My 510 more reliably connects to my Samsung S4 if I open Garmin Connect and leave it running in the background.lobstermash wrote:Finally figured out a process that seems to work... un-pair, power cycle Garmin, re-pair. Hopefully I'll start getting more than a couple of days before it screws up again...
Edge 510 owners - impressions & gripes
Re: Edge 510 owners - impressions & gripes
Postby R12RT » Fri Oct 24, 2014 2:49 pm
2010 Malvern Star Oppy C6
2014 Giant Propel Advanced 1
Postby lobstermash » Mon Nov 24, 2014 8:28 am
Postby boss » Mon Nov 24, 2014 1:17 pm
Postby Jesmol » Wed Nov 26, 2014 2:40 pm
Postby boss » Wed Nov 26, 2014 3:29 pm
Postby Jesmol » Wed Nov 26, 2014 3:44 pm
Teh altimeter doesn't seem to well calibrated between units, rode with another guy on sunday, he did 7 km more than me (ride too meet up point, no real climbs), yet did nearly 500m more climbing.boss wrote:I did quite a bit of riding in winter in the rain and got my 510 wet, with no issue. But seemingly over the last few weeks there have been a few days with 'warm rain', and it sends the altimeter haywire.
- Redbull
Postby Redbull » Thu Nov 27, 2014 7:54 pm
Postby Shred11 » Sat Nov 29, 2014 8:52 am
There has been a bit of discussion about this on the Garmin forums. The altimeter has a tiny little hole in the underside of the case and towards the front. In certain conditions - especially if the 510 is tilted up from horizontal, water can enter the altimeter hole and interfere with it. Wind - eg during a fast descent can also cause some weird readings. Fitting the Garmin silicone case seems to improve matters, since it shields the opening from the elements.boss wrote:I did quite a bit of riding in winter in the rain and got my 510 wet, with no issue. But seemingly over the last few weeks there have been a few days with 'warm rain', and it sends the altimeter haywire.
Postby Dr_Mutley » Sat Nov 29, 2014 12:32 pm
This may be true to some extent but it seems more algorithm based than design based. The 500 had similar altimeter issues early on and then worked flawless after several firmware revisions... My 510 also has wild altimeter fluctuations, while housed in a silicone case, on my extension mount.... Strangely the 500 when mounted in the same position without a case doesn't suffer from any altimeter woes...Shred11 wrote:There has been a bit of discussion about this on the Garmin forums. The altimeter has a tiny little hole in the underside of the case and towards the front. In certain conditions - especially if the 510 is tilted up from horizontal, water can enter the altimeter hole and interfere with it. Wind - eg during a fast descent can also cause some weird readings. Fitting the Garmin silicone case seems to improve matters, since it shields the opening from the elements.boss wrote:I did quite a bit of riding in winter in the rain and got my 510 wet, with no issue. But seemingly over the last few weeks there have been a few days with 'warm rain', and it sends the altimeter haywire.
Hopefully the fix the software issues soon...
Postby lobstermash » Thu Dec 04, 2014 11:07 am
I'm guessing that the firmware's corrupted or something and it'll need to be re-flashed. However, I'm wondering if that's even possible, as there's no option to do so in Garmin Express, and I'm worried about wiping the device and re-loading the firmware that way, whether that might prevent GE from recognising it... Anyone got any tips?
Postby march83 » Thu Dec 04, 2014 11:31 am
factory reset can be done by pressing all 3 hard buttons until the splash screen comes up, then releasing it.
once you've done a factory reset you can selectively restore some of the files to return your bikes, activity types and anything else that you like so long as those files aren't corrupted.
Postby lobstermash » Thu Dec 04, 2014 11:49 am
Postby Dr_Mutley » Thu Dec 04, 2014 11:51 am
Common gripe... Mine does that every few months... Frequently back up/upload your device in case this happens... Then it can be easily restored to its previous state after a hard reset/software upgradelobstermash wrote:My 510 has completely crapped itself. I turned it on this morning to try and sync bluetooth with my phone again, only to discover all my rides and training pages had disappeared. Not only that, but the units had changed to imperial... Factory reset resulted in not being able to select any settings, it won't save any training page setups, won't sync with cadence/speed/HR and didn't save my ride this morning.
Postby Dr_Mutley » Thu Dec 04, 2014 11:52 am
yeplobstermash wrote:Factory reset doesn't work. I'm pretty sure the firmware's corrupted. Is it safe to just completely wipe the device and re-install firmware? Or will Garmin Express not recognise the device?
Postby GaryJ » Fri Apr 10, 2015 2:26 am
Postby Shred11 » Fri Apr 10, 2015 7:52 am
https://forums.garmin.com/forumdisplay.php?363-Edge-510
I took a a full backup, then upgraded to 3.40 a few weeks ago. I haven't (touch wood) yet suffered any ill effects. The only positive that I've seen is that it seems to be more persistent in keeping BlueTooth connected to my iPhone. I saw the Edge 510 flash up "BlueTooth Disconnected" or something like that during my morning commute (cue dark thoughts of all the hassle I'd have getting it connected again), but by the time I arrived at work, it had associated again and was happy to upload my ride and sync with the the phone.
- 3DKiwi
Postby 3DKiwi » Fri Apr 10, 2015 2:39 pm
Yup, no problems so far. I don't use bluetooth.GaryJ wrote:Anyone using 3.4 or 3.5 firmware yet?
Postby lobstermash » Fri Apr 10, 2015 3:19 pm
