Your "Second Wind"
- flashpixx
Your "Second Wind"
Postby flashpixx » Wed Sep 03, 2014 12:46 pm
For the first 10 - 15 mins of a ride I lack the stamina that I have later in the ride. Back whan I was a kid we used to call this getting your "second wind", but it would come much later.
Interested to read some more on this if there are links on the subject. I wonder if I should just take it a bit easier for the first 10 mins. Just seems strange that a hill that presents no problem after 30 mins almost blows me up in the first 10 minutes.
Riding: Trek Domane SLR 7
- silentC
Re: Your "Second Wind"
Postby silentC » Wed Sep 03, 2014 2:01 pm
- Me
- burger
Postby burger » Wed Sep 03, 2014 2:16 pm
I'm a similiar age to you and find I'm far more breathless in the first 15 mins of a ride than over that same stretch later in a ride.
I reckon it's my body just takes a bit longer to realise it needs to kick into gear for exercise/work.
I dont remember feeling that when riding as a kid, mind you it was a while ago
I also think back to my tennis days and how much more warming up was needed increased as we 'matured'.
As a young'un? just go on the court and play . .. .
A not so young'un? maybe rolling the shoulders over a bit, maybe run up and back the court a few times before hitting up. .. .
Then when definitely not a young'un (and before I stopped playing) much more warming up with game simulating movements and stretches were required . . both before and after the games.
cheers,
stu.
Postby ball bearing » Wed Sep 03, 2014 2:47 pm
Postby Aussiebullet » Thu Sep 04, 2014 4:47 am
It takes me 20 - 45min to really feel switched on, I don't feel "out of breath" at the start but sometimes feel like it's just not gunna happen today kinda feeling.....
Those days seem to be the ones where I'm really able to pull something special out of the hat so I've learnt to ignore how I feel at the start of any ride/training session, mind you when putting in 400+km p/wk most rides start out a little sluggish!
- bychosis
Postby bychosis » Thu Sep 04, 2014 7:48 am
- gorilla monsoon
Postby gorilla monsoon » Thu Sep 04, 2014 12:13 pm
Same. First two or three clicks I think "there must be something wrong, I can't continue" but persevere and after 15 minutes or so I'm powering up. I thought it was because I am (a) overweight and (b) because I smoked from the time I was 15 until I was 50 (with an eight-year gap in my 30s).silentC wrote:I have the same issue. I'm sure someone knows the science behind it and would be interested to hear it too. Not because it bothers me or I feel I need to do anything about it, I'm just curious as to why.
Strange as it might sound, I'm actually happy to hear others have the same problem!
Postby lobstermash » Thu Sep 04, 2014 12:22 pm
- gorilla monsoon
Postby gorilla monsoon » Thu Sep 04, 2014 3:05 pm
Postby lobstermash » Thu Sep 04, 2014 3:57 pm
- Storm Boy
Postby Storm Boy » Thu Sep 04, 2014 10:44 pm
Regards,
SB
Edit: if you are short of breath your HR will be too high at that point in time, just take it a little easier until you are warmed up. I'd call it a first wind, not a second one
- Xplora
Postby Xplora » Thu Sep 04, 2014 11:20 pm
Postby CKinnard » Fri Sep 05, 2014 5:05 am
O2 debt is generated as cardiac output and energy metabolism lags the needs of muscles when starting exercise.
This debt occurs with less intense exercise as one ages. This is because the systems that control your heart rate and stroke volume become more sluggish with age. It is the same for the systems that control energy substrates (CP-ATP, glycolysis, mitochondrial respiration). These take longer to respond to more intense demands for energy.
i.e. when younger
- your HR and stroke volume increase a lot quicker and higher, thereby providing more blood much quicker than when old.
- blood from your abdomen can be mobilized a lot quicker to supply working muscle
when older
- your cardiac output is limited by slower heart rate, less powerful cardiac muscle contractions, less compliant arteries.
- you do not tend to stay adequately hydrated due to dulled thirst mechanism. This reduces blood volume and capacity to deliver adequate oxygen and nutrient in the early stages of exercise.
You avoid or reduce oxygen debt by beginning exercise at a low intensity. This will keep you using fat as a primary energy substrate via the aerobic respiration pathway, and reduce considerably tapping into CP-ATP and glycolysis. At rest and doing any light work, you are using primarily aerobic energy pathways and burning primarily fat.
Keep in mind too that if you are overweight, you will be insulin resistant to a varying level. This will play havoc with your ability to utilize fat and non fat energy sources - and therefore make you more restricted in the intensity of exercise you can do in the early stages of exercise. (insulin resistance adversely effects ability to mobilize fats. higher baseline insulin levels impede glucagon levels. this is partly why fatter people tend to be hungrier more often).
If you do any racing, especially in Masters, you can take advantage of all of the above by getting a proper warmup, and attacking from the whistle. You will have a distinct advantage over those who didn't warm up, or are overweight. Though obviously a good idea to attack with several others so you can sustain the advantage once everyone has warmed up!
- silentC
Postby silentC » Fri Sep 05, 2014 9:09 am
So it's like I'm running a dual-fuel system, where one fuel is more readily available for short bursts but less efficient, and the system takes awhile to gear up to using the more efficient fuel.
- Me
- Xplora
Postby Xplora » Fri Sep 05, 2014 12:04 pm
- silentC
Postby silentC » Fri Sep 05, 2014 12:21 pm
So I guess we'd better pay attention to it and run on idle for the first 15 or 20 minutes. Makes it difficult when you have to ride up a hill to get anywhere...
- Me
- Xplora
Postby Xplora » Fri Sep 05, 2014 12:48 pm
- foo on patrol
Postby foo on patrol » Fri Sep 05, 2014 2:31 pm
Bingo!Aussiebullet wrote:Or in other words "Warming up"
Foo
Goal 6000km
- clackers
Postby clackers » Fri Sep 05, 2014 2:36 pm
The pros are on the rollers before a time trial so they get that 10-20 minutes out of the way before they start, Flashpixx.flashpixx wrote:
- flashpixx
Postby flashpixx » Fri Sep 05, 2014 9:15 pm
Thank you - excellent explanationCKinnard wrote:Google "oxygen debt" and EPOC (excess post-exercise oxygen consumption.
- g-boaf
Postby g-boaf » Mon Sep 08, 2014 1:07 pm
I'm the same as you - it takes me about 25km to properly get going and get rid of that sluggish, breathless feeling. Good to read this and know what it is - makes sense.Aussiebullet wrote:Or in other words "Warming up"
Explains the 2x18 intervals I did the other week - first one felt like I was going to die (until the computer controlling the trainer crashed), second one did it very well - controlled breathing - heart rate seemed okay.
Postby BaldPatch » Mon Sep 08, 2014 8:25 pm
Have competed in the C2C multi day race a couple of times and have noticed heart rate is much lower on the final two days, there is less elevation change on the final two days but my theory is i ride myself "into fitness"
Postby Eleri » Tue Sep 09, 2014 8:58 pm
I hate that feeling of breathlessness, high HR and sometimes even tingles in my fingers and upper arms. Used to happen when playing footy too. It always goes away, which is the good thing to know, but I can't make it go away more quickly. Just have to work around it I guess. Mind you, once I wind up I can ride huge distances - I've done lots of 200km+ rides including a few 300s. I guess I'm just an enduro.
Postby durianrider » Tue Sep 09, 2014 9:46 pm
Most riders don't ride with a power meter so have no real idea what they are actually doing. Av speed means little as road surface, wind direction, tire pressure, jersey flap, bunch position etc can all affect that. HR is affected too much by stimulants, adrenaline and the change of pace in cycling means HR lag of a few minutes can lead to misleading data.
Watts per kg is the most accurate way to gauge real effort with your 3second wattage being the most helpful thing to watch whilst riding. Combine that with a cadence around 90rpm. Good to go.
Most riders have a big breakfast and that means blood will be diverted from the cardio system to digestion. You will feel a bit 'heavy' when you try to breathe but your full stomach is hindering it a bit. No probs, if your meal was high water content like fruit smoothie, rice and soy milk then it will digest a lot faster than a bacon and eggs. (hence why all pro riders eat high carb breakfasts for faster digestion).
You will find the riders who are strong on long weekend rides are usually the same riders that get dropped early on. These riders know how to eat large meals therefore will have larger glycogen reserves than the riders who eat little breakfasts but can punch hard for 1hr till the glycogen tank is running low.
Another factor is when glycogen is running low, the body releases adrenaline so you get a mad kick of blood sugar to the cells and your watts can go up. Stage 14 in the Vuelta 2014 was evident of this when Ryder got dropped by Zaugg who had a shot of adrenaline but bonked just before the line and was caught by Ryder.
Zaugg would have won literally if he had just a single gel or bottle of sugar water.
So what is the work around to having good wattage for the early climbs yet be able to stay strong for another 300km in the saddle?
What I do is consume 10g of carbs per kg of bodyweight per day, keep my fat and protein intake under 50g each approx and find this allows for peak glycogen retention. The low fat diet allows for better blood transfer (RBC's stick together in the presence of excess dietary fat) and the low protein allows the kidneys to better regulate natural EPO levels which boost hemoglobin production. RBC's are also fueled by sugars.
All I do for any long and fast ride is the same for any work day behind the computer.
Start the day with a quart of water, knock back a piece of fruit and get to it.
With in an hour of waking I try and take in 500-1000cals of fruit in the form of smoothie or juice.
The high water content means in 20mins, you are going to be able to hammer hard on the bike.
So I wake up, scull a quart of water or take it on the bike, have 500-1000cals of simple sugars in that first hour on the bike then about 400cals of sugar, dates or gels each hour after.
If you are stopping for lunch somewhere, knock back a litre of added sugar golden circle pineapple juice. When everyone is getting their legs fatted out from a grease meal, you will be smashing them up the last climb relative to what you would otherwise.
Yes you will hit the toilet/bushes more but Ive spent time with racehorses and never seen a constipated or dehydrated race horse. Every pro team Ive ever trained with stopped every 1.5-2hours for a nature break. Dehydration kills performances as your blood volume drops (hypovolemia) and you run the risk of hyponatremia etc as your kidneys can no longer regulate sodium/potassium levels effectively. To prevent this I take in 500ml per hour in colder weather and 1 litre per hour in hot weather. I always ensure clear unrination (unless you are eating cereals fortified with B vitamins then it will be yellow for an hour or after drinking beet juice it will be purple).
The science of warming up just gets the muscles at the right working temps and stimulates enzymes to aid in mitochondrial efficiency. Here is what Team Sky do before a TT. (Zones = riding to wattage)
Postby durianrider » Tue Sep 09, 2014 9:52 pm
1. Its normal and healthy to cough up some crap. The lymphatic system is part of our 'waste removal' system and the lungs will get rid of any junk if they need to. Cycling will pump the lymph and aid in waste removal.BaldPatch wrote:I often feel pretty ordinary for the first 10 km and am spitting out Phlegm although i am Asthmatic.
2. HR means little. It shows you how you are responding. Get a power meter so you can actually see for the first time ever, what you are actually doing in real time. My HR for 10mins at 6 watts per kg is only a couple of beats higher than my HR for a marathon. Nobody in the world can ride at 6 watts per kg for 2hours 48 though. Another example of why HR is a poor indicator to compare your fitness gains or losses to.
Those who can ride 200km, they can easily ride 400km if they ride between 100-200w and carb up with 1g of carbs per kg of bodyweight and drink enough for clear urine every 2 hours or so. Just comes down to chaffing tolerance after that.
