S5 rear light
warthog1
S5 rear light
Postby warthog1 » Thu Jan 09, 2014 5:33 pm
Decided to try a moon comet from Cell bikes as I've never been happy with the fizik clip light I've been using. I can't use the fizik light with a saddle bag attached anyway.
The light is pretty bright and seems user friendly, pretty happy at this stage. :)
softy
Re: S5 rear light
Postby softy » Sat Jan 25, 2014 3:56 pm
Love my lights,
But the S5 is not light mount friendly, mount my lights on the saddle bag, backpack and helent. Yes three light facing rear!
Motorist apear to be bicycle blind, hopefully multiple flashing lights may catch their eye and make a difference.
Ray1684
Re: S5 rear light
Postby Ray1684 » Mon Apr 14, 2014 5:21 pm
Have you tried the Numen Aero Rear Light which was designed for Giant? they fit well on the aero seatpost/frames.
I have one on my Propel SL, and don't believe there are any brandings on the light itself so it should look great on the S5.
Dr_Mutley
Re: S5 rear light
Postby Dr_Mutley » Mon Apr 14, 2014 5:30 pm
Ray1684 wrote:Have you tried the Numen Aero Rear Light which was designed for Giant? they fit well on the aero seatpost/frames.
I bought one of these just to check it out... Mounts well but I wouldn't use it as a main light... Way too dull to put my life in its hands... Although I home brewed up a secure mount for around the aero seatpost, I know just just a helmet mounted light as my primary light. After trialing the RedZone 8 I don't need anything else except a backup in my pocket in case of failures...
warthog1
Re: S5 rear light
Postby warthog1 » Tue Jul 22, 2014 4:53 pm
Serfas utl-6 now. Similar brightness to the moon comet, longer run time and hangs on better.
Dr_Mutley
Re: S5 rear light
Postby Dr_Mutley » Sat Mar 07, 2015 1:40 am
Just a heads up... Racewaredirect is about to release 3D printed light mounts for the Cervelo aero seatpost... Long overdue that someone would make an elegant, reliable , mount...
warthog1
Re: S5 rear light
Postby warthog1 » Mon Mar 09, 2015 1:32 pm
Dr_Mutley wrote:Just a heads up... Racewaredirect is about to release 3D printed light mounts for the Cervelo aero seatpost... Long overdue that someone would make an elegant, reliable , mount...
Nice. 8) thanks :)
queequeg
Re: S5 rear light
Postby queequeg » Sat Apr 25, 2015 12:26 pm
Any more details on this? I couldn't find anything on their site.
Dr_Mutley
S5 rear light
Postby Dr_Mutley » Sat Apr 25, 2015 12:31 pm
Email martyn [emoji106] or ask him on IG
queequeg
Re: S5 rear light
Postby queequeg » Sat Apr 25, 2015 12:34 pm
Cheers, will do that. Also found a Garmin VIRB mount for the S5 Post. although I have a saddle rail mount for that already. No saddle bag going on the S5 :-)
Dr_Mutley
Re: S5 rear light
Postby Dr_Mutley » Sat Apr 25, 2015 1:55 pm
WheresWaldo is a Cervelo fella and will 3D print most custom things u want (I think)... U will find him on WW and the cervelo forums...
Dr_Mutley
Re: S5 rear light
Postby Dr_Mutley » Sat Apr 25, 2015 1:56 pm
http://weightweenies.starbike.com/forum ... 6#p1133411" onclick="window.open(this.href);return false;
queequeg
Re: S5 rear light
Postby queequeg » Mon Apr 27, 2015 12:42 pm
Been looking at this over the weekend, and think I found my solution, which is rather elegant and does not involve 3D printing or permanent attachment of anything to the post
https://sugru.com/guides/mount-a-see-se ... bike-frame
Doesn't need to be that particular light - just any light with a silicone strap system, with the Sugru providing the perfect mould that stays bonded to the light.
kb
Re: S5 rear light
Postby kb » Tue Apr 28, 2015 7:00 am
Cool. Step 8 sounds a bit wrong out of context :-)
queequeg
Re: S5 rear light
Postby queequeg » Thu Apr 30, 2015 11:42 pm
I tried the Moon Comet but found the saddle rail on my S5 is too wide for the bracket due to the saddle position. The saddle mount on top of the post prevents the bracket from moving back far enough.
So, the comet will go on the commuter bike.
I got a Moon LX-70 as an alternate and it comes with rubber pads to fit aero posts. did a quick test and it looks like an almost perfect match. Will post up some pics as soon as I have put the aero pad onto the light (you need to unscrew the default pad and swap it over with one of the two others). If the fit is a bit wobbly, I will get some Sugru to make it a perfect fit.
queequeg
Re: S5 rear light
Postby queequeg » Sat May 02, 2015 6:33 pm
Pretty nice fit with the LX70 light. No extra mucking about required.
