Finally joined the clan...
- MattyK
Postby MattyK » Wed Apr 04, 2018 8:36 pm
Gumtree find Reid Harrier in ok knick. A bit of scratching and rust but most things straight.
Have commenced cleanup:
Wipe down and remove grime
Freed the stuck seatpost
Removed rear brake
Trimmed the front brake cable
Adjusted wheel bearings (too tight)
Lubed the chain and bearings
Trued the wheels back to straight
Replaced the rusty bottle cage screws with ss.
Destickered the wheels and cranks
Runs super quietly. Heavy as though, the complete wheels with tyres are over 4.1 kg...
Commuted yesterday, a good challenge up the hills
Some toe straps would be good, and the bars are awful on the wrists
Future plans are to:
Fit some bullhorn bars
Maybe some matching bar tape and saddle (thinking tan/brown)
Find the socket set and adjust the pedal bearings.
- mikesbytes
Re: Finally joined the clan...
Postby mikesbytes » Wed Apr 04, 2018 10:58 pm
What gearing did you go with?
- bychosis
Postby bychosis » Thu Apr 05, 2018 7:08 am
Fixed or SS? I quite enjoy the mechanical silence of the fixie. It's also a good wet weather bike with less drivetrain to clean.
Few years time you'll be ready for the current fad of a gravel grinder
- MattyK
Postby MattyK » Thu Apr 05, 2018 7:53 am
Currently it’s just SS, not fixed, but the freewheel was so gummy it was silent anyway . A few drops of lube has got it clicking again. Not sure if I’ll go fixed as the hills to work had me spinning out
- P!N20
Postby P!N20 » Thu Apr 05, 2018 9:46 am
FTFYMattyK wrote:Only took 12 years...
CX first.bychosis wrote:Few years time you'll be ready for the current fad of a gravel grinder
MattyK - I've got some toe clips for sale if you're in need: http://www.bicycles.net.au/forums/viewt ... 25&t=96384
I can probably find some straps, too, but they'll be in average condition.
- cancan64
Postby cancan64 » Thu Apr 05, 2018 10:19 am
and then bike packingP!N20 wrote:CX first.
- MattyK
Postby MattyK » Thu Apr 05, 2018 10:32 am
Need to get some moustache wax first...P!N20 wrote: CX first.
No toe clips please. but maybe some fat velcro straps a la:
- P!N20
Postby slidetaker » Fri Apr 06, 2018 1:16 pm
Good thing is these Quando no name wheels are bottomed priced, so you won't lose too much money...
- MattyK
Postby MattyK » Fri Apr 06, 2018 1:44 pm
I’m amazed at how heavy single speed wheels are. Even into decent money territory. It would be not hard to build a wheel and tyre combo at about 2.5kg, but it would probably cost about $500. Which is over 3x what I paid for the bike.slidetaker wrote:Definitely worth getting good fixed wheels if you like riding it.
So as it stands, wheels are unlikely to get upgraded unless they die.
Some fatter rubber (~28c) is tempting, I hopped a speed hump today and the landing was pretty harsh!
- bychosis
Postby bychosis » Fri Apr 06, 2018 2:00 pm
I had some of the Reid wheels, same as Quando - heavy. After a while I shelled out and bought rims, hubs, good spokes and built them up, then got them trued at the LBS. Total cost $390. The rims were a run out special, but other stuff was the usual price. Dropped about 1kg from memory and made a big difference to the ride, especially being easier to slow the rear wheel by back pedalling.MattyK wrote:I’m amazed at how heavy single speed wheels are. Even into decent money territory. It would be not hard to build a wheel and tyre combo at about 2.5kg, but it would probably cost about $500. Which is over 3x what I paid for the bike.slidetaker wrote:Definitely worth getting good fixed wheels if you like riding it.
- MattyK
Postby MattyK » Fri Apr 06, 2018 5:14 pm
- mikesbytes
Postby mikesbytes » Fri Apr 06, 2018 9:49 pm
One problem with the single speed is that your got no rear braking. It doesn't take too long to learn to spin downhill when its fixed
- MattyK
Postby MattyK » Fri Apr 06, 2018 10:03 pm
On my commute I’m freewheeling down the first hill at 45kmh. That would be 140rpm at the cranks...
- bychosis
Postby bychosis » Fri Apr 06, 2018 10:55 pm
I’ve hit over 60 on my fixie, particularly on the hill on the way to work. It gets crazy fast on the cadence. I find there are a couple of particularl cadence points where I feel like I’m about to shake myself off the bike, but I can get past it and smooth out again. Fixed ear just adds an extra dimension - and you get to keep a ‘rear brake’ without installing one.MattyK wrote:Well I could add the rear brake on but... aesthetics...
Postby slidetaker » Mon Apr 23, 2018 1:31 pm
When you think deeper about it, it is really the rear wheel. You can run any cheap front wheel from flebay.bychosis wrote:I had some of the Reid wheels, same as Quando - heavy. After a while I shelled out and bought rims, hubs, good spokes and built them up, then got them trued at the LBS. Total cost $390. The rims were a run out special, but other stuff was the usual price. Dropped about 1kg from memory and made a big difference to the ride, especially being easier to slow the rear wheel by back pedalling.MattyK wrote:I’m amazed at how heavy single speed wheels are. Even into decent money territory. It would be not hard to build a wheel and tyre combo at about 2.5kg, but it would probably cost about $500. Which is over 3x what I paid for the bike.slidetaker wrote:Definitely worth getting good fixed wheels if you like riding it.
With the rear wheel, it is a long term investment as you do not wear your rim, no freebody nor freewheel. Fresh grease every year, the rear wheel can run years.
What I did, buy and salvage good rim from broken hub rusted spokes $20, new DT DB spokes online shipped $60, Formula rear hub online shipped $35. Total $115 for a long lasting wheel. You cannot beat that.
- P!N20
Postby P!N20 » Tue Apr 24, 2018 10:29 am
Postby slidetaker » Tue Apr 24, 2018 4:24 pm
No/not enough/not proper grease when first installed the cog. In my opinion, it ain't worth damaging the hub or the tool to get it out. Get a new cog for the new hub. Cog is cheap.P!N20 wrote:^ I stripped the thread on the hub on my Kona's stock rear wheel (too many whip skidz ;P). Bought a second hand replacement rear wheel and set about swapping the sprocket over...dear god, it was so hard getting the sprocket to budge - I could have kept running that rear wheel without a lockring and it wouldn't have come loose.
- P!N20
Postby P!N20 » Tue Apr 24, 2018 4:30 pm
Maybe...this was years ago. Been through several sprockets since then.slidetaker wrote:No/not enough/not proper grease when first installed the cog. In my opinion, it ain't worth damaging the hub or the tool to get it out. Get a new cog for the new hub. Cog is cheap.
Return to “Fixed Gear/ Single Speed”
