Best place to mount a video camera?
- bychosis
Postby bychosis » Mon Jan 14, 2013 1:26 pm
I have read much of the who uses a video camera thread which tends to lean towards camera reviews etc. Where is the best/safest location to provide the most effective footage in the event of an incident. I am limited to one camera at present and do not spend a lot of time on busy, narrow roads but do travel through a couple of busy roundabouts and intersections. I am yet to decide on chest, helmet or bike mount, front or rear as most effective.
Mods please feel free to set this thread on your preferred course.
- hannos
Re: Best place to mount a video camera?
Postby hannos » Mon Jan 14, 2013 1:30 pm
personally I have a single GoPro and helmet mount it.
- Lukeyboy
Postby Lukeyboy » Mon Jan 14, 2013 1:35 pm
Safety wise I'd go for a helmet view for forwards/side views with one on the rear.
- 15wilsonwu
Postby 15wilsonwu » Mon Jan 14, 2013 6:30 pm
sonofthewind, is that you?Lukeyboy wrote:Top of helmet, side of helmet, chest, back, arms, top of handlebars, bottom of handlebars, on the drops, under the seat, on the stem, front, forward..... on the frame, under the frame, on the quick release...... that's all I have done
- Ultegra 6800
- Shimano RS31
- outnabike
Postby outnabike » Mon Jan 14, 2013 7:00 pm
Mine took a bit of fitting as I had to purpose make a bracket to suite my helmet. I find that the position on the right brings the cam to almost eye level, and it is easier to turn on and off. Mine has a very quiet little sound upon activation and it is clear at this position. Probably depends on the shape of the cam really.
I doubt my helmet would ever pass the AUS standard though. Pity as it only 12 years old too..... love my helmet, it is great for is blackberry picking.
- herzog
Postby herzog » Mon Jan 14, 2013 9:22 pm
And for onroad cycling, you're probably looking more to use it as an "incident" camera. In this case, if you're only running 1 camera, I think helmet mount is the go.
Helmet mount allows you to turn to film driver's face, numberplate etc. It also shows you making headchecks etc when changing lanes, which could be critical in a police investigation of an incident.
- Lukeyboy
Postby Lukeyboy » Mon Jan 14, 2013 11:02 pm
No... not that I know of15wilsonwu wrote:sonofthewind, is that you?Lukeyboy wrote:Top of helmet, side of helmet, chest, back, arms, top of handlebars, bottom of handlebars, on the drops, under the seat, on the stem, front, forward..... on the frame, under the frame, on the quick release...... that's all I have done
Postby GraemeL » Tue Jan 15, 2013 11:26 am
You can find the mount in my DIY mounts, link in my sig.
Graeme
Postby Farris » Wed Jan 16, 2013 11:08 pm
I've now got the GoPro mounted and ready for tomorrow mornings ride.
http://www.acecosportgroup.com/shop/k-e ... ounts.html" onclick="window.open(this.href);return false;
- ozzymac
Postby ozzymac » Thu Jan 17, 2013 2:48 pm
Farris wrote:I'd just like to add a warning here to people using or considering using the GoPro with the handlebar mount. I was riding my (road) bike a couple of weeks back and the handlebar mount snapped sending my new GoPro Hero3 crashing to the road, lucky for me it was early so no cars crushed the camera and aside from a few light scratches on the housing the GoPro continues to function. After this I did some research online and found that the original GoPro handlebar mount is subject to cracking and failing under stress and vibration particularly when used on road bikes. As a result I ordered two new mounts from an american company called K-Edge (link below) which arrived today via fedex less than a week after I had ordered them. The mounts are made from aluminium, are rock solid and come with a lifetime guarantee so well worth checking out.
Hi,
Mine did the same thing after using it only about 3 times. Piece of crap really, very badly designed and made. I find it very strange that the mating surfaces where the bolts go through are made shiney smooth so stop any movement they need to be done up very tight, which can only encourage things to break even quicker.
Sent from my GT-P5110 using Tapatalk 2
Postby gretaboy » Thu Jan 17, 2013 3:01 pm
I go rear facing also. I have a http://www.jejamescycles.co.uk/cntry-au ... 4godwCwASQ" onclick="window.open(this.href);return false; mount and it sits just under the saddle. Nicely out of the way..only issue is if you want to run a saddlebag there.GraemeL wrote:Rear facing would be the most important, if you have two cameras then obviously its front and rear. I like having the cameras mounted low, I have mine mounted on the quick release of either the front or rear wheel, these give the best view/angle I feel and it also has some on the wheel in the shot which helps give some perspective.
Graeme
This position gives a really good clear rear view recording location. You do pick up noise off the chain and road but I am not after the sound effects, more the video footage.
In time, when the budget allows I will be getting one for the front as well.
Postby Farris » Thu Jan 17, 2013 10:05 pm
http://vimeo.com/57565005
Postby GraemeL » Fri Jan 18, 2013 9:52 am
Having a single camera mounted on the rear gives good evidence in the event of an accident, the placement and movement of both the bike and the car can easily be seen along with any incidents that accur. Car swerving, close shaves, passenger throwing things, hanging out of the window ect.gretaboy wrote:I go rear facing also. I have a http://www.jejamescycles.co.uk/cntry-au ... 4godwCwASQ" onclick="window.open(this.href);return false; mount and it sits just under the saddle. Nicely out of the way..only issue is if you want to run a saddlebag there.GraemeL wrote:Rear facing would be the most important, if you have two cameras then obviously its front and rear. I like having the cameras mounted low, I have mine mounted on the quick release of either the front or rear wheel, these give the best view/angle I feel and it also has some on the wheel in the shot which helps give some perspective.
Graeme
facing forward, I feel you can see what is coming up and take steps to avoid a situation, but you cannot always see what is going on behind you.
If you are struck from behind it will capture the event and if it is a hit & run, a rear facing camera will capture a lot more than it would if mounted on a helmet, bars etc.
Graeme
- bychosis
Postby bychosis » Fri Jul 11, 2014 9:07 am
There is one section I regularly ride where there is a higher risk of hit from behind, and very low risk of getting pulled out in front of so the camera will probably be rear mounted there. Otherwise the risk mainly comes from being pulled out in front of, or cutting me off so a front view is more valuable for those.
- AUbicycles
- Site Admin
Postby AUbicycles » Fri Jul 11, 2014 10:43 pm
Unfortunately an accident can be in front (left turn across your path) or come from behind - not sure what may more more frequest - so the cheap mobius which is mentioned in the Video Camera thread may be the solution.
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
