Bikes on the Australind train to Bunbury
- Aushiker
Postby Aushiker » Thu Aug 02, 2012 9:59 pm
Aushiker.com
- HappyHumber
Re: Bikes on the Australind train to Bunbury
Postby HappyHumber » Thu Aug 02, 2012 10:19 pm
I have heard people have been OK - but asked ahead when booking their ticket. Have also heard of some gripes from the attending staff on the train. Might be a case of luck of the draw.
I would also ask if there's offpeak times of the week - less likely like to be a heap of Mums with prams or oldies with wheelchairs and walkers being carried as well. I'd imagine they'd be the favoured travellers in which case.
- Aushiker
Postby Aushiker » Fri Aug 03, 2012 12:28 am
Good idea. I have emailed them to confirm it is okay and if they reply I will ask if they can suggest a good day to travel. I have the flexibility to do that I think.HappyHumber wrote:I would also ask if there's offpeak times of the week - less likely like to be a heap of Mums with prams or oldies with wheelchairs and walkers being carried as well. I'd imagine they'd be the favoured travellers in which case.
Aushiker.com
Postby just4tehhalibut » Fri Aug 03, 2012 2:32 am
Of course if you have a folding bike and it is bagged so they can't see 'bike' then they can't charge for taking up a 'bike' space or restrict where you get on or off, as long as you don't exceed luggage weights. Transwa gives this as "one (1) piece of stowed luggage not exceeding 20 kilograms and one (1) piece of carry on luggage not exceeding 7 kilograms."
Having said all this the Australind is an easier to use service for cyclists than the Prospector and a fairly pleasant trip.
- Lizzy
Postby Lizzy » Fri Aug 03, 2012 12:49 pm
- Aushiker
Postby Aushiker » Fri Aug 03, 2012 12:54 pm
The bike on the Australind is ok but the trailer will not be allowed.
I would suggest that you take a bus to Bunbury and the charge would be $10 per item i.e. $20
Problem solved ...
Aushiker.com
- GingaNinja
Postby GingaNinja » Mon Aug 06, 2012 11:50 am
Taking your panniers off the freewheeler would make it negligable in size and volume resulting in it easily being able to be slotted in between bikes.
- Thoglette
Postby Thoglette » Tue Aug 07, 2012 12:04 pm
Got to love it.just4tehhalibut wrote: You can get on or off only at the terminating points in Perth or Bunbury, no chance at some country stop like Waroona or Wokalup
Having said that some of the platforms are quite tight and not level with the train. But if octegenarians can get on and off safely so can a bike - after all it's not like the Australind runs to a tight connecting schedule!!!!
- HappyHumber
Postby HappyHumber » Fri Apr 13, 2018 3:05 pm
After pondering this for many years; the stars aligned for me do a trip to visit family in Bunbury with just the bike on the train over the weekend just gone. Did my research on the website and phoned up to book over the phone with a couple of questions.
At this time of posting It's $15 excess luggage for a bike - each way. As per the website, you must pre-book and the call centre lady they told me they have room for two booked bikes. I was curious about the allocated space in which they're stored. My Mum travels on the service semi-regularly and I've dropped her off and picked her up from it often enough and I was having trouble visualizing exactly where bikes went.
I departed Perth on the PM service Friday arvo; and arrived the requested 30mins prior to departure time. One of the stewards saw me with bike in between tending to the disembarking passengers and advised me where to wait. She described to me how they liked the bikes parked and let me do so. The return journey Monday morning a male steward took the bike from me and parked it.
Basically the bikes go in the space behind the trailing drivers cockpit; as the train changes direction so the driver changes ends. The space has doors on both sides of the carriage; and into the main passenger space and drivers cabin. Whilst there'd be physical space for maybe 4 or 5 bikes at an awkward pinch; two can really only go in safely against the offside carriage door. I imagine this is so as to not block the emergency exit from the passenger space.
if I do it again; I'd rig up a temporary handbrake by way of a tough 'laccy; piece of inner tube or old toe strap to go around the brake levers to prevent the bike moving. It's something I like to have handy even when I travel on the urban trains so I'm less worried about steadying or holding the bike constantly
Anyway the Australind arrangement does seem a bit of an afterthought; but it does the job. There was a second bike for my return journey for another passenger; so as ever if you're considering doing the trip with a bike; book ASAP ahead of time to reserve your token bit of alloted space!
- Aushiker
Postby Aushiker » Fri Apr 13, 2018 3:59 pm
Aushiker.com
- Thoglette
Postby Thoglette » Fri Apr 13, 2018 5:10 pm
Or it is "IDGAF"?Aushiker wrote: I guess either comprehension skills are not high in her skill set and/or the answer is no.
Yarloop is currently being upgraded.
All stations are going to be upgraded to allow wheelchair access but that doesn't mean the platforms will be full length which might restrict their ability to load bikes.
I presume the train still stops in East Bunbury and not in Bunbury?
Postby Scott_C » Fri Apr 13, 2018 6:33 pm
On a similar topic, there is a forthcoming project to purchase new "C-series" railcars, likely to be permanently coupled 6-car sets. They haven't been designed yet so now would be the time to put some pressure on PTA to include 1 or more bicycle friendly carriages as part of the fit-out.
- rifraf
Postby rifraf » Sun May 27, 2018 10:15 pm
I suspect you might be able to bring an extra wheel into the passenger carriage as luggage.
I say this as there was no supervision of my putting my bike into the last carriage nor did anyone appear to be doing much of anything regarding passenger placement although this may be different now.
I think it might be interesting for others to know that TransWA policy is bikes can only exit at Bunbury (or Perth) according to the phone call I made recently, whilst looking for alternative station options to access the Munda Biddi.
I think the concern was the time involved and holding up the timetabling.
Postby Wixxy » Tue May 29, 2018 9:06 pm
Postby redned » Thu Jun 07, 2018 1:44 pm
Interesting that what works fine in other parts of the world is a hurdle for TransWA.rifraf wrote: I think it might be interesting for others to know that TransWA policy is bikes can only exit at Bunbury (or Perth) according to the phone call I made recently, whilst looking for alternative station options to access the Munda Biddi.
I recently returned from Brittany where regional trains (TERs) have bike hanging areas. They stop at intermediate stations for less than a minute (I timed one at 40 secs) which surprisingly is plenty of time to get quite a few bikes on and off.
- rifraf
Postby rifraf » Fri Jun 08, 2018 2:25 am
Very hard to understand given that the TransWA train only allows a maximin of two bike per trip.redned wrote: Interesting that what works fine in other parts of the world is a hurdle for TransWA.
How long could it take to remove a max of two bikes
- Thoglette
Postby Thoglette » Fri Jun 08, 2018 11:09 am
The issue is storage space: the Australind is best described as a "heritage" train. It was designed in the '70s and is designed for people who would get taxis at either end (back then the train actually went to Bunbury). Or have their car waiting at the station. Quaint, I know.rifraf wrote:How long could it take to remove a max of two bikes
So there's actually very little space on the train, perhaps in an attempt to make it more "space age" and perhaps "aeroplane like" (a retrograde step if ever there was one)
(Wikipedia)
Compare the current "snack bar" arrangements with the old buffet car.
Now that's a proper buffet car.
There's really no option for adding a goods wagon for luggage, either. Nor porters to load/unload the goods wagon. And with the furious pace of the timetable, no time to allow passengers to get their own gear on or off.
Having said all that, if you can "rinko" your bike, just call it luggage.
Postby redned » Fri Jun 08, 2018 1:18 pm
My wife and I caught a train from Tullamore to Limerick in Ireland, changing at Portarlington.rifraf wrote:Very hard to understand given that the TransWA train only allows a maximin of two bike per trip.redned wrote: Interesting that what works fine in other parts of the world is a hurdle for TransWA.
It was a Sunday and there were no rail people to find out which end of the train had the bike hangers. The train pulled in. People on and off. I said to my wife jump on and we'll sort it out. We had to take our bikes on through separate doors.
So far so good.
Then the door opened at the end of my carriage and its a tea trolley! We are both blocking the passage ways by the doors! I looked at my wife with my best "what am I to do now?" look.
Tea trolley gets closer. Tea lady looking not very impressed.
Train pulls into Portarlington and we bailed out just before we disrupt the tea trolley.
All's well that ends well!
