Rohloff which Axle
Rohloff which Axle
Postby }SkOrPn--7 » Wed Jul 23, 2014 8:58 am
Thanks Ricky
- Leaf T
Re: Rohloff which Axle
Postby Leaf T » Wed Jul 23, 2014 9:04 am
What frame are you going to be using?
- Wingnut
Postby Wingnut » Wed Jul 23, 2014 10:20 am
Postby }SkOrPn--7 » Wed Jul 23, 2014 1:05 pm
Ricky
- Leaf T
Postby Leaf T » Wed Jul 23, 2014 2:05 pm
- RonK
Rohloff which Axle
Postby RonK » Wed Jul 23, 2014 6:04 pm
With vertical dropouts you will need a chain tensioner unless you have an EBB to adjust chain tension.
Depending on the type of dropouts you will need either one of the several types of OEM axle plate or a torque arm. Use the selection wizard on the Rohloff site to guide you.
Post a pic of your dropouts from the left side.
Postby }SkOrPn--7 » Thu Jul 24, 2014 11:45 am
I'm still looking over the Rohloff site I'm looking at the disk hub version so if you can tell by my images to what I'm needing then thanks. I'm guessing that I can mount the chain tensioner to my existing hanger?
Ricky
- rifraf
Postby rifraf » Thu Jul 24, 2014 4:11 pm
have you blown your Dual Drive?
Whilst I believe running stock standard within warranty gearing ratios, the Rohloff is a stronger unit, they are still breakable which is the reason Rohloff offer strict guidelines with regards gearing ratios to utilise their warranty.
Last I looked, for rider under 100kg, Rohloff says 34T/16T for a 700c/29er wheel.
You'll have to check their site for 20' (406) rim sizing.
I'm waffling about the gear ratios as a I believe its the super deep reduction low range use (triple front chainring on cranks) that makes the dual drive spit the dummy but they remain good bang for buck with the caveat of being somewhat challenging to source parts (from what I've heard)
If I was revisiting my hub purchase, rather than the QR I'd currently be leaning towards the threaded axel but Wingnuts logic sounds fine to me for your use.
If you get serious about the Rohloff, do try to take one for a ride first before taking the plunge as in my opinion they can be an acquired taste and are not for everyone.
I"m not getting online much currently due to my some expenditure taking priority over my prepay purchase but I'm trying to get to the library every few days, so apologies in advance for any late replies on my part.
Postby Mike Ayling » Thu Jul 24, 2014 5:25 pm
It has vertical dropouts and EBB.
Mike
- il padrone
Postby il padrone » Thu Jul 24, 2014 5:41 pm
Or if that doesn't reach there is the Speed Bone
- RonK
Postby RonK » Thu Jul 24, 2014 6:30 pm
OK, I just need to know what colour hub (silver, red, black), disc size and the brand of caliper and I can get you the list of part numbers off the Rohloff wizard.}SkOrPn--7 wrote:Here are some images Ron...
Ricky
I presume you'll need some shifter cable clips and the like too.
- RonK
Postby RonK » Thu Jul 24, 2014 6:32 pm
Both an OEM2 Axle Plate and a Speedbone will be required.il padrone wrote:You will not be able to use an OEM short torque arm base-plate with the dropouts you have, but rather than the long torque arm you should be able to use the special OEM base-plate that slots against your disc caliper mount
Postby }SkOrPn--7 » Thu Jul 24, 2014 10:47 pm
Hi Aidan no the duel drive is fine it's built up on another rim. My last around Australia journey I just did I swapped out those wheels for a new set and I went back to the conventional hub and cassette with custom made granny chainring and cassette sprockets. My rear wheel is 24" and with the setup I'm planning the warranty will be voided but warranty doesn't mean anything to me as I belief Rohloff are placing way too much caution on there product regarding torque. I also believe that with the setup I'm planning you would still be hard pressed to shear there pin.rifraf wrote:Hi Ricky,
That's the reason I went back to a conventional hub because parts for a duel drive are like hens teeth. I don't think I will be able to test drive a Rohloff and from reading all the praise from you guys I think I have a pretty good judgement that I can make it work and get the gear inch I want knowing the warranty will be binned but still function without blowing the hub.
No worries Aidan I fully understand I haven't been aroaund much myself life is busy for me as well. I just finished high pressure spraying the bike to blow all the mud and crap off it from my last tour and rebuilding it to get it reading again but the Rohloff has been jabbing me in tbe sides and now I'm seriously looking into it.
Ricky
Postby }SkOrPn--7 » Thu Jul 24, 2014 10:59 pm
Hi Ron I'm going with a red disk hub 203mm rotors and because most of my spare parts I have I will stick with Avid. Yeah I will need the complete caboodl and the longest cables they have. I will also order there spare parts box set and tool set. Were are you guys all buying Rohloff gear from?RonK wrote:OK, I just need to know what colour hub (silver, red, black), disc size and the brand of caliper and I can get you the list of part numbers off the Rohloff wizard.}SkOrPn--7 wrote:Here are some images Ron...
Ricky
Thanks Ron
- RonK
Postby RonK » Thu Jul 24, 2014 11:54 pm
I got my hub from Bike24, others from StarBike. Be careful ordering though, it's easy to exceed the $1000 threshold and then getting hit with import charges.
Of the suggested parts you won't want the downhill parts so probably just a handful of cable clips.
:We recomend the following version of the SPEEDHUB 500/14:
Art Nr: 8026 SPEEDHUB 500/14 CC DB OEM Red
Art Nr: 8250 Chain Tensioner Order together!
Art Nr: 8227 Axle Plate CC OEM2 Order together!
Art Nr: 8286 Brake Disc 203 mm for Shimano DH, Hayes, Formula Order
together!
Art Nr: 8550 Speedbone Order together!
Chosen Brake: Avid - 203
ATTENTION:
Rohloff OEM2 - When permission has not been granted by the frame manufacturer to mount the Rohloff SPEEDBONE or the support bolt through the disc brake mount, then mounting of the OEM2 versions is at your own risk.
Spokes for the wheel:
Attention, The lacing into a rim of the Rohloff SPEEDHUB 500/14 requires special spoke lengths!
The following articles could also be ordered for the hub:
Art Nr: 8290 Chain Guide
Art Nr: 8293 DH-Kit
Art Nr: 8291 Downhill-Guide
Art Nr: 8245 DH Chain Tensioner Shorty
Art Nr: 5200 Cabelclipp
Fundamentally, we recomend for your bike: Bicycle Insurance
We reccommend the additional use of a Pitlock System as protection against theft.
© by Rohloff AG -- Technical specifications are subject to change without notice. E & oe.
ID: a4.SB-1.s3.FR.T-0 --- Thu Jul 24 23:41:48 GMT+1000 2014 --- Daten-Version: 2006.02.08
Postby }SkOrPn--7 » Fri Jul 25, 2014 8:55 am
I'm aware of the $$$ limit but you can't avoid the over limit on the hub alone but I can break all the other items into smaller orders. Those same stores also sell the Schlumpf Mountain Drive do you know? I can look those up anyway when I get time to see the stores you listed.
Cheers Ricky
- Warin
Postby Warin » Fri Jul 25, 2014 9:50 am
- Leaf T
Postby Leaf T » Fri Jul 25, 2014 10:37 am
And as I mentioned above I would check pricing with Rohloff Australia directly because you may find it better than overseas and much faster delivery. No connection with Rohloff Australaia myself other than mostly excellent warranty support.
- Leaf T
Postby Leaf T » Fri Jul 25, 2014 10:46 am
- Wingnut
Rohloff which Axle
Postby Wingnut » Fri Jul 25, 2014 12:10 pm
I went with a bike shop instead of online as it's handy when help is needed and warranty issues...the savings just weren't enough to justify going overseas for me...Andy wrote:And as I mentioned above I would check pricing with Rohloff Australia directly because you may find it better than overseas and much faster delivery. No connection with Rohloff Australaia myself other than mostly excellent warranty support.
Postby }SkOrPn--7 » Fri Jul 25, 2014 2:09 pm
Ron I won't need a speed bone with this setup will I?
http://www.cyclemonkey.com/monkey_bone.shtml
http://cyclemonkey.bigcartel.com/product/monkey-bone
Ricky
- RonK
Postby RonK » Fri Jul 25, 2014 5:17 pm
Nope, it's either/or. The Monkeybone looks like a worthwhile improvement.}SkOrPn--7 wrote:Thanks Andy I will look into all means Wingnut but I need to purchase a rim from the US and I know my supplier will build the Rohloff into my rim just saving me a task so I'm happy to pay for any cost to import. I will just get him to place it on a bike to test before sending then it's secondhand and invoices can be changed to reflect the $1000.00 limit
Ricky
Andy would be right about the axle spacing of the tandem version, but at midnight I couldn't think of it for the life of me. It's only the axle plates that are wider, not the hub, so no advantage to be gained
I wouldn't fuss too much about the cables - as mentioned they are the same pattern as Shimano and you should be to get tandem cables locally if need be.
Postby }SkOrPn--7 » Sun Jul 27, 2014 9:59 am
Ricky
- il padrone
Postby il padrone » Sun Jul 27, 2014 10:50 am
However the Monkeybone does look to be a cleaner solution.
