The new and interesting touring gear thread...
- Wingnut
Re: The new and interesting gear thread...
Postby Wingnut » Wed Jul 30, 2014 8:27 pm
http://theradavist.com/2014/07/blackbur ... ng-system/" onclick="window.open(this.href);return false;
- Aushiker
Postby Aushiker » Mon Aug 04, 2014 10:51 am
Spot Gen3
The promoted new features are:
New features Options:
Tracking motion-activated regardless of the level of tracking you choose (Basic, Unlimited or Extreme). A vibration sensor tells your SPOT to send track updates when you are moving and to stop when you do. This is a great new battery-saving feature!
Unlimited Tracking Set it and forget it. Pre-set your SPOT Gen3 to send tracks at the speed of your adventures. Change your tracks to send every 5, 10, 30, or 60 minutes. SPOT Gen3 will send tracks at your chosen rate for as long as your device is turned on and moving (no need to re-set after 24 hours). Tracking doesn't stop until you do.
Extreme Tracking Get all of the great features of Unlimited Tracking, but with the added ability to vary your track rate down to every 2 ½ minutes. D
Longer Battery Life SPOT Gen3 has approximately twice the battery life of the SPOT Satellite GPS Messenger!
Battery Options Now there are more options for how you power your SPOT:
4 AAA Energizer® Ultimate Lithium 8x Batteries (L92)
4 AAA Energizer® NiMH reusable batteries (NH12)
Line power with a 5v USB connection. (SPOT Gen3 is not waterproof when line powered.)
Aushiker.com
Postby TouringPhil » Tue Aug 05, 2014 12:27 pm
The Gen3 looks interesting but it's a bit expensive by the time you pay for this device and the ongoing annual fees. Still looks like a great little unit, in particular this latest version just released.
I'm considering, something similar to monitor my Bike, while I'm out and about, therefore if someone so happens to manage to pass my Kryponite Lock on my bike and rides off, I'll be allerted to this on my mobile phone and able to track my bike.
I'm looking at something like this.
http://bikespike.com/" onclick="window.open(this.href);return false;
- Aushiker
Postby Aushiker » Fri Aug 15, 2014 11:00 pm
Aushiker.com
Postby }SkOrPn--7 » Sat Aug 16, 2014 2:43 pm
Andrew where did you purchase it I'm in for buying one?Aushiker wrote:RonK and now myself are users of Anker's 5-Port 40W USB Charger. It is great to see that the Anker charger now gets the Techmoan treatment.
Ricky
- RonK
Postby RonK » Sat Aug 16, 2014 3:24 pm
He said what I said - you just can't beat it for a traveller's aid. I've been using mine for a month now and I'm delighted with it. As I write it is charging two iPads, an iPhone, a Magellan Cyclo and a Shimano Sports Cam. No sweat.Aushiker wrote:RonK and now myself are users of Anker's 5-Port 40W USB Charger. It is great to see that the Anker charger now gets the Techmoan treatment.
I assume that Andrew got his from King Power Accessories, same as I did.
- Aushiker
Postby Aushiker » Sat Aug 16, 2014 5:52 pm
Yes same place. I am thinking of getting a second one to leave at the office. Having the cameras on the bike and GPS to charge when I commute I see it as been an ideal solution.RonK wrote:I assume that Andrew got his from King Power Accessories, same as I did.
Aushiker.com
Postby }SkOrPn--7 » Sat Aug 16, 2014 7:25 pm
Ricky
- RonK
Postby RonK » Sat Aug 16, 2014 7:55 pm
HK, which is probably UK anyway. But the cords are common and I had a bunch of them already.}SkOrPn--7 wrote:Thanks for that what plug did it come with HK, UK or Aus?
Ricky
Postby }SkOrPn--7 » Sat Aug 16, 2014 8:25 pm
Thanks Ron I'm going to place an order now.RonK wrote:HK, which is probably UK anyway. But the cords are common and I had a bunch of them already.}SkOrPn--7 wrote:Thanks for that what plug did it come with HK, UK or Aus?
Ricky
Ricky
- Aushiker
Postby Aushiker » Mon Aug 18, 2014 10:02 pm
I now have one ex Japan. Very solid feel to it, charging my phone as I type. Seems to be quick with the charging. I got it from ebay seller, tokyofreaks23 for US$62.00.Aushiker wrote:The Anker Astro E5 15000 mAh looks like a reasonable compromise for me ... 10,500 to 12,000 mAh in reality which isn't to bad, two USB outputs at 1 amp and 2 amp and USB charging at 1.5 amp if going just for a battery.
Aushiker.com
Postby TouringPhil » Mon Aug 18, 2014 11:05 pm
Whats the weight?Aushiker wrote:I now have one ex Japan. Very solid feel to it, charging my phone as I type. Seems to be quick with the charging. I got it from ebay seller, tokyofreaks23 for US$62.00.Aushiker wrote:The Anker Astro E5 15000 mAh looks like a reasonable compromise for me ... 10,500 to 12,000 mAh in reality which isn't to bad, two USB outputs at 1 amp and 2 amp and USB charging at 1.5 amp if going just for a battery.
Sent from my GT-N5110 using Tapatalk
- il padrone
Postby il padrone » Tue Aug 19, 2014 6:03 pm
Postby chillimagnum » Wed Aug 20, 2014 1:47 am
That seller says he sells Japanese products but the Anker website I can't find that information.
With a 5V / 1.5A micro USB input, then ewerk with 5V 500mA output would be too slow to recharge? This would require a solar panel for off grid recharge?
- Wingnut
- Leaf T
Postby Mike Ayling » Mon Aug 25, 2014 9:07 pm
And only 150 Euros!Andy wrote:A very neat little dynamo and only 70 grams.
Mike
- kx315
Postby kx315 » Tue Sep 02, 2014 1:38 pm
2013 Giant Defy Advanced 0
2016 Giant TCR Advanced Pro 0
- RonK
Postby RonK » Thu Sep 11, 2014 3:35 pm
Well, I dunno about cardio-control, but what I do like is that it's for a rear wheel and is both cassette and disc brake compatible.
Postby TouringPhil » Thu Sep 11, 2014 4:07 pm
Love your website RonK. I'm going to start reading now.
- RonK
Postby RonK » Thu Sep 11, 2014 5:26 pm
It's been a long while between updates Phil - work commitments have curtailed my touring activities for a couple of years, but I have unfinished business in EnZed and I'll definitely be heading off again soon...TouringPhil wrote:Love your website RonK. I'm going to start reading now.
- outnabike
Postby outnabike » Sat Sep 13, 2014 1:06 pm
Postby Baalzamon » Sat Sep 13, 2014 4:21 pm
Bit late, Aug 27 - 30 2014outnabike wrote:So who is going to the Euro bike show in Germany to see the latest gear on display. http://www.eurobike-show.com/eb-en/" onclick="window.open(this.href);return false;
- Wingnut
- RonK
Postby RonK » Tue Sep 30, 2014 6:21 pm
