Raleigh Twenty
barefoot
Raleigh Twenty
Postby barefoot » Mon Jul 14, 2008 11:23 am
I'm about the enter the exciting world of retro biking, having won myself a BSA - Raleigh Twenty!
Not sure what year it is - they were built from the mid 60s to the mid 70s. The serial number might hold some clues.
I just have to get it home, strip it down, blast it, powder coat it, then start building it up into something awesome.
I'm thinking of modernising it somewhat, and turning it from its current cruiser setup into a more practical commuter and city bike. A little along the lines of this Twenty of Sheldon's:
mixed with a little of this one:
... and maybe a bit of this one thrown in for good measure:
Mine isn't a folder like these three are. They were made both ways, originally only in rigid form, but later with the hinge as an option. I don't need a bike to fold, so I'm happy to save the weight and flex.
Management is less than pleased with me buying (yet) another bike, but she'll get over it...
tim
toff
Postby toff » Thu Jul 24, 2008 3:22 pm
Well done barefoot. I have a Twenty that I've built up using Sheldon's as a template. I went with cowhorn bars. I'm using an old Shimano 600 rear derailleur and a 5-sprocket freewheel on Suntour Superbe Pro hubs for now, but I intend to go with the 8-speed SA hub Sheldon chose. I'm also getting a second wheel made so I can ride it fixed.
You will have lots of obstacles to overcome, especially the proprietry threading of the headset and bottom bracket, but that's half the fun...
Choosing wheel size will also be a challenge: Yours looks like it has 451 size wheels, but I chose 406 like your last pic because I wanted to install front shocks.
I installed mountain bike size front shocks on mine too, and went with a threaded headset, so I solved that problem, but the cranks were the biggest challenge. In the end, I shaved down the bottom bracket so that a standard 26 TPI bottom bracket would fit, installed a mountain bike bottom bracket and BMX cranks with no front derailleur.
I've also mounted a weeride on the front of mine, and I take my 13 month daughter for rides. She loves it! We turn heads whenever we ride it.
531db
Postby 531db » Thu Jul 24, 2008 3:52 pm
toff wrote:Well done barefoot. I have a Twenty that I've built up using Sheldon's as a template. I went with cowhorn bars. I'm using an old Shimano 600 rear derailleur and a 5-sprocket freewheel on Suntour Superbe Pro hubs for now, but I intend to go with the 8-speed SA hub Sheldon chose. I'm also getting a second wheel made so I can ride it fixed.
Pics of the "Toff Twenty"?
toff
Postby toff » Fri Jul 25, 2008 7:43 am
They exist but I haven't taken them. Will take some this weekend...
bridgethegap71
Postby bridgethegap71 » Fri Jul 25, 2008 11:11 am
Yes I have one or two of these lying around - will have to get them out of the pile. . . .
kukamunga
Postby kukamunga » Tue Sep 09, 2008 8:53 pm
Just discovered this thread. The following beauty is going up on auction on eBay from this Thursday night, if anyone's interested.....
It's a wee ripper !!
kukamunga
Postby kukamunga » Fri Sep 12, 2008 9:33 am
BSA 20 (Raleigh 20) 'Shopper' HERE!
kukamunga
Postby kukamunga » Sat Sep 20, 2008 9:07 am
Another BSA Twenty Shopper on eBay here
kukamunga
Postby kukamunga » Sun Sep 21, 2008 9:09 pm
Don't forget this is finishing in half an hour.....
MountGower
Postby MountGower » Sun Sep 21, 2008 9:47 pm
Here I was feeling guilty about steeling this thing off you and then.... bam. Good to see you got a reasonable price. Sad to see it go no doubt. Although, I suppose you'll just whip out one of your other ones and start buffing it.
kukamunga
Postby kukamunga » Sun Sep 21, 2008 9:53 pm
I was hoping to get minimum $300, and I got just that..... just!
kukamunga
Postby kukamunga » Tue Oct 07, 2008 11:21 pm
Is this based on a Raleigh 20?
kukamunga
Postby kukamunga » Tue Oct 07, 2008 11:33 pm
Some interesting Raleighs here
kukamunga
Postby kukamunga » Mon Oct 27, 2008 10:02 pm
Wonder how this BSA Twenty will go?
Kid_Carbine
Postby Kid_Carbine » Mon Oct 27, 2008 11:11 pm
A problem with anything that has the Raleigh name attached is their unique threading for headsets & bottom brackets.
Sourcing standard replacements in the UK shouldn't be too much of a problem, but in Australia, well I haven't found a bike shop that stocks them yet.
Sheldon refers to this problem in the build up of his Twenty & explains in detail how he got around these problems. A good read of his story would be highly recomended because if anyone thinks that a replacement bottom bracket for their new Shimano Mega Ace crankset is going to fit, ............... it won't.
kukamunga
Postby kukamunga » Tue Oct 28, 2008 8:34 am
Some people like 'problem' bikes. Me? I just like passing on problem bikes (now, where did I put those two Peugeots, the Motobecane, and the Gitane?) :wink:
super_simian
Postby super_simian » Wed Nov 12, 2008 12:52 am
I did read online somewhere that an FAG (no joke) plastic 24tpi sealed bottom bracket will work with the 26tpi threading on these. I'm doing a bit of research because after our trip to Japan, my sister has decided that a tricked out city type bike is for her, and I just happen to have a metallic brown non-folding Twenty out the back....
kukamunga
Postby kukamunga » Tue Feb 24, 2009 10:44 am
Just refreshing this thread
Check out these two mint condition Raleigh Twentys on eBay ! :shock:
toff
Postby toff » Tue Feb 24, 2009 2:23 pm
I like the colour of this one better. Those other 2 are 16-inch wheel Stowaways whereas the BSA is a genuine whitelabeled Twenty.
kukamunga
Postby kukamunga » Tue Feb 24, 2009 2:30 pm
toff wrote:Those other 2 are 16-inch wheel Stowaways whereas the BSA is a genuine whitelabeled Twenty.
My oops ! :oops: I should've known and read better. I've got an incomplete Stowaway on eBay ATM ! And a Raleigh 20 in the shed..... :?
twowheels
Postby twowheels » Tue Feb 24, 2009 5:49 pm
toff wrote:I like the colour of this one better. Those other 2 are 16-inch wheel Stowaways whereas the BSA is a genuine whitelabeled Twenty.
The Stowaways are actually 22" wheels, gave a burgundy one away not long back.
Resg
Postby Resg » Wed Feb 25, 2009 12:06 am
I think there's some Twenty parts on there at the moment as well...
paul
Postby paul » Wed Feb 25, 2009 9:35 pm
How do these things ride - looks like it would be scary !!
toff
Postby toff » Thu Feb 26, 2009 1:23 am
You know... It's my turn to admit my mistake. I shot my mouth off without checking my facts. Stowaways are true Raleigh Twentys. Just a variant, like the Shopper, etc. I was getting confused with the Raleigh RSW, which looked similar and had 16 inch wheels. Something about the pictures of those late model Ebay Stowaways reminded me of the 16 inch version - probably the narrowing seat tube diameter.
paul wrote:How do these things ride - looks like it would be scary !!
Twentys in original form are heavy and the brakes are a bit dodgy, but they do handle well. They have a wheelbase which is pretty long - about the same as a road bike, so that makes them stable, and the small wheels also assist stability by lowering the centre of gravity, as well as making for a highly manouverable bike. Biggest problem with the small wheels is bumps, because you feel them all. That's why I run front shocks on my mod Twenty.
paul
Postby paul » Thu Feb 26, 2009 8:43 pm
its the small wheels i would be worried about, just dont look too stable, but i guess ok if you arent going too quickly?
Users browsing this forum: Majestic-12 [Bot], micky2shoes
