*whispers* Daaamn...jaseyjase wrote:Looking good Ant! Crank combo is killer!
My recent all weather SS commuter, i dub it my #Monsterslate
CAAD4 F700 / DLR2 speedy 110 lefty, 26x2.4 Holy Rollers, SRAM S500s to TRP Spyers. Running 44/16 with a RaceFace Deus cranks but i reckon i can go a 45, just hard to find!
Post your Fixie piccies
- Mulger bill
Re: Post your Fixie piccies
Postby Mulger bill » Fri Dec 02, 2016 9:47 pm
Postby Ant_S » Mon Dec 05, 2016 12:05 pm
- P!N20
Postby P!N20 » Tue Dec 06, 2016 3:12 pm
You could just rotate your front wheel if you were worried about it. Rear isn't quite so easy.
I doubt there would ever be a situation that hitting the deck or keeping it upright ever came down to whether your Gatorskin was mounted the right way.
- P!N20
Postby P!N20 » Thu Jan 12, 2017 10:36 am
Kona Paddywagon, purchased new in 2009. Absolute workhorse, has done +150k rides, all weather commuting, child portaging, alleycats and everything in between. Original wheelset was swapped out when the rear hub thread stripped. FSA cranks broke and replaced with Suginos. Just a few days ago put new bearings in the rear wheel and put the stock front wheel back on as the brake surface in the black front was seriously concaved. Got a new sprocket and chain to put on and need to get the knock in the headset looked at.
McBain Record 1982, purchased from Tim of Velosmith fame. Originally a Tasmanian, I always wanted a Tassie made frame, so jumped at the chance when this came up for sale. Was in a pretty sorry state when I bought it, so stripped it down and built it up with period correct parts. Managed to do all the work myself including building the wheels in order to teach myself how bikes work. I love riding this when the sun is shining, unfortunately it’s a tad small for me (54, usually ride a 56) so it probably doesn’t get out as much as it should.
- HappyHumber
Postby HappyHumber » Thu Jan 12, 2017 1:56 pm
- P!N20
Postby minhyy » Fri Jan 13, 2017 10:11 am
- P!N20
Postby P!N20 » Fri Jan 13, 2017 11:19 am
Actually, did you get this from 'delno' in Tas? It looks like one he was showing me when I was down there a few years back.
Do the holes in the fork crown limit this to dry weather only or don't you worry about it?
Postby minhyy » Fri Jan 13, 2017 12:35 pm
Yeah not quite sure about the builder, McBain was suggested but nothing conclusive. Carl Wilson was also thrown around as a suggestion. I've only ever seen one other track frame with identical drillings.P!N20 wrote:^ Frame looks a bit McBain-ish with the fork crown and track end cut outs.
I got the frame from Gypsy, who was based in Brisbane but now is in Canberra with Kumo.
I'm not concerned about water getting into the fork, I sprayed a generous coat of Inox into the fork blades and they haven't rusted despite being caught in the rain on the odd occasion.
- PeteV
Postby PeteV » Fri Feb 17, 2017 3:56 am
Postby FJ45 » Wed Dec 13, 2017 11:10 am
Specs
-Frezoni Track Frame and Forks (Columbus Foderi Laminati)
-Campagnolo Record Cranks
-Campagnolo Strata Pedals vintage
-NJS quill
-Cinelli Track Bars
-Campagnolo headset
-Stratos saddle
-Dura Ace hub with Mavic rims rear wheel
-Campagnolo Khamsin front wheel
Here is a link to some photos.
https://postimg.org/image/p17kjkxxn/
https://postimg.org/image/r5rxkqk5n/
https://postimg.org/image/ylr76jfkr/
https://postimg.org/image/nm5zuxwvf/
https://postimg.org/image/6yehsg9tn/
Postby minhyy » Mon Dec 18, 2017 10:28 pm
FJ45 wrote:This Frezoni was built in 1999 and is my reliable daily ride. It was originally a track bike, until I acquired the bike and took it to the Brisbane frame builder Joe Cosgrove himself. All I have done is installed a front brake for daily commuting to work. A great bike to ride incredibly smooth and a real conversation starter with complete strangers. I highly recommend Joe Cosgrove's craftsmanship, if you need any work done on your bike just pop in and give him the work. People like Joe are unique in the sense he has dedicated his life to his craft with not much financial return. Bespoke builders like Joe are shadowed by mass produced bicycle manufacturers, who can build more bikes for cheaper.
Specs
-NJS quill
-Cinelli Track Bars
-Campagnolo headset
-Stratos saddle
Are you riding it fixed gear with no foot retention? Or a single speed with just a front brake?
Postby minhyy » Wed Jan 24, 2018 8:52 am
Wide risers I reckon
- bychosis
Postby bychosis » Wed Jan 24, 2018 9:03 am
anodised rims for a splash of colour.
- familyguy
Postby familyguy » Sat May 12, 2018 1:32 pm
Finished for now, aside from front wheel,
Larry Custom Cycles steel frame and fork, no name sealed 1/8 headset, no name seat collar, Sugino 27.2 post, perf Turbo, Tec9 cheapo cranks, 42T(?) x 16 free/fixed, Ritchey Classic 420mm bars and 90mm stem, Campy-shape Tektro brake levers, Shimano 600 calipers, flat pedals till I figure out what SPD set I want to run. Rear wheel is BLB silver hub to EA65 rim using triple butted Pillar spokes. Just waiting for the spokes to arrive to rebuild the matching front. 103mm BB coming to let ne run the chainring on the outside of the spider.
Postby slidetaker » Mon May 14, 2018 1:07 pm
What gear ratio? Straight pull for the front wheel??
- familyguy
Postby familyguy » Mon May 14, 2018 1:50 pm
Postby Nick Bagus » Tue Aug 14, 2018 12:15 pm
- P!N20
Postby P!N20 » Tue Aug 14, 2018 1:00 pm
http://www.bicycles.net.au/forums/viewt ... =6&t=23303Nick Bagus wrote:I'd like to try and show mine but how the feck do you upload an image?
Postby Nick Bagus » Wed Aug 15, 2018 11:33 am
Thank you!P!N20 wrote:http://www.bicycles.net.au/forums/viewt ... =6&t=23303Nick Bagus wrote:I'd like to try and show mine but how the feck do you upload an image?
So here's my Bianchi Pista! Since owning I've removed the track drops and bought some second-hand Cinelli Pepper bars with Cinelli Pista stem due to my fairly relaxed ride into work. Absolutely love it, weighs about 7kg.
- P!N20
Postby P!N20 » Wed Aug 15, 2018 11:44 am
Postby Nick Bagus » Wed Aug 15, 2018 12:46 pm
Since taking that photo I fitted a Tektro lever for the front over the weekend to the existing caliper i had lying around. Very happy with how it feels!P!N20 wrote:^ Cool. If you are riding fixed brakeless, I strongly recommend you get some foot retention - be it straps or cleats.
Postby markoarb » Wed Oct 10, 2018 2:18 pm
Specs:
Cell Messenger frame (need to upgrade shortly, waiting on a certain colour way to come back in to stock from Constantine Bikes)
Front aerospoke
Surly rear wheel
Sugino 75 crank set
Colossi riser bars
Fyxation pedals & straps
Headset from my old Felt TK2
San marco pro race saddle
- singlespeedscott
Postby singlespeedscott » Wed Oct 10, 2018 4:08 pm
Return to “Fixed Gear/ Single Speed”
