Cycling related signs - good/bad/ugly
- find_bruce
- Moderator
Re: Cycling related signs - good/bad/ugly
Postby find_bruce » Mon Jan 30, 2017 2:05 pm
- Ross
- Alex Simmons/RST
Postby Alex Simmons/RST » Tue Jan 31, 2017 9:35 am
I've always taken them to just be an alert to cyclists that the road or path conditions ahead may mean it's a safer option for the cyclist to walk over them than attempt to ride over them. e.g. if there is a lot of loose gravel/rocks, or holes in the surface where the works are taking place. Now for some these probably don't represent all that much of a risk to stay on your bike, but for others they may well prefer to dismount. Each can make their own judgement.wellington_street wrote:and walking a bike through there! How does that pass risk assessment?mikesbytes wrote:It defeats me how a bicycle can be more dangerous to the workers than a car traveling at 40kphLukeyboy wrote:
Lucky those 'Cyclist Dismount' signs are guide signs only, not regulatory.
I don't think "cyclists dismount" is about road worker safety, where as the speed limit is much more a factor for both road user and road worker safety in road works zones.
- bychosis
Postby bychosis » Tue Jan 31, 2017 2:29 pm
I suspect it is put there to keep bikes from 'holding up' the other traffic. If it is a portable traffic light setup there might not be enough time on the phasing to allow a bicycle to pass through at 20km/h before the oncoming traffic is set free.Alex Simmons/RST wrote:I don't think "cyclists dismount" is about road worker safety, where as the speed limit is much more a factor for both road user and road worker safety in road works zones.
- Ross
- Mustang
Postby Mustang » Sun Feb 19, 2017 10:24 am
This one at Forth a popular climb in the area.
This one 15km from Deloraine on the Lakes road.
70 years young.
- find_bruce
- Moderator
Postby find_bruce » Mon Mar 06, 2017 7:06 am
Reported to be Gornergrat, Switzerland. IIRC the red circle means "no"
Postby fat and old » Mon Mar 06, 2017 7:22 am
That's spot on for why they're recommended when we do a job. If the cyclist wants to ride, so be it. He/she was fairly warned, and can then use their own judgement.Alex Simmons/RST wrote:I've always taken them to just be an alert to cyclists that the road or path conditions ahead may mean it's a safer option for the cyclist to walk over them than attempt to ride over them. e.g. if there is a lot of loose gravel/rocks, or holes in the surface where the works are taking place. Now for some these probably don't represent all that much of a risk to stay on your bike, but for others they may well prefer to dismount. Each can make their own judgement.wellington_street wrote:and walking a bike through there! How does that pass risk assessment?mikesbytes wrote: It defeats me how a bicycle can be more dangerous to the workers than a car traveling at 40kph
- mikesbytes
Postby mikesbytes » Mon Mar 06, 2017 8:27 am
Perhaps there's a better communication to communicate caution to the cyclistsfat and old wrote:That's spot on for why they're recommended when we do a job. If the cyclist wants to ride, so be it. He/she was fairly warned, and can then use their own judgement.Alex Simmons/RST wrote:I've always taken them to just be an alert to cyclists that the road or path conditions ahead may mean it's a safer option for the cyclist to walk over them than attempt to ride over them. e.g. if there is a lot of loose gravel/rocks, or holes in the surface where the works are taking place. Now for some these probably don't represent all that much of a risk to stay on your bike, but for others they may well prefer to dismount. Each can make their own judgement.wellington_street wrote: and walking a bike through there! How does that pass risk assessment?
- bychosis
Postby bychosis » Mon Mar 06, 2017 8:35 am
Are you sure it isn't so all the road workers can point at the fallen cyclist and laugh?fat and old wrote:That's spot on for why they're recommended when we do a job. If the cyclist wants to ride, so be it. He/she was fairly warned, and can then use their own judgement.
Postby Scott_C » Mon Mar 06, 2017 9:23 pm
Recommended in what? As far as I know they aren't found as a stand alone sign in the current revision of AS1742.3. Do any of the state based road authorities still have a yellow 'cyclists dismount' sign in their traffic control manual?fat and old wrote:That's spot on for why they're recommended when we do a job. If the cyclist wants to ride, so be it. He/she was fairly warned, and can then use their own judgement.
I would have thought if the sign is there to warn cyclists of a hazard it would be more appropriate to use a 'Cyclist' panel and a yellow description of the hazard like 'uneven surface' or 'loose stones' or 'water on road' in a multi-message sign, the same way as you would if you had a hazard specific to heavy vehicles or high vehicles.
- StevOz
- Ross
- Ross
- Ross
Postby Ross » Thu Mar 16, 2017 5:22 pm
- find_bruce
- Moderator
Postby find_bruce » Fri Mar 17, 2017 5:04 am
Its judt the position of the sign that needs changing - slap it on the front windowRoss wrote:A lot of ironry here as ACTION bus drivers are one of the worst offenders at close shaving cyclists.
- Ross
Postby fat and old » Fri Mar 17, 2017 11:28 am
Recommended by the fellas/girls who write up these TMP's. By our insurance companies. By worksafe (in my case, via an on site visit).Scott_C wrote:Recommended in what? As far as I know they aren't found as a stand alone sign in the current revision of AS1742.3. Do any of the state based road authorities still have a yellow 'cyclists dismount' sign in their traffic control manual?fat and old wrote:That's spot on for why they're recommended when we do a job. If the cyclist wants to ride, so be it. He/she was fairly warned, and can then use their own judgement.
You have a point re the multi-message signs, although that is already covered on compliant sites. If I put up a standard 3 panel sign here....red working man, 40kmh limit, roadwork ahead then that applies to all, doesn't it? Cycles are road users and subject to the same road rules/understanding of such as other users? If a hazard sign is put out as you describe, why do cycles have to be specifically targeted? As you referenced AS1742.3, where is the specific reference to dealing with cycles as a seperate entity? TBH, I can't think of something that would affect a cyclist and not a car in the way you describe the high/wide vehicles, except maybe the profiling signs. If on the other hand you want to point at general road conditions that allow a 4wd to use the road but are unsuitable for high speed cycling then that's a different matter to what I'm referring to. Given that many cyclists actively seek out unsealed roads these days I don't really see the difference in road quality....although we do have to cater to the lowest denominator.
I can only speak for myself (and looking at the shite all over Melb would not speak for any T/C company at all)....we do all we can top pre-warn, guide and manage traffic through our sites. There is always someone who doesn't GAF, and those are the ones that the bulk of signs are erected for. Working on the M1 with a 60k limit at 2.00am and the bulk of cars go past at 90+. Close a lane on Swanston St, and the majority of "road cyclists" will try to ride straight through my worksite.
I am always interested in suggestions on how to better convey roadworks to all users, especially cyclists. I have no issue with whether or not a sign is "recommended" or "compliant" if they do the job. I have a job coming up shortly that will be a real test of T/M of cyclists and peds. It will be interesting to note what occurs.
- antigee
- Location: just off the Yarra Trail but not lurking in the bushes
Postby antigee » Fri Mar 17, 2017 1:59 pm
"Narrow Lanes Drivers DO NOT Pass Cyclists"
"CAUTION Cyclists have priority"
http://road.cc/content/news/130401-cycl ... ange-signs
edit and in the city I used to live in the cycling forum failed to get the council to adopt the London guidelines - here is draft version (might be a final version somewhere)
https://consultations.tfl.gov.uk/cyclin ... dworks.pdf
- Ross
Postby human909 » Sun Mar 19, 2017 8:39 pm
Exactly what I was going to say. "Cyclists dismount" isn't a warning at all. It is a direction and one that is over used and thus ignored. It doesn't describe the hazard and is entirely useless "safety" measure.fat and old wrote:Scott_C wrote:Recommended in what? As far as I know they aren't found as a stand alone sign in the current revision of AS1742.3. Do any of the state based road authorities still have a yellow 'cyclists dismount' sign in their traffic control manual?fat and old wrote:That's spot on for why they're recommended when we do a job. If the cyclist wants to ride, so be it. He/she was fairly warned, and can then use their own judgement.
Who know very little about providing for cyclist's safety. (And arguable quite incompetent at dealing with safety in general.)fat and old wrote:Recommended by the fellas/girls who write up these TMP's. By our insurance companies. By worksafe (in my case, via an on site visit).
Shouldn't that question get asked about cyclists dismount signs?fat and old wrote: If a hazard sign is put out as you describe, why do cycles have to be specifically targeted?
Which, when it comes to cyclists, is done poorly more times than it is done well in my experience. And when the safety issue is brought to workers attention expletives often follow. (In my experience.)fat and old wrote:I can only speak for myself (and looking at the shite all over Melb would not speak for any T/C company at all)....we do all we can top pre-warn, guide and manage traffic through our sites.
The job needs to be done. But it must be said that in general catering for the needs of cycling safety in Australia exceedingly poor and this extends to 'OH&S' too.
Postby human909 » Sun Mar 19, 2017 8:45 pm
antigee wrote:this article from the UK has a couple of interesting examples if not already seen it
The only problem is that if I saw that in Australia I'd probably fall off my bike in shock.
Postby wellington_street » Mon Mar 20, 2017 6:53 pm
If this is the case, then why are the people you quoted above recommending installing 'Cyclists Dismount' signs?fat and old wrote:Recommended by the fellas/girls who write up these TMP's. By our insurance companies. By worksafe (in my case, via an on site visit).Scott_C wrote:Recommended in what? As far as I know they aren't found as a stand alone sign in the current revision of AS1742.3. Do any of the state based road authorities still have a yellow 'cyclists dismount' sign in their traffic control manual?fat and old wrote:That's spot on for why they're recommended when we do a job. If the cyclist wants to ride, so be it. He/she was fairly warned, and can then use their own judgement.
- Ross
Postby fat and old » Mon Apr 10, 2017 7:30 pm
Short answer, they're ignorant and the prime objective on all sites as with everywhere is cover your ass.wellington_street wrote:If this is the case, then why are the people you quoted above recommending installing 'Cyclists Dismount' signs?fat and old wrote:Recommended by the fellas/girls who write up these TMP's. By our insurance companies. By worksafe (in my case, via an on site visit).Scott_C wrote:
An update on this
There's a job being done for VicRoads not far from here. They are using a cyclists dismount sign; in my opinion totally unnecessary and only there to save the contractor from keeping the cycle lane clear and safe after hours (during works they do need to close the cycle lane). So the cycle lane is closed at all hours now. Turned out that I was required for something on this job. So I contacted the V/R engineer supervising the works, and during the conversation bought up the signage and lane closure. Turns out that she doesn't understand why it's used....in fact she didn't realise that as legal road users we have the right to merge with the traffic and also that it's illegal for us to use the footpath. I opened up a great big can of worms actually by also pointing out the defeciencies in V/R's accreditation of Traffic Management companies if those companies don't know the legal status of all road users. It was quite fun actually. I have a meeting tomorrow so should have a bit more fun
