Brisbane Racing Scene
Postby jack11 » Wed Jul 17, 2013 9:54 pm
Re: Brisbane Racing Scene
Postby master6 » Thu Jul 18, 2013 8:10 am
Have a look at Cycling Queensland site for a list of clubs.
Google "Hamilton Pine Rivers Wheelers", and at their site, subscribe to their excellent weekly newsletter email.
Postby Crawf » Thu Jul 18, 2013 9:35 am
New crit track at Ipswich, not sure on dates.
Crits also down on the Gold Coast at Nerang & Runaway Bay.
Someone else can fill you in on Sunshine Coast.
Plenty more going on, best thing to do is check the online calendars of clubs and you'll be aware of just about everything - HPRW, CATS...
Postby DavidI » Thu Jul 18, 2013 10:18 am
Gold Coast has road races as well as the aforementioned crits.
You can pretty much find a club race somewhere every weekend if you want.
Postby Abby » Thu Jul 18, 2013 1:14 pm
HPRW at Nundah & Lakeside. Balmoral at Murarrie. Ipswich at, well, Ipswich. Logan at Crestmead. Lots of Gold Coast races a short drive down the highway...
You have to join a club to be able to race, but you can pretty much do all the races for all clubs (mostly) once you are a member of one club... (make sense?). Wait until you knwo where you are going to be living, & base your club choice on that - pick teh one that has the closest racing/club rides to you...
Abby
Postby marinmomma » Thu Jul 18, 2013 4:38 pm
During summer they rotate between Lakeside and Nundah.
Upside to being on the s/s is that you're closer to the Logan and Gold Coast races.
Balmoral race every week, just crits though.
Gold Coast have a good mix of road and crit on three different circuits, Nerang being a tough bugger of a course...no wonder the coast riders are so good!
Logan isn't always on and the numbers are smaller than HPRW/Balmoral which could be a good thing if you are just getting into racing.
Ipswich use a road circuit at Wacol or out further at the facility used for motorsports.
There are other clubs around check out the Cycling Queensland website for the full list and more info.
Hth
- Lukeyboy
Postby Lukeyboy » Thu Jul 18, 2013 11:05 pm
Postby thearthurdog » Fri Jul 19, 2013 5:42 am
Postby jack11 » Sun Sep 14, 2014 9:15 pm
1. Living in St Lucia I am close to a number of clubs, but do not mind traveling, can anybody recommend one of the brisbane based clubs or give an insight into the 'culture' of the clubs?
2. Which of the two criterium tracks would you recommend starting at (Nundah or Muzz)?
3. How does the grading process work for a new rider? I am somewhat petrified of being thrown in the deep end because I am young and in reasonable shape.
4. Any other key info I should know before I start?
- Lukeyboy
Postby Lukeyboy » Sun Sep 14, 2014 9:28 pm
Start at Nundah. Alot safer than Muzz as its wider.
Grading varies. Some clubs will throw you into C grade while others will put you in B grade - depending on your age/fitness etc.
Postby jack11 » Sun Sep 14, 2014 9:50 pm
The thought of being thrown into B grade is terrifying, I've heard the average speed is more than 40kmh?Lukeyboy wrote:Grading varies. Some clubs will throw you into C grade while others will put you in B grade - depending on your age/fitness etc.
Most of my rides (solo or in a small group) would normally be between 27 and 31 kmh
- brett.hooker
Postby brett.hooker » Sun Sep 14, 2014 9:54 pm
Nundah would be my choice of the two.
Postby jack11 » Mon Sep 15, 2014 9:38 am
That is a great idea. I think speaking to the handicapper and asking to be put in a lower grade so that I can concentrate on learning to race safely rather than potentially riding dangerously because I am on the limit/fatigued.Oxford wrote:When I decided to race at HPW crits, the handicapper threw me into B grade because I also raced MTB. It was hard work in many ways. The best thing to do is talk to the handicapper (his name escapes me just now for HPRW) and talk to him. At one time when I had fallen out of fitness I came to an agreement that I could race a lower grade, but would pull up at the end if I was in contention. I personally didn't feel right taking honours if I was under graded.
Postby CKinnard » Mon Sep 15, 2014 10:32 am
I agree Nundah track is safer for beginners, flatter, and less changes in surface and width. but it still has its dangers.
Before you race, I'd recommend you go down the track around 430pm Tue,Wed, or Thu. There's paceline training then, and it is good to learn how to draft and work in a group before doing it when everyone is in race mode.
Some pointers : (most of these maybe on HPRW's website now)
- always always ride straight and predictably. never steer violently, unless avoiding an imminent crash.
- accordingly, before changing line or veering to go around someone, do a shoulder check and be sure you have room to come out. you can even put your finger out to indicate. this highlights that you should practice looking around behind you to both sides while holding a straight line, and you should do it quickly. Guys have gone down when looking around and the pace in front slows temporarily.
- when moving through corners or curves, think of the riders around you, esp to the sides, and give them room to get around as well. Don't squeeze them into a corner.
- when drafting, never overlap your front wheel with someone else's rear wheel, apart from momentarily as indicated in the points below. If someone in front veers suddenly, they will hit your front wheel, and you will go down hard and most likely break bone/s.
- when drafting, always have an escape route planned if something happens in front...either be prepared to go to the left or right. don't automatically grab a handful of brake every time the pace slows or something happens in front.
- it's best to keep turning over your pedals (soft pedaling) when the pace changes. don't freewheel a lot.
- never sit up and slow down in a race until you are well past the finish line. the nature of racing is that you will have people drafting you.
- if you see someone riding in a way that is going to cause an issue, shout something sooner rather than later. a lot of people who have raced for a long time can still do silly things or lose concentration.
- if you are going to take a swig from your water bottle or otherwise do something distracting, be quick about it, and back off the wheel in front a bit. and be very very careful putting the bottle back in the cage. personally I don't drink during a race unless down the back after an effort.
- if you find yourself on the front of the pack, and want to come off, shoulder check to your left, and indicate iwth your right elbow for the guys behind to come through on your right (presuming you are racing clockwise).
- For your first 5-6 races, just hang down the back (but wheel sucking) for the first few laps, and watch what's happening in front. Then for the last two laps (when the 2 lap sign is held up), go down the back and don't try and race. Races get more aggressive and dangerous in the last two laps. even if you think you are strong and can contest the last 2 laps, if you fatigue or the pack lifts the pace, you will be in a precarious position with a lot of guys trying to get around you any way they can, and it can get real ugly.
- if you find yourself in a breakaway, share the lead with the others. best to do shorter turns (15-30 secs) until you know your threshold.
Postby Abby » Mon Sep 15, 2014 10:37 am
Your CQ licence will let you race at Murarrie (Balmoral) and Nundah (HPRW) crits anyway (bar the very occasional club-only crits there).
As a general rule, when picking a club, have a look at where their training/bunch rides start/finish. If its local, that's obviously a big plus...
Abby (A Balmoral member, for the record...)
Postby Crawf » Mon Sep 15, 2014 11:50 am
I've never been graded for any club crits, just turn up and put yourself in the most appropriate. Open events of course you need official grading.
Postby jack11 » Mon Sep 15, 2014 1:07 pm
Planning on heading down to Nundah this saturday with a few mates to do some laps and interval work. What time does the track normally free up after the morning crits?
Postby CKinnard » Mon Sep 15, 2014 8:35 pm
Postby marinmomma » Tue Sep 16, 2014 1:40 pm
HPRW is my club, Adam will sort you out details on the clubs we page, if Terry was still the handicapper he would have put you straight into B because your young and fit....Adam would probably put you into C and see how you go.
As I wrote earlier HPRW have a good mix of racing, we're about to move into summer which is Crits at either Nundah or Lakeside, and the twilight series.
Agree that Nundah is a safer track, Muzz is notorious for crashes and massive numbers.
The negative with HPRW is the kit is crap
Postby marinmomma » Tue Sep 16, 2014 1:42 pm
Crawf wrote:RE gradings, just turn up and tell them what grade you want to race in when you hand over the cash, you will be fine in C (AT) Nundah or crashville (Muzz).
Have you ever tried to get past Esme at Muzz...you can't rock up there and sign up for A, and Adam has cracked down on the self-promoting at Nundah as well
Postby jack11 » Tue Sep 16, 2014 1:56 pm
Thanks very much for the response. What is the average speed of a C grade crit at Nundah?marinmomma wrote:From memory you have to be a UQ grad to get into the club, could be wrong though.
Postby CKinnard » Tue Sep 16, 2014 3:50 pm
C1 40-42kph
C2 39-41kph
though the average speed doesn't signify much. any Joe can sit in a large pack at 40-45kph and soft pedal a lot. you get sucked along more than you can imagine (if you haven't been in a big pack before).
just make sure you never fall off the back!
imho, racing C2 (older guys) is harder because the numbers are lower, it tends to be a strung out single line rather than a bunch, therefore you don't get as much draft effect.
Postby marinmomma » Tue Sep 16, 2014 7:05 pm
Yep, what he said!CKinnard wrote:presuming no wind and a reasonable number
C1 40-42kph
C2 39-41kph
Really depends on who turns up on the day and their plans for the race
Postby jack11 » Tue Sep 16, 2014 8:35 pm
I have no idea if I would be able to hold that pace, but I guess all I can do is work hard until the start of October and hope for the bestCKinnard wrote:presuming no wind and a reasonable number
C1 40-42kph
C2 39-41kph
- Lukeyboy
Postby Lukeyboy » Tue Sep 16, 2014 9:19 pm
Breakaway! Breakaway! Breakaway! Breakaway! Breakaway! Breakaway!marinmomma wrote:Yep, what he said!CKinnard wrote:presuming no wind and a reasonable number
C1 40-42kph
C2 39-41kph
