Shifting fast and accurate ???Aushiker wrote:That was my first thought too. Just another electronic piece that needs charging, another piece of technology that could cause problems and maybe not be simply doubt with out on the road.Wingnut wrote:But why?
Do you really need it for touring to bikepacking?
Yesterday I was riding into Coolgardie; chain needed lubing. Easily done on the side of the road. Now if this wireless shifting died on me, maybe a seriously bigger problem. Not much help out here.
The new and interesting touring gear thread...
- il padrone
Re: The new and interesting gear thread...
Postby il padrone » Mon Oct 03, 2016 10:48 pm
- Leaf T
Postby Leaf T » Tue Oct 04, 2016 9:33 pm
https://www.aldi.com.au/en/special-buys ... 0-04_10-17
Postby }SkOrPn--7 » Tue Oct 04, 2016 10:11 pm
Wonder how heavy that is would be good for the leading edge of my EPO RC plane wings to toughen up. Little filling and sanding and they would be dent proof.Leaf T wrote:I've not seen a product like this before. Seems to be an epoxy impregnated tape? I can imagine it being quite handy for racks or tent poles.
Thanks for that LT
Ricky
- RonK
Postby RonK » Mon Oct 10, 2016 10:23 am
So I did order one and it arrived this morning.RonK wrote:I think I'll get me one of these for my Fargo - a bell that rings itself. TIMBER Mountain Bike Bell: The Polite Way to Pass
And I must say it has a very nice ring to it.
Postby avolve » Mon Oct 10, 2016 6:46 pm
Who'd you order it through?RonK wrote:So I did order one and it arrived this morning.RonK wrote:I think I'll get me one of these for my Fargo - a bell that rings itself. TIMBER Mountain Bike Bell: The Polite Way to Pass
- RonK
Postby RonK » Mon Oct 10, 2016 7:38 pm
Charlie the Bikemongeravolve wrote:Who'd you order it through?RonK wrote:So I did order one and it arrived this morning.RonK wrote:I think I'll get me one of these for my Fargo - a bell that rings itself. TIMBER Mountain Bike Bell: The Polite Way to Pass
- Leaf T
Postby Leaf T » Tue Oct 11, 2016 1:48 pm
- RonK
Postby RonK » Tue Oct 11, 2016 2:22 pm
That's less than my Spur Cycle bells.Leaf T wrote:23 quid for a bell? I'd need bats in the belfry to spend that much.
It's a unique design - you can't get one like it anywhere else (until the cheap Chinese knockoffs appear).
But I suppose you could go out the back and snatch the bell off Daisy's neck.
A nice Condamine Bullfrog will cost an arm and leg these days.
- RonK
Postby RonK » Mon Oct 17, 2016 2:28 pm
I've done a few rides now with this hell on the bike.RonK wrote:So I did order one and it arrived this morning.RonK wrote:I think I'll get me one of these for my Fargo - a bell that rings itself. TIMBER Mountain Bike Bell: The Polite Way to Pass
As expected, on the road it doesn't ring much unless I hit a bump. When it does the tone is quite pleasant and pedestrians on the footpath look as round so it is obviously noticeable.
I tested it on the chromatic scale and it rings in the key of G, compared to the Spurcycle bell which rings in A.
Postby }SkOrPn--7 » Fri Oct 21, 2016 9:26 am
http://www.kindernay.com/
Ricky
Postby ironhanglider » Fri Oct 21, 2016 10:08 pm
Seems like you don't like it much!RonK wrote:I've done a few rides now with this hell on the bike.RonK wrote:So I did order one and it arrived this morning.RonK wrote:I think I'll get me one of these for my Fargo - a bell that rings itself. TIMBER Mountain Bike Bell: The Polite Way to Pass
Cameron
- RonK
Postby RonK » Fri Oct 21, 2016 11:05 pm
Not at all. I like it a lot. It's a hell of a bell - one of the nicest I've ever owned.ironhanglider wrote:Seems like you don't like it much!
- RonK
Postby RonK » Wed Oct 26, 2016 10:01 am
Hehe - I wonder if they are trying to tell me something...
- Leaf T
Postby Leaf T » Wed Oct 26, 2016 1:19 pm
That hub looks like a serious contender for Rohloff fans. Very little weight difference though once you add it all up. I like the fact the shifters can be mounted on drop bars. And being able to remove the gear mech and use it on other bikes is a great idea. Then there's the cost which is around $2400AUS. Any idea how much a pinion system costs these days?}SkOrPn--7 wrote:New 14 speed IGH might interest someone and if it turns out to be good might inspire Rohloff to make improvements to there's.
Ricky
Postby }SkOrPn--7 » Wed Oct 26, 2016 1:53 pm
LT I know very little about it and have done very little in the way of research much past posting that link. Just reading it has a little larger GI range but in my opinion still not low enough for my use. That did spark my interest the fact that you can buy a hub shell and lace up different rim combos then just slip the hub into each new rim build and off you go that for me was real innovation allowing use across many bikes. I think they said the shifters are hydraulic now I don't know enough about that to say either way if that is good or bad I know I prefer cables on my brakes just for simplistic reasons but the newer cable hydraulic combo has my attention with brakes.Leaf T wrote:That hub looks like a serious contender for Rohloff fans. Very little weight difference though once you add it all up. I like the fact the shifters can be mounted on drop bars. And being able to remove the gear mech and use it on other bikes is a great idea. Then there's the cost which is around $2400AUS. Any idea how much a pinion system costs these days?}SkOrPn--7 wrote:New 14 speed IGH might interest someone and if it turns out to be good might inspire Rohloff to make improvements to there's.
Ricky
The pinion is around $1800 isn't it I'm assuming that is AUD but once again that system isn't something I have delved into because I think the GI isn't for me. I reckon this Kindernay hub has some real positives going for it but I would like to see some more technical data on what it can and can't do as far as limitations with sprockets and chainrings before you break it.
Ricky
- Leaf T
Postby Leaf T » Wed Oct 26, 2016 2:01 pm
"How much torque?
The hub is designed to withstand MTB use. As different riders use their equipment in different ways the load put into such systems varies considerably. XIV is designed for a nominal torque of 100Nm on the hub and a chain tension of 3000N, though the maximum peak torque capacity is significantly higher. Due to the large span of use and loading, it is impossible to give direct calculation of crank/hub sprocket ratios or minimum hub sprocket, but a good practice is to follow the indication below:
The minimum sprocket that the hub can handle is 13T, however riders expecting to use the hub up to its upper torque capacity should use larger sprockets, preferable 15T or larger to avoid overload and premature wear both on the hub and crank bearings and the drive line itself. The crank/hub sprocket ratio should be chosen in the range of 1.9 to 3.0. "
Postby Calvin27 » Fri Nov 04, 2016 3:01 pm
Solves the crosswind and front aero trade off to some extent. Seems like a cool concept to me. Some nice computational fluid dynamics images would have been the icing on the cake.
Cushy dirt bike
Very cushy dirt bike
Bike crushed by car (RIP)
No brakes bike
Ebike
- RonK
Postby RonK » Fri Nov 04, 2016 6:27 pm
Postby eldavo » Fri Nov 04, 2016 6:46 pm
I thought it was interesting, but wondered if they would be supporting Sea Shepherd or such eco charity given the bio-mimic was patent license free.
Postby Calvin27 » Fri Nov 04, 2016 6:50 pm
My bad haha.RonK wrote:Aero wheels - just the thing I DON'T need on my touring bike.
Cushy dirt bike
No brakes bike
Ebike
- Aushiker
Postby Aushiker » Fri Nov 11, 2016 9:37 am
- baabaa
Postby baabaa » Sat Nov 19, 2016 10:12 am
New Product Spotlight: Yokozuna Motoko Cable-Pull Hydraulic Disc Brake
https://www.cxmagazine.com/yokozuna-mot ... el-caliper
- il padrone
Postby il padrone » Sat Nov 19, 2016 3:21 pm
Fire-starters are available all over the shop - from $2.99 to $35 depending on your preferred supplierAushiker wrote:I use a Light My Fire mini but this looks like an interesting alternative, the Vargo Ultimate Fire Starter that is. Massdrop have a drop going with the price now at US$25.99 delivered.
- il padrone
Postby il padrone » Sat Nov 19, 2016 3:24 pm
Only available for 10mm and 12mm thru-axle systems.Leaf T wrote:That hub looks like a serious contender for Rohloff fans. Very little weight difference though once you add it all up. I like the fact the shifters can be mounted on drop bars. And being able to remove the gear mech and use it on other bikes is a great idea. Then there's the cost which is around $2400AUS. Any idea how much a pinion system costs these days?}SkOrPn--7 wrote:New 14 speed IGH might interest someone and if it turns out to be good might inspire Rohloff to make improvements to there's.
Ricky
Then there is the (*cough*) rather large price barrier
- RonK
Postby RonK » Sat Nov 19, 2016 4:40 pm
Nothing new about these - they are simply a rebranding of the Juin Tech R1 brakes I posted about here more than a year ago.baabaa wrote:Finally, no reservoir, adjustable and not self adjusting hydro; looks the goods to me as I do like to dial in my brakes in regarding to on road and off road and then if wet and muddy or just dusty or sandy (also keen on cable for the no fuss when levers are pranged and less parts to lug about)
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
