Canning Stock Route - July-August 2011
- Aushiker
Postby Aushiker » Mon Oct 31, 2011 2:34 pm
Hi
Martijn Boonman (AT) Harmattan Cycling has posted on his ride of the Canning Stock Route, which he completed in July - August, 2011 in 31 days unsupported. Further details at his website. He rode his Surly Pugsley pulling a modified BOB trailer (sort of Extrawheel).
Aushiker.com
- CommuRider
Re: Canning Stock Route - July-August 2011
Postby CommuRider » Mon Oct 31, 2011 3:16 pm
Tourism Australia should take a look at CSR bike vets - want to go somewhere extreme? Here's a route for you that traverses through a couple of deserts.
Postby saronmcm1 » Mon Oct 31, 2011 3:43 pm
Do you think that you could use a 26 inch fat wheel in a bob ibex trailer with mods?
Saron
- il padrone
Postby il padrone » Mon Oct 31, 2011 8:01 pm
It would produce a trailer with a tilted cargo bed, unless you make quite significant changes to the back end to raise the height of the axle slots. The Extrawheel has other handling advantages any way that make it superior to the BOB.saronmcm1 wrote:Do you think that you could use a 26 inch fat wheel in a bob ibex trailer with mods?
- RonK
Postby RonK » Mon Oct 31, 2011 10:24 pm
I can't see that heavy-duty Extrawheel on their site. I'm sure it was there before. Maybe they don't make it anymore.il padrone wrote:The Extrawheel has other handling advantages any way that make it superior to the BOB.
Ah, I found it - it's amongst the fastening fork options in the shop. Hmmm, no, that just for towing with a Pugsley. Where is the fat tyre trailer?
- Wingnut
Postby Wingnut » Mon Oct 31, 2011 11:22 pm
I guess it all depends on what you want to carry? The Extrawheel maybe easier to tow but two pannier bags vs a trailer that can carry a 90ltr bag plus more strapped on top...il padrone wrote:It would produce a trailer with a tilted cargo bed, unless you make quite significant changes to the back end to raise the height of the axle slots. The Extrawheel has other handling advantages any way that make it superior to the BOB.saronmcm1 wrote:Do you think that you could use a 26 inch fat wheel in a bob ibex trailer with mods?
Sent from my iPhone using Tapatalk...
- RonK
Postby RonK » Mon Oct 31, 2011 11:31 pm
Jakub Postrzygacz found the Extrawheel approriate for his 2005 crossing on the Canning Stock Route.Wingnut wrote:The Extrawheel maybe easier to tow but two pannier bags vs a trailer that can carry a 90ltr bag plus more strapped on top...
- il padrone
Postby il padrone » Mon Oct 31, 2011 11:44 pm
Yes the Extrawheel only carries two panniers (~40L). However I always use it with other bags. My bike will carry 110L in front and rear panniers, rack-top drybag and a handlebar bag - stable and smooth handling on roads rough and smooth. Using the Extrawheel I can add another 40L to this (I did this on the Oodnadatta Track).Wingnut wrote:I guess it all depends on what you want to carry? The Extrawheel maybe easier to tow but two pannier bags vs a trailer that can carry a 90ltr bag plus more strapped on top...il padrone wrote:It would produce a trailer with a tilted cargo bed, unless you make quite significant changes to the back end to raise the height of the axle slots. The Extrawheel has other handling advantages any way that make it superior to the BOB.
The one time I tried to load up the BOB for a big tour (using trailerbag with rucksack on top plus handlebar bag and rackbag) it was so destabilising to the bike that I made last minute changes to the luggage arrangements - to the above set-up of four panniers...... and found I now had one front pannier empty . The BOB, even on a loaded bike (where it is overall a bit more stable in handling and braking), is a cow of a thing to manouvre at slow speed or when walking. It readily jacknifes on you (into the 'park-stand' position) and is very difficult to straighten up. In contrast the Extrawheel is no trouble. The long tow-arm length and the weight placement is the source of this problem - Extrawheel has all weight over the wheel, rather than on the pivot.
These guys have moved from using BOBs to using Extrawheels
- Wingnut
Postby Wingnut » Tue Nov 01, 2011 1:00 pm
Maybe I'll look into one in the future...
- il padrone
Postby il padrone » Tue Nov 01, 2011 1:40 pm
Wingnut wrote:I like the look of the Extrawheel but the deal-breaker for me was the inability to be able to carry my surfboard or massage table.
Then it sounds like you really need the Xtracycle with Longloader
This has happened to me on some occasions - surprisingly only on good sealed roads. It is more to do with harmonics setting up a rythm, at certain speeds only, where there is a bit of a ripple in the tarmac. It never became any hazard, and I solved it quite easily by packing lighter, bulky things in the Extracycle and putting the heavy items in the bike's panniers. On gravel roads it did not occur.Wingnut wrote:the flexibility of the frame which can be quite a bit when carrying a significant load.
- Wingnut
Postby Wingnut » Tue Nov 01, 2011 1:48 pm
Postby Uncle Just » Sat Nov 05, 2011 12:49 pm
- Wingnut
Postby Wingnut » Sat Nov 05, 2011 3:07 pm
Canning wasn't really a nice bloke...Uncle Just wrote:Opinion piece in today's Age challenging some history of the CSR...http://www.theage.com.au/opinion/societ ... 1mzvw.html
- il padrone
Postby il padrone » Sat Nov 05, 2011 3:18 pm
In the standards of the day he was probably a "jolly nice chap"Wingnut wrote:Canning wasn't really a nice bloke...Uncle Just wrote:Opinion piece in today's Age challenging some history of the CSR...http://www.theage.com.au/opinion/societ ... 1mzvw.html
- Wingnut
Postby Wingnut » Sat Nov 05, 2011 3:35 pm
- il padrone
Postby il padrone » Sat Nov 05, 2011 4:30 pm
Canning's use of Aboriginal guides came under scrutiny after the survey was completed. The expedition's cook, Edward Blake, objected to the practice of chaining guides and claimed that Aboriginal people were cruelly treated. He criticised the survey party's 'immoral' pursuit of Aboriginal women, the theft and 'unfair' trade of Aboriginal property and the destruction of native waters. These complaints led in 1908 to a royal commission into the 'Treatment of Natives by the Canning Exploration Party'.
During the hearings, however, it was Blake's word against the team's, and he was unable to prove many of his claims. Despite condemning the use of chains, the royal commission cleared Canning and his men of all charges and approved immediate commencement of the stock route's construction.
- elStado
Postby elStado » Sat Jun 23, 2012 10:12 pm
I've looked into this option as I'd like to be able to take the train down the coast and then cycle the remaining 7-15km to a surf beach out of the city instead of having to wait around for a bus.il padrone wrote:Wingnut wrote:I like the look of the Extrawheel but the deal-breaker for me was the inability to be able to carry my surfboard or massage table.
I found it interesting though that all of the cycle touring surfers have all used trailers and not these longer bikes. Is it ignorance of other options, or had they done their research and found the trailer options to be a better choice for touring with large, long items like a surfboard?
Postby saronmcm1 » Sun Aug 19, 2012 2:12 pm
Postby Canning Walker » Sat Sep 27, 2014 9:15 pm
- Aushiker
Postby Aushiker » Thu Jan 22, 2015 1:41 am
Aushiker.com
- Wingnut
Postby Wingnut » Thu Jan 29, 2015 9:37 pm
Custom Fat bike by Bilenky Cycle Works...surfboard on the back...elStado wrote:I've looked into this option as I'd like to be able to take the train down the coast and then cycle the remaining 7-15km to a surf beach out of the city instead of having to wait around for a bus.il padrone wrote:Wingnut wrote:I like the look of the Extrawheel but the deal-breaker for me was the inability to be able to carry my surfboard or massage table.
- rifraf
Postby rifraf » Fri Jan 30, 2015 12:35 am
Assuming surfing hasn't changed too much since I was a teenager in that often the formula was big swell with off-shore wind if memory serves.elStado wrote:
The wind aspect I imagine would have a potential negative impact on a board layed on its side across-ways making the combo somewhat less than aerodynamic.
A decent cross gust could be catastrophic on an extra long bike
When I thought about this post I was thinking of the surfboard being on the side in place of two panniers and not on top as per Wingnuts pic of the fatback
I wonder even with just the four rearward panniers what the bike would handle like in gusty side winds.
Saying that, Landscapecadmonkey's Big Dummy that was in the for sale forum threads was awfully tempting.
I'm thankful it was in Queensland and thus too far to contemplate.
viewtopic.php?f=25&t=81669&p=1216972&hi ... y#p1216972" onclick="window.open(this.href);return false;
