Gravel Bike Recommendations
Postby lewie15 » Fri Feb 09, 2018 4:44 pm
http://www.99bikes.com.au/bike18-norco- ... rival-grey
http://www.99bikes.com.au/bike18-norco- ... c-ult-blue
https://www.specialized.com/au/en_AU/me ... 510-129079
https://www.specialized.com/au/en_AU/me ... 508-128909
- RonK
Re: Gravel Bike Recommendations
Postby RonK » Fri Feb 09, 2018 5:04 pm
99 Bikes is also expecting the Merida Silex 6000 to arrive in March. It also has a carbon frame with Sram Apex 1x11, and $2999 RRP.
Having become accustomed to the high fronted comfort of my Salsa Fargo I prefer the geometry this bike, but I'm mostly attracted to its low weight which should make it a very capable all rounder.
From BikeRumour: Merida Silex goes all road with new gravel road bike in carbon or alloy
"Tire clearance is a big part of the versatility of the Silex. It officially fits a 42mm wide 700c tire or 50mm wide in 650b. Take that to 700c x 35mm with full coverage fenders. Those might be conservative numbers though, as Merida says they have fit 2.25″ Schwalbe Thunder Burts on the bike, and even 47mm WTB Horizons with fenders."
Here is a review by offroad.cc on the Silex 9000 (which won't be offered here). SILEX 9000 TESTED BY OFFROAD.CC
Postby lewie15 » Fri Feb 09, 2018 5:11 pm
- RonK
Postby RonK » Fri Feb 09, 2018 5:24 pm
Well only you know where you will ride. If you are dead certain to stick to gravel roads and fire trails, 35 mm is probably wide enough, but my experience is that once you go off the sealed road, more and more adventurous trails beckon, so you could have regrets.lewie15 wrote:http://www.99bikes.com.au/bike18-norco- ... -ult-slate Thanks for the reply Ron. Looks like the model you have mentioned has already arrived. Unfortunately it's a bit out of my price range. I'm still tempted to go with the Ultegra Search in my original post, unless someone can convince me that I need bigger tyres than 35c for the type of riding that I want to do.
I have ridden my touring bike over gravel on 32 mm tyres and it took a lot of concentration to avoid the front washing out on the loose stuff.
I have used both 42mm and 2.1" tyres on my Fargo. I've concluded the 2.1" tyres were overkill for the routes I have ridden and that a 42-44mm tyre would give a good balance of rolling resistance, ride comfort and grip.
- baabaa
Postby baabaa » Fri Feb 09, 2018 5:47 pm
But if I start packing the bike up with frame bags they do get a bit flighty so I then for a minimal tread continental touring, (contacts 2 maybe? ) at 37mm which fit much the same as a normal 35.
So width is such a hard thing to call unless you really ping down a type of tread and casing you like.... see guitar teds pages and his forums http://ridinggravel.com/forum/?p=%3F
I don't really see the need to go wider than 37mm but I am 75/ 78 kgs and if I need to go wider than 1.9 inch I then grab a different bike.
I agree with Ron the norcos do look good at that price and if me would try and avoid any x1 up front and go a double ring with a l/h brifter so that you can try a single if you wish and just use it for braking. A new shift and brake lever would cost plenty if you do not like x1 (which I tend not to) Have fun these type of bikes do make a lot of sense, just don't worry what the frame is made of they will get rubbished by branch scratching and frame bag rub anyway.
Postby lewie15 » Fri Feb 09, 2018 6:01 pm
Alloy version - https://www.specialized.com/au/en_AU/me ... 508-128909
Carbon version - https://www.specialized.com/au/en_AU/me ... 510-129079
- RonK
Postby RonK » Fri Feb 09, 2018 7:13 pm
My Fargo has TRP Spyres and they are quite good as cable brakes go, but I would prefer hydraulic. I can see the extra value in the Diverge Comp.
So I'm thinking Silex 6000 which I think would enable me to keep up with bunch rides around the city and still get still be good on out of town back roads with a few bikepacking bags attached.
But of course I would still have the Fargo for more adventurous rides.
Postby lewie15 » Fri Feb 09, 2018 8:09 pm
https://www.bikeexchange.com.au/a/cyclo ... /103312759
- Ross
Postby Ross » Fri Feb 09, 2018 8:56 pm
I've ridden a friend's Crux with the Tektro Spyre brakes and IMO they are rubbish. My alloy rim brakes on my road bike stop heaps better - in the dry, probably different story in the wet. My CX bike has the Shimano hydraulic discs which are noticeably better than both other brakes, so my advice would be to get them. Should be able to retro-fit hydraulic for way less than $1600 if you can do some/all of the work yourself.lewie15 wrote:Thanks Ron and Baabaa for your knowledgable advice. I think you make a good point Ron about possibly regretting not having the ability to go wider than 35c for more adventurous trails. The Diverge takes tyres up to 700x42mm, so maybe this puts it ahead over the Norco Ultegra. The two Diverge models have the same 105 components and gearing, but the more expensive version is carbon and has hydraulic disk brakes ($1600 more expensive). It doesn't seem like there is an extra $1600 of value when I look at the specs of each bike. I've heard good things about the Tektro Spyre mechanical disk brakes that come with the alloy diverge, and in the back of my mind i'm thinking an alloy frame might be a more sensible option than carbon.
If you are on a budget now maybe get the bike with the TRP brakes and upgrade them to the Shimano hydraulic later when you are more financial. You can then sell your TRP setup to help finance.
- Defy The Odds
Postby Defy The Odds » Fri Feb 09, 2018 9:27 pm
For the money they are a fantastic bit of kit. Full SRAM APEX 1x with hydraulic disc brakes.
3 bottle mounts (size medium and up), fit up to 50mm tyres and very comfortable for long rides.
Edit: $2,399 - excellent value and I prefer the 1x gearing as others either have cyclocross gearing or road gearing, this has a 42t cog which I tested up a mountain this morning
- queequeg
Postby queequeg » Fri Feb 09, 2018 9:50 pm
https://lynskeyperformance.com/2018-gr- ... l-pricing/
Postby NASHIE » Fri Feb 09, 2018 10:11 pm
Geez some big price slashing across their current range. Wonder why ?queequeg wrote:If you are quick, this will just scrape in under your budget, even with the GST:
- queequeg
Postby queequeg » Sat Feb 10, 2018 10:38 am
It’s a start of season special on a few bikes. They do this every year around this time. It’s how I got my Cooper CX back in 2011.NASHIE wrote:Geez some big price slashing across their current range. Wonder why ?queequeg wrote:If you are quick, this will just scrape in under your budget, even with the GST:
Postby owly » Sat Feb 10, 2018 10:44 am
You can always purchase a Redshift Shockstop stem if you want some more cush up front.
The Diverge range does have a shorter reach than the Giant; one may fit you better.
Ideally you'd have a ti frame with huge clearance
- baabaa
Postby baabaa » Sat Feb 10, 2018 11:56 am
Take out the vat it may make your budget
If you wish to make a bike up I would be swooping on one of these
https://www.bike24.com/1.php?content=8; ... =1000,4,34
https://www.bike24.com/1.php?content=8; ... 0,2,99,101
- singlespeedscott
Postby singlespeedscott » Sat Feb 10, 2018 12:57 pm
- RonK
Postby RonK » Sat Feb 10, 2018 1:38 pm
That is the first model Diverge. The current model takes 42mm tyres.singlespeedscott wrote:My mate, Smith Street, has a Diverge and it is very nice. However max tyre he can squeeze in is a 38mm.
- Defy The Odds
Postby Defy The Odds » Sat Feb 10, 2018 2:39 pm
Also, max tyre clearance is 42mm.... the Giant comes with 40mm tyres and though adequate, I'd prefer the option of 50mm if need be.
The stack is quite high but reach is almost identical to the Defy. If you take out the spacers and slam the stem on the Toughroad GX 0 you would have very similar geometry to the Defy with the lower bottom bracket.
If you don't want aluminium though I would strongly consider the Giant TCX SX also which is more aggressive in geo though
https://www.giant-bicycles.com/au/tcx-advanced-sx
- mogwaiboi
Postby mogwaiboi » Sat Feb 10, 2018 4:24 pm
- cyclotaur
Postby cyclotaur » Sat Feb 10, 2018 4:51 pm
I wouldn't be buying a 'gravel bike' for a Mawson Trail ride. Gravel bikes, to my mind, are basically all-road bikes, 'road' being the operative word. For 'general dirt roads' I think 35mm is fine.singlespeedscott wrote:I wouldn’t be touching any gravel bike unless it can takes 45mm. Any less on a ride like the Mawson Trail I think you will regret. My mate, Smith Street, has a Diverge and it is very nice. However max tyre he can squeeze in is a 38mm. He’s looking to do the Mawson trail and has got himself a titanium Curve GMX. running 2.1” 650B tyres. I think a a longer ride like that, especially with a rigid fork, I would be looking for some fat rubber too. For general dirt roads I think 45mm is fine.
I have a 2018 Diverge and have just put 35c Schwalbe Marathon Mondials on (it came with slick but heavy 30s) ahead of a tour in March, It's an all-road tour with a fair stretch of gravel roads involved. It makes it fairly hefty at 10.6kgs without bottles/spares/pump but with pedals. It will cope with the rougher gravel sections without imposing to much penalty on sealed roads and climbs.
The Schwalbe 35 tyres on the new Diverge wheels sit significantly wider than on the 2011 wheels they were on previously. They run well on seal and are just knobbly enough to cope with rougher gravel roads. For tours it's obviously different paced riding and you have some gear on board also, so the actual bike weight is less important than overall weight and lower gearing. The Diverge has 48/32 chainrings and comes with 11-32 cogs. It could take a 34t cassette quite easily, possibly even a 36t.
I now also have a lighter wheelset (with 25c tyres) for pure road-riding days, which drops the weight by 1.3kgs. For me, if the bike weight gets anywhere over 10kgs I really start to feel it on road rides, though the lightest bike I've ever had was still low-8 kgs, depending on wheels/tyres.
My old blog - A bit of fun
Postby lewie15 » Sat Feb 10, 2018 8:47 pm
https://www.bikebug.com/scott-addict-gr ... 78611.html
- mogwaiboi
Postby mogwaiboi » Sun Feb 11, 2018 9:31 am
Postby owly » Sun Feb 11, 2018 10:01 am
I'd have a look at the alu and the steel Reynolds 631 model. 700 or 650b depending on frame size.
Postby lewie15 » Sun Feb 11, 2018 11:27 am
Thanks for that. I've been struggling to find reviews on the Scott.owly wrote:Didn't think they were available in Aust, but they are in a few places: 2018 Jamis Renegade.
- Defy The Odds
Postby Defy The Odds » Sun Feb 11, 2018 10:54 pm
