Front Pannier Racks
Front Pannier Racks
Postby Biking POD » Wed May 21, 2014 6:48 pm
Long time listener, first time caller! Thanks for all the grouse info, it's been most useful!
Anyways, looking for some FRONT pannier racks to suit a bike with disc brakes. I can find a few but none say that they will suit a bike with disc brakes.
Please help!
Cheers now!
- il padrone
Re: Front Pannier Racks
Postby il padrone » Wed May 21, 2014 8:19 pm
Tubus Tara or Duo may be able to be fitted with a front disc. Easiest with hydraulics* but may work with cable also. It will all depend on where your rack mounts are, and easier if you have dual mounts with one on the front of the fork blade.
* I should say that with nearly all hydraulic disc-brakes you will not need disc-adapted racks at all. The disc calipers are generally quite narrow and do not protrude to interfere with the rack mount or struts.
Surly Disc-Trucker running F&R cable discs and Tubus Cargo and Tara standard racks.
Postby Konatourer » Fri May 23, 2014 7:18 am
Postby Espresso_ » Sun May 25, 2014 12:43 pm
I'll probably be running TRP Spyre mechanical discs, which are a bit slimmer than others, I hear, but I predict some bending of the stays will be required as per the pics Il Padrone posted above. The Soma fork has both front and rear eyelets. The Tubus Tara seems like a popular option.
My issue is that this bike will be my daily rider, and I don't want to run the racks unless I'm going on a "tour". As such, I'm looking for a solution where the mudguards attach to the rear eyelets, and the rack can go on and come off when I don't need it.
Any ideas?
E
- Wingnut
Postby Wingnut » Sun May 25, 2014 1:06 pm
http://velonews.competitor.com/2013/12/ ... ers_310996" onclick="window.open(this.href);return false;
Front Pannier Racks
Postby Espresso_ » Mon May 26, 2014 8:50 am
Postby Baalzamon » Mon May 26, 2014 1:26 pm
Postby Espresso_ » Mon May 26, 2014 9:06 pm
I had seen the Surly rack - looks hardcore! Maybe a bit of overkill for my one/two night aims, but will keep it in mind.
E
Postby Baalzamon » Mon May 26, 2014 9:47 pm
Postby Espresso_ » Mon May 26, 2014 9:59 pm
At the risk of hijacking the thread....
Its the advice I've been given by a lot of people lately, in terms of improving weight distribution and handling. It was also provided by the place where I got my bike fit done recently, given the top tube height for the bike I'm building is very high, and I may have difficultly mounting and unmounting with loaded rear racks.
E
Postby Baalzamon » Mon May 26, 2014 10:49 pm
- il padrone
Postby il padrone » Mon May 26, 2014 11:07 pm
Postby Espresso_ » Mon May 26, 2014 11:26 pm
Great. Add another one to the list of "the advice I've been given by a lot of people lately".il padrone wrote:Having travelled this way, I can confirm that front low-rider panniers, with a racktop bag or saddlebag is a very stable way to ride. Well-placed front panniers can barely influence the steering (apart from the added inertia). Avoid high-rise mounting though.
Looks like I might take a chance on the Tubus Tara ...
E
- outnabike
Postby outnabike » Tue May 27, 2014 9:53 am
I put a basket on as well as the panniers, that are now a permanent feature, but the centre of gravity is not a help when I put 6 kg in the basket. Fortunately it is seldom needed.
Postby Espresso_ » Tue May 27, 2014 11:31 am
But should I be concerned that the mounting point for the panniers is too high?
E
- Aushiker
Postby Aushiker » Fri May 30, 2014 12:40 pm
Aushiker.com
Postby Espresso_ » Fri Jun 06, 2014 9:44 pm
This photo shows the kind of mounting that I'm looking for, avoiding the rear eyelet/mudguard mount:
http://cyclingabout.com/wp-content/uplo ... 002-PM.jpg
E
- il padrone
Postby il padrone » Fri Jun 06, 2014 10:39 pm
Postby Espresso_ » Sat Jun 07, 2014 4:04 am
http://ep.yimg.com/ay/yhst-377369925495 ... gold-3.gif" onclick="window.open(this.href);return false;
However, it looks like the rear eyelet option might still involve the same issues that you raise.
- rifraf
Postby rifraf » Sat Jun 07, 2014 2:18 pm
I don't have an opinion on the pannier height but I would remind you about the Pass n Stow rack being painted cromo and its rust issue when the paint gets scratched which it undoubtably will.Espresso_ wrote:These Pass and Stow racks look interesting (and expensive). They seem to fix on the front fork eyelet, leaving the rear eyelet free for mudguard stays - perfect for my use. Plus they look sweet.
E
I think its a very attractive rack but for this quality.
If I was looking at something similar, I'd carefully consider some of the stainless options like the Velo Orange Porteur rack as an less attractive but more utilitarian and not to mention cheaper possibility.
http://store.velo-orange.com/index.php/ ... -rack.html" onclick="window.open(this.href);return false;
Postby Espresso_ » Sun Jun 08, 2014 10:05 pm
I'll report back on fitting issues once I've had a chance to get them on the bike (which would require the bike itself....but that should only be a matter of a week away).
While I was at it, I managed to get a pair of SKS Longboard mudguards in the order for the same all-up price as Wiggle et al. I ordered from Bike24 - let's see how the shipping times go.
E
- Warin
Postby Warin » Mon Jun 09, 2014 9:28 am
Postby Espresso_ » Mon Jun 09, 2014 9:45 am
Yep - not expecting it any time soon. Need it in 5 weeks, so let's see how I go!Warin wrote:The German post is slow. Expect 2+ weeks. Probably 3.
- il padrone
Postby il padrone » Mon Jun 09, 2014 11:34 pm
My son is using my old frame that has some scratches and scrapes that date back to 1997. They have a patina of surface rust, which has not changed, intensified nor worsened since about 1998.rifraf wrote:I would remind you about the Pass n Stow rack being painted cromo and its rust issue when the paint gets scratched which it undoubtably will.
- rifraf
Postby rifraf » Tue Jun 10, 2014 6:27 pm
Well I wasn't advocating the expense of a stainless steel bike frame but merely suggesting the possibility that some appreciate rust free racks.il padrone wrote:My son is using my old frame that has some scratches and scrapes that date back to 1997. They have a patina of surface rust, which has not changed, intensified nor worsened since about 1998.rifraf wrote:I would remind you about the Pass n Stow rack being painted cromo and its rust issue when the paint gets scratched which it undoubtably will.
I like my bike and don't mind spending money on good accessories if they enhance its use.
For my aesthetic taste, rusty racks look scruffy and detract from a bikes appearance compared to either freshly painted or chrome/stainless finishes.
Its merely my personal taste and not one that needs to be followed.
Knowing myself, I tend to take better care of something thats nice to begin with, so purchase accordingly.
Your tastes and idiosyncrasies may vary and I think thats fine too (for you)
I see no problem favouring form and function as they don't have to be mutually exclusive.
