aluminum Click-Rail to protect bike during transport
Durable and removable side panels protect the bike
Nylon wheel bags prevent frame and wheel contact
Thru axle adapters for 15mm and 20mm axles included
Integrated bike assembly stand doubles as a convenient bike holder and assembly stand making it easy to assemble and disassemble your bike
Integrated wheels and handles for easy transport and maneuverability
Lightweight and easy to store with folding side panels and collapsible frame
For road, mountain and cyclocross bikes up to and over a 46" / 116.8 cm wheelbase
Cons:
Weighs 9.5kg
Costs $799
- il padrone
Postby il padrone » Fri May 16, 2014 6:57 pm
Blackburn simply need to re-release their marvellous Bomber cage - a much more robust design for touring uses. I don't understand why they don't do it.
- RonK
Postby RonK » Fri May 16, 2014 7:01 pm
Postby Baalzamon » Fri May 16, 2014 7:51 pm
- Aushiker
Postby Aushiker » Wed May 21, 2014 9:18 am
Aushiker.com
- RonK
Postby RonK » Wed May 21, 2014 12:08 pm
- Aushiker
Postby Aushiker » Thu May 22, 2014 12:33 pm
Just what you need for the romantic cycle tour The TorchGlo
TorchGlo is a great way to create ambient lighting while out on the trail. It attaches to any headlamp and diffuses your headlamp's light into pleasant, warm lighting. With TorchGlo, you don't have to buy a lantern or a new lighting device, you can just attach TorchGlo to the headlamp you already own. TorchGlo weighs less than 3 oz, so it won't weigh you down. It radiates the perfect amount of light for a tent, great for reading or talking with friends.
Details can be found at Kickstarter if you are bored.
Aushiker.com
Postby bushwalker zane » Thu May 22, 2014 2:15 pm
I was recently sitting out on a verandah with a bicycle tourist, and she had her Sea to Summit X Cup sitting over her headtorch. We thought it was a fantastic idea, and even thought of ways to make a custom fit cover. Looks like someone beat us though! But, I think it is easier to use a pre-existing object if you already have something to fit the bill.Aushiker wrote:
Groovy thing though
Postby PapaJohn » Thu May 22, 2014 6:56 pm
The one's that come in great stacks of 50 or so, free anywhere there is a water dispenser, eg. Dr.s waiting rooms, but occasionally they provide the clear ones - no good.
- outnabike
Postby outnabike » Fri May 23, 2014 9:07 am
Sorry it came up as a spammer sale.
- Leaf T
Postby Leaf T » Fri May 23, 2014 3:47 pm
- Aushiker
Postby Aushiker » Fri May 23, 2014 4:30 pm
Aushiker.com
- rifraf
Postby rifraf » Fri May 23, 2014 5:21 pm
I cant see that being much help getting some air into your inflatable mattress
Postby jaffaman » Fri May 23, 2014 5:39 pm
Yeah. Mine came with dire warnings not to use it stationary for more than a few minutes or it would overheat. Maybe some low powered "be seen" rather than "see" lights would be OK.Andy wrote:Re Torch glo- I thought it was critical for LED's to be able to shed heat and that is why they usually have an aluminium surround or cooling fins. My B+M front dynamo light has a metal hood like thing which I presume is for this purpose. And my Led lenser head lamp is mostly ally too.
Sent from my iPhone using Tapatalk
- RonK
Postby RonK » Fri May 23, 2014 6:37 pm
In case you didn't notice, this is the touring forum, and we are talking about the low-powered kind of lights you might use in camp on tour.jaffaman wrote:Yeah. Mine came with dire warnings not to use it stationary for more than a few minutes or it would overheat. Maybe some low powered "be seen" rather than "see" lights would be OK.Andy wrote:Re Torch glo- I thought it was critical for LED's to be able to shed heat and that is why they usually have an aluminium surround or cooling fins. My B+M front dynamo light has a metal hood like thing which I presume is for this purpose. And my Led lenser head lamp is mostly ally too.
- Leaf T
Postby Leaf T » Sat May 24, 2014 12:19 pm
The Led lenser is a head lamp that does get used for touring and camping Ron.RonK wrote:In case you didn't notice, this is the touring forum, and we are talking about the low-powered kind of lights you might use in camp on tour.jaffaman wrote:Yeah. Mine came with dire warnings not to use it stationary for more than a few minutes or it would overheat. Maybe some low powered "be seen" rather than "see" lights would be OK.Andy wrote:Re Torch glo- I thought it was critical for LED's to be able to shed heat and that is why they usually have an aluminium surround or cooling fins. My B+M front dynamo light has a metal hood like thing which I presume is for this purpose. And my Led lenser head lamp is mostly ally too.
It's a brilliant headlamp. It can get very hot if covered though. I accidentally left it face down on a sleeping bag for perhaps a minute. I was surprised it didn't burn a hole in my bag. I suspect the torch glo would capture the heat too.
http://www.wildearth.com.au/buy/led-len ... ume/zl7398
- il padrone
Postby il padrone » Sat May 24, 2014 1:05 pm
